One example concerning the Summicron 23 (TL2, ISO 400, 1/1000s, f/9) - i like this combination.
  • 4 months later...
Here is another evaluation.  Nothing shows up a lens's aberrations better than astrophotography.  Here one commonly uses a lens at maximum aperture or near it, and a poorly-corrected lens will quickly reveal its defects—flare, coma, CA, etc.—on those pristine little star points.
The 23mm Summicron is one of my favorite lenses for star-scapes.  There is a little bit of coma near the field edge, but it is minimal and counts as well-controlled, indeed. Here is an example of an unguided shot of the Northern Milky Way.  The green cast in the lower part of the image is from a photochemical reaction in the upper atmosphere.  Note the Andromeda galaxy in the lower right hand corner.  A keen eye—or I should say, an eye that knows what its looking for—will spot one of its companions just above.  (TL2, 23mm Summicron, f/2, 10 sec., ISO 3200.) This is quite a fine lens in my opinion.
The 23mm Summicron is one of my favorite lenses for star-scapes.  There is a little bit of coma near the field edge, but it is minimal and counts as well-controlled, indeed. Here is an example of an unguided shot of the Winter Milky Way.  The green cast in the lower part of the image is from a photochemical reaction in the upper atmosphere.  Note the Andromeda galaxy in the lower right hand corner.  A keen eye—or I should say, an eye that knows what its looking for—will spot one of its companions just above.  (TL2, 23mm Summicron, f/2, 10 sec., ISO 3200.) This is quite a fine lens in my opinion.
Thank you!
You're welcome!
ERRATUM: I wrote above "Winter Milky Way," but should have written "Northern Milky Way. 'Caught the error too late to edit it. Apologies.
Edited by bcorton
14 hours ago, bcorton said:
You're welcome!
Easily corrected ;)
  • 2 weeks later...
The 23 is supposed to be the better lens which is logical, given that the compromises of the design of the 18 are slanted towards compactness with acceptable quality.
