Einst_Stein Posted February 14, 2020 Share #1 Posted February 14, 2020 (edited) Advertisement (gone after registration) This is not strictly Leica, but I assume many Leica people would like to know. I hope. It is about scanning negative films to digital positive using digital camera. There is a 1-click solution using Hasselblad Phocus. Before talking about the post-scan processing, let's start with the camera set up. FYI, this is what I have, you may find your own preference. --- 1: Scan lens: Rodenstock Apo-Rodagon-D 75mm F4 enlarger lens. It has no focus, and has the Leica M39 mount. ( A used one on ebay is ~ $200). --- 2: Scan focusing: M39 to hasselblad adapter + Hasseblad extension tubes (21mm, 56mm) or Hasselblad Bellows + copy stand + Hasselblad camera with digital back Now, assume you have taken the pictures from your negatives, and you are ready to convert to positive. --- Goto Hasselblad Phocus --- On the manual bar on the top right, next to "... adjust, Export", find the little "triangle and bars", click it, look for "reproduce", select it so that it can appear in thr "adjust" manual. --- click "adjust", then look for "reproduce", click "reproduce" and look for "response", click "response" to select "negative". Now you are asking Phocus to convert your negatives to positive (and positive if the original is positive". --- Go back to the top manual bar, select "Export"..... from now on you are on your way to export the file to, say, DNG, or whatever. Remark 1: The above flow only works for the files from Hasselblad digital back. If you are using Leica digital there are other excellent Lightroom plug-ins, but I haven't tried. Remark 2: About the copy stand, Leitz has a very lovely copy stand. Mine is the Zeiss equivalent. They are small and work nicely with the extension tubes or the bellows. But if you use extension tube, you might need more space a long quick release between your camera and the copy stand camera clamp as a focus slider. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 14, 2020 by Einst_Stein 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/306462-1-click-convert-negative-to-positive-using-phocus/?do=findComment&comment=3912892'>More sharing options...
Advertisement Posted February 14, 2020 Posted February 14, 2020 Hi Einst_Stein, Take a look here 1-Click Convert Negative to Positive Using Phocus. I'm sure you'll find what you were looking for!
250swb Posted February 15, 2020 Share #2 Posted February 15, 2020 So the only thing that Leica owners may not already have is a Hasselblad camera with a digital back? Well that's easy to rectify. But you fail to mention the light table for back projecting the film, is that also Hasselblad or Hermes? 1 1 Link to post Share on other sites More sharing options...
Einst_Stein Posted February 16, 2020 Author Share #3 Posted February 16, 2020 7 hours ago, 250swb said: So the only thing that Leica owners may not already have is a Hasselblad camera with a digital back? Well that's easy to rectify. But you fail to mention the light table for back projecting the film, is that also Hasselblad or Hermes? This is an info FYI. If you don’t like it, ignore it. Link to post Share on other sites More sharing options...
frame-it Posted February 16, 2020 Share #4 Posted February 16, 2020 35 minutes ago, Einst_Stein said: This is an info FYI can you please post a photo of the converted file before any other adjustments Link to post Share on other sites More sharing options...
Dmitry Belyakov Posted June 11, 2020 Share #5 Posted June 11, 2020 What kind of copy stand is that? Looks a bit like BEOON, but obviously is not. Link to post Share on other sites More sharing options...
Einst_Stein Posted June 11, 2020 Author Share #6 Posted June 11, 2020 2 hours ago, Dmitry Belyakov said: What kind of copy stand is that? Looks a bit like BEOON, but obviously is not. it's the copy stand from old Zeiss. I got it from ebay. But ot is not relevant, Your readily usable tripod shpyld work just as well or even better. I started with the cute copy stand thinking it would be easier in alignment but it turned out not true. Not for a heavy camera, at least. The modern DSLR or SL is already so heavy that the vertical pole would bend slightly and lost the perfect vertical. The other problem is keeping it balance. Try your ecisting tripod first. Use spirit level to adjust the leg extends to find the best vertical and horizontal position. It is much simpler than you might imaging. I get it done in less than three minutes. I have replaced the light box once. The one bought from B&H is not bright enough and not big enough. Besides, all B&H light pad are much more expensive. I got an LED tracing pad from Amazon for less than one third of the price, A4 size, 2X larger, and about 2-4 X brighter. The brighter light reduces exposure time to reduce the effect of the annoying environment light, so that you dont have to work in the dark. One thing to watch when purchasing LED is to make sure it DOES NOT have the grid mask. It must be patternless plain white. This is why you cannot use your smart pad or smart phone. Link to post Share on other sites More sharing options...
