stevegaskin Posted January 29, 2020 Share #1 Posted January 29, 2020 Advertisement (gone after registration) I've just acquired this lens which unfortunately came without the front cap. Could someone please confirm if the A36 cap is the correct version for this lens. Thanks in advance Link to post Share on other sites More sharing options...
Advertisement Posted January 29, 2020 Posted January 29, 2020 Hi stevegaskin, Take a look here Lens cap for Leitz Summaron 3.5cm, f3.5 lens © 1954 . I'm sure you'll find what you were looking for!
a.noctilux Posted January 29, 2020 Share #2 Posted January 29, 2020 If your lens is like the left one, yes A36 cap Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! this one needs A42 cap and E39 filter 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! this one needs A42 cap and E39 filter ' data-webShareUrl='https://www.l-camera-forum.com/topic/305863-lens-cap-for-leitz-summaron-35cm-f35-lens-%C2%A9-1954/?do=findComment&comment=3902025'>More sharing options...
andyturk Posted January 29, 2020 Share #3 Posted January 29, 2020 I use one of these: fleabay link Link to post Share on other sites More sharing options...
stevegaskin Posted January 29, 2020 Author Share #4 Posted January 29, 2020 2 hours ago, a.noctilux said: If your lens is like the left one, yes A36 cap Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! this one needs A42 cap and E39 filter Hi, mine looks like the one on the left but it is M mount not LTM; I believe they are the same fitting which is a 39mm filer thread, but a 42mm inside diameter cap fit. Link to post Share on other sites More sharing options...
Pyrogallol Posted January 29, 2020 Share #5 Posted January 29, 2020 (edited) If it is the version in the left hand picture I think you will find that it is a screw mount lens with a bayonet adaptor attached, which is removable. the lens cap is old style A36. Edited January 29, 2020 by Pyrogallol Link to post Share on other sites More sharing options...
wizard Posted January 29, 2020 Share #6 Posted January 29, 2020 vor 13 Minuten schrieb stevegaskin: Hi, mine looks like the one on the left but it is M mount not LTM; I believe they are the same fitting which is a 39mm filer thread If your lens looks like the on the left, it is the A36 version, which does not have a 39mm filter thread. That's why the lens caps for both versions are different (the lens cap for the older version has a smaller diameter). Link to post Share on other sites More sharing options...
a.noctilux Posted January 29, 2020 Share #7 Posted January 29, 2020 Advertisement (gone after registration) The good thing with Leitz/Leica lenses is compatibility since almost a century 😉... Here, my trio old LTM lenses that I use on my Monochrom : We can see that those 35/50/90 have LTM to M adapters and on Summaron 3.5/3.5cm another filter E39 size to A36 called SOOGZ, not seen A42 cap for soogz and the other two need A36 caps Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/305863-lens-cap-for-leitz-summaron-35cm-f35-lens-%C2%A9-1954/?do=findComment&comment=3902136'>More sharing options...
TomB_tx Posted January 29, 2020 Share #8 Posted January 29, 2020 If you need 36 mm, there are options from way back east: https://www.amazon.com/Pixco-Front-Leica-Protect-Protective/dp/B01NBWWFVP Link to post Share on other sites More sharing options...
stevegaskin Posted January 29, 2020 Author Share #9 Posted January 29, 2020 I thought it best to show my lens, so images attached. I measured the outside diameter of the front ring and it is 42mm. I hope this helps to obtain better clarification. Thanks Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/305863-lens-cap-for-leitz-summaron-35cm-f35-lens-%C2%A9-1954/?do=findComment&comment=3902158'>More sharing options...
a.noctilux Posted January 29, 2020 Share #10 Posted January 29, 2020 Definitely A42 cap or E39 "new" plastic Leica #14038 you can buy everywhere ! Link to post Share on other sites More sharing options...
