adan Posted April 7, 2019 Share #21 Posted April 7, 2019 Advertisement (gone after registration) 11 hours ago, andyturk said: I never noticed the green cast on the sides before, but now that you mention it, it's fairly obvious in the barbership pic. Interestingly, I did configure the lens in the camera's menu and the metadata in Lightroom shows the correct lens. However, Lightroom doesn't have a profile for the 21/2.8 ASPH, so I've been using the one for the Super Elmar. Toggling "Enable Profile Corrections" on and off doesn't seem to affect the greenish cast though. That's curious. You might triple-check that you selected the 21 Elmarit-M f/2.8 ASPH in the camera menu, and not the previous non-ASPH 21 Elmarit-M (11134). Both are listed in the menu side-by-side (well, right above and below each other). And those color corrections are very model-specific - gotta match the exact lens type, not just any 21mm f/2.8. And indeed, as I said, the LR lens profiles don't do diddly for the color stains. Simply not included in their programming. Gotta either set the camera correctly - or add the "flat-field" plugin to your LR, and use that separately, in addition to "Enable Profile Corrections." 1 Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 7, 2019 Posted April 7, 2019 Hi adan, Take a look here Leica Elmarit 21mm f2.8 ASPH 6 bit. I'm sure you'll find what you were looking for!
happymac Posted April 8, 2019 Share #22 Posted April 8, 2019 (edited) Probably it works, if you install it here as well: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Mac: Macintosh HD / Users / *your username* / Library / Application Support / Adobe / CameraRaw / LensProfiles / 1.0 / LeicaWin: 😄 \ Users \ *your username* \ AppData \ Roaming \ Adobe \ CameraRaw \ LensProfiles \ ... Edited April 8, 2019 by happymac 1 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Mac: Macintosh HD / Users / *your username* / Library / Application Support / Adobe / CameraRaw / LensProfiles / 1.0 / Leica Win: 😄 \ Users \ *your username* \ AppData \ Roaming \ Adobe \ CameraRaw \ LensProfiles \ ... ' data-webShareUrl='https://www.l-camera-forum.com/topic/295852-leica-elmarit-21mm-f28-asph-6-bit/?do=findComment&comment=3717966'>More sharing options...
andyturk Posted April 8, 2019 Share #23 Posted April 8, 2019 (edited) 8 hours ago, happymac said: Probably it works, if you install it here as well: Mac: Macintosh HD / Users / *your username* / Library / Application Support / Adobe / CameraRaw / LensProfiles / 1.0 / LeicaWin: 😄 \ Users \ *your username* \ AppData \ Roaming \ Adobe \ CameraRaw \ LensProfiles \ ... That's a Bingo! I.e., the profile shows up correctly now. Thanks! EDIT: The green cast remains in the 21mm barbershop photo even with the "Tom Summer 2012" profile. Edited April 8, 2019 by andyturk Quote Link to post Share on other sites More sharing options...
happymac Posted April 8, 2019 Share #24 Posted April 8, 2019 Smile! 😀 By the way: My profile does no color correction, only distortion. Quote Link to post Share on other sites More sharing options...
Telemetric Posted April 9, 2019 Author Share #25 Posted April 9, 2019 On 4/7/2019 at 9:59 AM, happymac said: !Hola Telemetric! Sorry, I should have mentioned, how to install it. Go to the applications folder. Choose Adobe Lightroom (that's also a folder). In this folder you find the LR application "Adobe Lightroom.app". Right-click on it and choose "Show package content". Go to "...Contents/Resources/LensProfiles/1.0/Leica". You should see the following (or similar). Drag the profile file into the Leica folder. Restart LR and you should be able to use it. Good luck! Tom Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Thanks a lot Tom! I copied the file there but it does not appear in the list. I even tried to change the name to match the nomenclature of the other leica lenses... and nothing. I have Lightroom CC ver 8.2.1 Any suggestion Quote Link to post Share on other sites More sharing options...
Telemetric Posted April 9, 2019 Author Share #26 Posted April 9, 2019 On 4/8/2019 at 7:56 AM, happymac said: Probably it works, if you install it here as well: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Mac: Macintosh HD / Users / *your username* / Library / Application Support / Adobe / CameraRaw / LensProfiles / 1.0 / LeicaWin: 😄 \ Users \ *your username* \ AppData \ Roaming \ Adobe \ CameraRaw \ LensProfiles \ ... Worked!!!! Thanks a lot!!!! IS GREAT!! Quote Link to post Share on other sites More sharing options...
Telemetric Posted April 13, 2023 Author Share #27 Posted April 13, 2023 Advertisement (gone after registration) Hello! Here I am again after... 4 years! I had to reinstall my MACOS and I installed the lense profile in both folders but... it does not appear. I have now the Lightroom Classic 12.2.1 version and Camera Raw 15.2 Any suggestion? Thanks a lot! Quote Link to post Share on other sites More sharing options...
happymac Posted April 13, 2023 Share #28 Posted April 13, 2023 Hello Telemetric, I’m glad to hear from you again. I hope you are fine. In the meantime I’ve switched from LR to Capture One. I kept my LR setup in a virtual Parallels volume, but I‘ve not used it for years. I‘m afraid, but concerning LR 12 I can‘t assist… 😟 I‘d assume, older profiles won‘t work with newer versions of LR. All the best Tom Quote Link to post Share on other sites More sharing options...
Telemetric Posted April 13, 2023 Author Share #29 Posted April 13, 2023 Hello! Is nice to read you again! i solved it, the new lightroom has an import option in Files-> import profiles. Very easy! 1 Quote Link to post Share on other sites More sharing options...
happymac Posted April 13, 2023 Share #30 Posted April 13, 2023 Oh perfect – it’s really good to hear, that the profile, I worked out years ago, still is alive. 😀 1 Quote Link to post Share on other sites More sharing options...
Telemetric Posted April 13, 2023 Author Share #31 Posted April 13, 2023 Just now, happymac said: Oh perfect – it’s really good to hear, that the profile, I worked out years ago, still is alive. 😀 Yes! And I love it! I save it as gold! Thanks for your effort and your file! You are the best! 👏👏🙏 1 Quote Link to post Share on other sites More sharing options...
happymac Posted April 13, 2023 Share #32 Posted April 13, 2023 Thank so much! ☺️ 1 Quote Link to post Share on other sites More sharing options...
