bullmoon Posted July 4, 2019 Share #41 Posted July 4, 2019 Advertisement (gone after registration) On 3/17/2019 at 3:05 PM, sbarrenos said: Best strap I have ever had. Not the most elegant, but the most practical CORREA LEICA ESTRECHA P/M Y R (14312) Totally agree - had those on my M cameras (what they shipped with) and I got one for the Q and just moved it to the Q2. Best strap hands down. Link to post Share on other sites More sharing options...
Advertisement Posted July 4, 2019 Posted July 4, 2019 Hi bullmoon, Take a look here Avoiding strap ring scratches? . I'm sure you'll find what you were looking for!
John Photography Posted July 4, 2019 Share #42 Posted July 4, 2019 I use a round rubber O-ring with my Monarch BOA strap and works like a charm. I used the same set up with my Q for 4 yrs and never had issues with scratches. Link to post Share on other sites More sharing options...
Ahsu88 Posted October 18, 2019 Share #43 Posted October 18, 2019 Vi Vante has one that doesn’t scratch. The only problem is you can’t adjust the length of this strap. They do offer another strap that you can adjust, but required you install a triangle ring like on Nikon camera to connect. https://www.amazon.com/dp/B07NDJSJ5W/?coliid=I3NTO11JABPYOH&colid=GW2ZPZ7SMDSG&psc=1 Link to post Share on other sites More sharing options...
Herr Barnack Posted October 19, 2019 Share #44 Posted October 19, 2019 (edited) Here is another option: https://www.vi-vante.com/camerastraps/sheetline/rope/aqua-blue It's also available in silver/gray and black if the blue is not your cup of tea. I just got one of these for my Q2. Once it finally arrives, it will be wearing this strap. Vi Vante has many different straps to choose from - some made of leather, some made of synthetic rope. They make some nice products imho. Edited October 19, 2019 by Herr Barnack Link to post Share on other sites More sharing options...
DexL Posted October 20, 2019 Share #45 Posted October 20, 2019 On 7/4/2019 at 12:37 AM, John Photography said: I use a round rubber O-ring with my Monarch BOA strap and works like a charm. I used the same set up with my Q for 4 yrs and never had issues with scratches. Agreed ...rubber O-rings or washers from a good hardware store work like a charm. Link to post Share on other sites More sharing options...
rbookman Posted October 31, 2019 Share #46 Posted October 31, 2019 On 3/18/2019 at 5:53 AM, budjames said: Here is my solution to avoid marks on my M10 bodies, quick releases system from Peak Design. It also allows me to very quickly and easily change from a Gordy leather wrist strap to a neck strap. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography or on Instagram at www.instagram.com/budjamesphoto. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! How did you get the Peak ends through the hole on your M10? I tried to do that on my Q2 and had to use the metal rings supplied by Peak.... Link to post Share on other sites More sharing options...
budjames Posted November 1, 2019 Share #47 Posted November 1, 2019 Advertisement (gone after registration) 17 hours ago, rbookman said: How did you get the Peak ends through the hole on your M10? I tried to do that on my Q2 and had to use the metal rings supplied by Peak.... I was able to get them started in the hole and then pull through with very fine point needle noses pliers. However, since I made the post you are referring to, I have since started using the split rings with leather protector to give a little more length to the set up. I found that the clip on the strap that attaches to the PD round connector was rubbing the body. By adding the split ring, the PD round connector clears the body. See attached photos.. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography or on Instagram at www.instagram.com/budjamesphoto. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/295309-avoiding-strap-ring-scratches/?do=findComment&comment=3845641'>More sharing options...
Phil_P Posted November 1, 2019 Share #48 Posted November 1, 2019 17 hours ago, rbookman said: How did you get the Peak ends through the hole on your M10? I tried to do that on my Q2 and had to use the metal rings supplied by Peak.... Just fitted this week Peak ends to a Q-P I have just bought... using the previously mentioned on here dental floss trick, and pulling them though quite easily. Link to post Share on other sites More sharing options...
roydonian Posted November 1, 2019 Share #49 Posted November 1, 2019 In the days when I used a Digilux 2, I bought a LCD rear screen protector, cut two small rectangular pieces from it, and attached these directly above the eyelets on the body so that they would play the same role as the plastic anti-scuff pads on my M camera. Link to post Share on other sites More sharing options...