UliWer Posted January 29, 2020 Share #11 Posted January 29, 2020 (edited) Your lens has 39mm filter mount and needs the A42 cap, which is the most common cap to be used for many lenses up to the current 1:4/90mm Makro-Elmar. The lens is part of the first series of 35mm Summarons, which were made for the M3 to be used with additional finder. I am not sure though but I think it activates the frames for 50mm with an M-Camera - not 35mm with an M2 or a later model. Btw: the rear element of your lens looks very good on your photo; the Summarons often are rather foggy on the rear element, obviously no problem for your lens. Edited January 29, 2020 by UliWer Link to post Share on other sites More sharing options...
stevegaskin Posted January 29, 2020 Author Share #12 Posted January 29, 2020 1 minute ago, UliWer said: Your lens has 39mm filter mount and needs the A42 cap, which is the most common cap to be used for many lenses up to the current 1:4/90mm Makro-Elmar. The lens is part of the first series of 35mm Summarons, which were made for the M3 to be used with additional finder. I am not sure though but I think it activates the frames for 50mm with an M-Camera - not 35mm with an M2 or a later model. Hi, that’s an interesting point you have made. I had looked at a few of these and dismissed ones which came with ‘goggles’ for the reason you state. This one from a well known LONDON Leica dealer doesn’t appear to have any fixings for ‘goggles’ and they made no mention of the framelines in the listing or when I spoke to them (we didn’t discuss that particular issue just condition etc); I assumed as there were no apparent fixings that the lens would activate the correct framelines; perhaps I need to check. Link to post Share on other sites More sharing options...
UliWer Posted January 29, 2020 Share #13 Posted January 29, 2020 (edited) The first Summarons with M-bayonet - and according to the serial number, your‘s is a very early one - were made for the M3 which had no 35mm frame. So the lenses just keep the normal 50mm frame of the M3 and you had to use the additional viewfinder SBLOO to get the proper field of view for 35mm. The goggled versions were introduced later - still only with 50mm frame, but the additional goggles enlarged its field of view. When the M2 was introduced later again, they offered a „proper“ version which activates the 35mm frame. Edited January 29, 2020 by UliWer Link to post Share on other sites More sharing options...
UliWer Posted January 29, 2020 Share #14 Posted January 29, 2020 Here is a thread were you get almost any information you can get about the Summarons for the M: Link to post Share on other sites More sharing options...
stevegaskin Posted January 29, 2020 Author Share #15 Posted January 29, 2020 14 minutes ago, UliWer said: Here is a thread were you get almost any information you can get about the Summarons for the M: Hi again, thanks for the link, I’m obtaining a greater understanding, and now realise that this issue is more than about the missing lens cap; and perhaps I should have researched this more! I basically wanted a reasonably priced 35mm to compliment my 28mm Elmarit and 50mm Summarit and planned to use this predominantly on an M6 although I also have a digital M which I would use it with occasionally. I really liked the idea of using a ‘vintage’ lens (mainly for street photography), as I can't justify spending 1000’s on a more modern version. I now have more questions! Can I use this by selecting the correct framelines once mounted and will the rangefinder accurately focus, or should I return the lens and wait to source a later, ‘affordable’ alternative. Link to post Share on other sites More sharing options...
stevegaskin Posted January 29, 2020 Author Share #16 Posted January 29, 2020 (edited) 27 minutes ago, UliWer said: Here is a thread were you get almost any information you can get about the Summarons for the M: Hi again, thanks for the link, I’m obtaining a greater understanding, and now realise that this issue is more than about the missing lens cap; and perhaps I should have researched this more! I basically wanted a reasonably priced 35mm to compliment my 28mm Elmarit and 50mm Summarit and planned to use this predominantly on an M6 although I also have a digital M which I would use it with occasionally. I really liked the idea of using a ‘vintage’ lens (mainly for street photography), as I can't justify spending 1000’s on a more modern version. I now have more questions! Can I use this by selecting the correct framelines once mounted and will the rangefinder accurately focus, or should I return the lens and wait to source a later, ‘affordable’ alternative. Edited January 29, 2020 by stevegaskin Link to post Share on other sites More sharing options...
