Alan Friedman Posted May 4, 2022 Share #41 Posted May 4, 2022 Advertisement (gone after registration) My work flow has long been with Adobe Photoshop, importing with there Camera Raw plug-in. I've only dabbled with Lightroom and have not used Capture One. Camera Raw imports in-camera cropped images from the Q2M as cropped image files, which is my preference if I framed the image using the crop lines in the camera. Link to post Share on other sites More sharing options...
Advertisement Posted May 4, 2022 Posted May 4, 2022 Hi Alan Friedman, Take a look here Capture One and Leica Q2 crop mode . I'm sure you'll find what you were looking for!
jaapv Posted May 4, 2022 Share #42 Posted May 4, 2022 That post is three years old… Link to post Share on other sites More sharing options...
marchyman Posted May 4, 2022 Share #43 Posted May 4, 2022 On 5/3/2022 at 1:24 PM, JS2020 said: exiftool: command not found (127) The free Exiftool utility is available at https://exiftool.org for both Mac and Windows machines. Link to post Share on other sites More sharing options...
hdmesa Posted May 5, 2022 Share #44 Posted May 5, 2022 (edited) On 5/4/2022 at 9:21 AM, Pelu2010 said: I thought that C1 had an update and it could use the Leicas / sl2 and Sl2s and M11. It can and has supported Leica cameras fairly well for a long time. There's nothing about DNG that has prevented C1 from incorporating this feature – it's just not a priority for them. Edited May 5, 2022 by hdmesa Link to post Share on other sites More sharing options...
hdmesa Posted May 5, 2022 Share #45 Posted May 5, 2022 On 5/4/2022 at 10:14 AM, jaapv said: That post is three years old… And yet they have still not implemented this feature in Capture One. That's how sleepy the folks at C1 are with regard to this and many other features such lens profiles. Link to post Share on other sites More sharing options...
holgerf Posted June 9, 2022 Share #46 Posted June 9, 2022 Am 11.4.2019 um 01:41 schrieb b_ben: Hi, For the first time, I'm considering getting a Leica, as the Q2 looks very tempting... However, I was worried that the crop modes would not work with Capture One, which is a bit of a deal breaker. So, before purchasing one, I wanted to make sure that this could be fixed and made a script to retrieve the crop factor and apply it in Capture One. 2 goods news: It's possible! It works with a combination of Exiftool and Applescript (so, unfortunately, it doesn't work with the Windows version), and it integrates into the Capture One menus I release it as open-source, so that others can use it if they face the same issue: https://github.com/bezineb5/c1-crop-from-exif Now, I just have to wait until B&H gets some Q2 in stock... unless I finally go for a Q. I hope this will help some of you! Ben Hi Ben, the script does work wunderfully and saved my life using the Q2 – thanks! Is there a chance to make it work for other cameras which also offer a crop mode? Just tried it with my Leica M11 but didn't work. Cheers Holger Link to post Share on other sites More sharing options...
b_ben Posted June 9, 2022 Author Share #47 Posted June 9, 2022 Advertisement (gone after registration) 2 hours ago, holgerf said: Hi Ben, the script does work wunderfully and saved my life using the Q2 – thanks! Is there a chance to make it work for other cameras which also offer a crop mode? Just tried it with my Leica M11 but didn't work. Cheers Holger Thanks Holger! The Q/Q2 uses fairly standard EXIF fields to store the crop mode (namely the DefaultUserCrop field). That's unfortunate that it doesn't work with the M11, I'm not sure why. I (unfortunatelly) don't have a M11 and dpreview.com did not publish their RAWs. What you can try is to do in a terminal: exiftool -v <path to your file> And see if there's a tag which could contain the crop information. Best regards, Benjamin Link to post Share on other sites More sharing options...
holgerf Posted June 10, 2022 Share #48 Posted June 10, 2022 Thanks Ben! Tried it and got a result at the end of the list. See attachment. Does this help to figure out how to change the script? Cheers Holger Exif-Result Leica M11.rtf Link to post Share on other sites More sharing options...
b_ben Posted June 10, 2022 Author Share #49 Posted June 10, 2022 11 minutes ago, holgerf said: Thanks Ben! Tried it and got a result at the end of the list. See attachment. Does this help to figure out how to change the script? Cheers Holger Exif-Result Leica M11.rtf 9.89 kB · 0 downloads That's exactly the same as the Q... so the script should work. When you tried, did you get an error? Link to post Share on other sites More sharing options...
holgerf Posted June 11, 2022 Share #50 Posted June 11, 2022 To your question: no error, just does not work. I read out the date of a Q2 file. At least the position of the Default User Crop seems to be different: 50) in M11, 28) in Q2. See second attachment. I prepared a folder on my dropbox with a sample file of the M11 here: https://www.dropbox.com/sh/8ejeqoudnujw1zp/AADSFxs-wExMOEDQJGezz8Mda?dl=0 May be you can just try it? Thanks and cheers Holger Exif-Result Leica C2.rtf Link to post Share on other sites More sharing options...
lebanese blonde Posted September 14, 2022 Share #51 Posted September 14, 2022 Thanks for the script! My wife just got a Q and this script saves a ton of time. The Qs crop mode is pretty useless in my opinion without this script for Capture One users. 1 Link to post Share on other sites More sharing options...