Stealth3kpl Posted June 11, 2020 Share #7 Posted June 11, 2020 Advertisement (gone after registration) On 2/15/2020 at 8:46 PM, 250swb said: So the only thing that Leica owners may not already have is a Hasselblad camera with a digital back? Well that's easy to rectify. But you fail to mention the light table for back projecting the film, is that also Hasselblad or Hermes? and I counted 7 clicks 😂 Link to post Share on other sites More sharing options...
Einst_Stein Posted June 11, 2020 Author Share #8 Posted June 11, 2020 3 hours ago, Stealth3kpl said: and I counted 7 clicks 😂 Amazing. Only the first shot need 1 click, after that, zero click. Study the manual, Link to post Share on other sites More sharing options...
Stealth3kpl Posted June 11, 2020 Share #9 Posted June 11, 2020 54 minutes ago, Einst_Stein said: Amazing. Only the first shot need 1 click, after that, zero click. Study the manual, I'm just pulling your leg. Pete Link to post Share on other sites More sharing options...
Einst_Stein Posted June 11, 2020 Author Share #10 Posted June 11, 2020 nice try but ugly move. Link to post Share on other sites More sharing options...
fotomas Posted June 11, 2020 Share #11 Posted June 11, 2020 Would be interesting to see some results. f-) Link to post Share on other sites More sharing options...
marchyman Posted June 12, 2020 Share #12 Posted June 12, 2020 13 hours ago, Einst_Stein said: One thing to watch when purchasing LED is to make sure it DOES NOT have the grid mask. It must be patternless plain white. This is why you cannot use your smart pad or smart phone. I use diffusion panels from a flash mounted soft box wrapped over a cheap LED video light with its own diffuser. The three layers of diffusion hides the fact that light source is actually an array of LEDs. I still get enough light to do the job. Link to post Share on other sites More sharing options...
Einst_Stein Posted June 12, 2020 Author Share #13 Posted June 12, 2020 (edited) 33 minutes ago, marchyman said: I use diffusion panels from a flash mounted soft box wrapped over a cheap LED video light with its own diffuser. The three layers of diffusion hides the fact that light source is actually an array of LEDs. I still get enough light to do the job. I am also thinking to use flash and the slide copy tube but have not tried it yet. I think eventually that would be the better setup. A diffuser in front of the grided LED should be good idea too . Edited June 12, 2020 by Einst_Stein Link to post Share on other sites More sharing options...
Pembers357 Posted May 27, 2021 Share #14 Posted May 27, 2021 Thanks for posting this. I had been using Negative Lab Pro in Lightroom, but it was pain. I Just used my tethered X1D to ‘scan’ some 6x6 negatives straight into Phocus as you suggest. Excellent one click solution. Thank you. I gave up using a tripod. I bought a Kaiser copy stand and Kaiser negative holder, complete with 6x6 inserts, to hold the negatives really flat. Works very well, sitting atop the Kaiser Slimlite Plano LED light box. Not a cheap solution, but very reliable. Link to post Share on other sites More sharing options...
bags27 Posted May 29, 2021 Share #15 Posted May 29, 2021 (edited) On 5/27/2021 at 5:51 PM, Pembers357 said: Thanks for posting this. I had been using Negative Lab Pro in Lightroom, but it was pain. I Just used my tethered X1D to ‘scan’ some 6x6 negatives straight into Phocus as you suggest. Excellent one click solution. Thank you. I gave up using a tripod. I bought a Kaiser copy stand and Kaiser negative holder, complete with 6x6 inserts, to hold the negatives really flat. Works very well, sitting atop the Kaiser Slimlite Plano LED light box. Not a cheap solution, but very reliable. Welcome to the Forum! Since we're offering alternatives, this is an excellent negative, far less expensive, holder: https://clifforth.co.uk/ And, while Neg Lab Pro is quite good for batch files, I find Neg Master a bit better for fine-tuning conversions. Edited May 29, 2021 by bags27 1 Link to post Share on other sites More sharing options...
algrove Posted July 19, 2024 Share #16 Posted July 19, 2024 @Einst_Stein Thanks for posting this even though I am trying it 3 years later. With the newer Phocus one must activate the "Reproduction" section in I believe it was "Tools" in order the get to the bottom section of it under "Response" and then on the click down arrow select" "Negative". It works fine and thanks. Link to post Share on other sites More sharing options...
algrove Posted July 19, 2024 Share #17 Posted July 19, 2024 (edited) Neglected to mention I use the Skier light base and that comes with solid 35mm and 120 frames for holding film and the Skier foldable copy stand. Then using the 38 f2.5 V lens with 20mm Auto Macro Tube on my CFV 100C I find I lose less of my frame since the 120 image fills a very large portion of my 44x33 image. I also use this same Skier setup with my M11 and the Laowa Macro 85mm lens at the minimum focus distance and f11 with 35mm film scanning. Edited July 19, 2024 by algrove Link to post Share on other sites More sharing options...