Tim B Posted November 2, 2019 Share #50 Posted November 2, 2019 (edited) Previous post posted in error, sorry. Can’t delete it. I thought that the new split rings from PD were a great idea and started using them on my new CL (and my old Q) for which I bought a set of new PD connectors. However I found that they came a little too close to the body for comfort and have stopped using them. The pull through method of attaching the clips works for me although I think that PD have made their connector cords slightly thicker than the old ones. Tim Edited November 2, 2019 by Tim B Link to post Share on other sites More sharing options...
Scott997 Posted November 3, 2019 Share #51 Posted November 3, 2019 I am the owner of the Vi Vante brand and saw the web traffic from this post and thought I'd chime in. I'm an enthusiast and Leica shooter just like you all are. I make products specifically for Leica cameras. When I design my straps I know it's of top priority to my customers that they don't mark up their cameras and hold up. I use thick Nappa leather for the side protection, that is not split seam or pleather. In addition I have developed a quick release system that doesn't look like a ping pong racket with dental floss. It's not currently for sale yet, but will sell it under the stipulation the customer has a half case, that is the only way to protect against rubbing with these. It consists of a Titanium ring for the body and a very special micro clip. This clip goes through the eye of the side protection and clips on to our electroplated key rings on the strap. 1 Link to post Share on other sites More sharing options...
LBJ2 Posted July 11, 2021 Share #52 Posted July 11, 2021 On 11/2/2019 at 9:13 PM, Scott997 said: I am the owner of the Vi Vante brand and saw the web traffic from this post and thought I'd chime in. I'm an enthusiast and Leica shooter just like you all are. I make products specifically for Leica cameras. When I design my straps I know it's of top priority to my customers that they don't mark up their cameras and hold up. I use thick Nappa leather for the side protection, that is not split seam or pleather. In addition I have developed a quick release system that doesn't look like a ping pong racket with dental floss. It's not currently for sale yet, but will sell it under the stipulation the customer has a half case, that is the only way to protect against rubbing with these. It consists of a Titanium ring for the body and a very special micro clip. This clip goes through the eye of the side protection and clips on to our electroplated key rings on the strap. 2 Link to post Share on other sites More sharing options...
Jst13 Posted July 11, 2021 Share #53 Posted July 11, 2021 I am the happiest guy here..Never used straps on any camera i owned so far and thats a lot. Always had a sling bag, shot and - back in the bag 🤗 Link to post Share on other sites More sharing options...
forkin Posted July 16, 2021 Share #54 Posted July 16, 2021 COOPH ‘Leica Rope’ straps (100 cm & 120mm) include supposedly protective leather disks (~20 mm diameter). I found them only partially protective, so I had my shoe repairman cut larger ones (~25 mm dia). I also protect my Q2M with an inexpensive, leather Chinese half-case that includes a built-in, comfortable handgrip (roughly $US 89 on eBay). Link to post Share on other sites More sharing options...
prio Posted September 1, 2021 Share #55 Posted September 1, 2021 On 3/18/2019 at 5:53 AM, budjames said: Here is my solution to avoid marks on my M10 bodies, quick releases system from Peak Design. It also allows me to very quickly and easily change from a Gordy leather wrist strap to a neck strap. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography or on Instagram at www.instagram.com/budjamesphoto. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Hey Bud, How did you feed the PD quick release disc lanyard through the camera’s eyelets? I’ve tried and tried with no success. I am about to install split rings which is going to scratch my Q2. thanks prio Link to post Share on other sites More sharing options...
Guest Posted September 1, 2021 Share #56 Posted September 1, 2021 PD changed the thickness of the cord on the little disks ... earlier ones lighter and will barely fit ... no way on the new ones ... seems they got caught out with failures on the originals ... Link to post Share on other sites More sharing options...
prio Posted September 1, 2021 Share #57 Posted September 1, 2021 Yes, I read a story/post detailing the failures with the lighter thread after I posted here. I have wet and lubricated the thread and have tried various tools to feed it and there is no way. So frustrating because that damn camera makes me obsess on keeping her out of harms way. so meanwhile, I installed the arca plate included with the PD travel tripod and attached two of the QR disc to that and sling the Q2 crossbody style. I haven’t tested it across my ecosystem (tripod, fluid head, slider) yet but will evaluate over the next couple of days. Link to post Share on other sites More sharing options...
Marc B-C Posted September 1, 2021 Share #58 Posted September 1, 2021 1 hour ago, prio said: Yes, I read a story/post detailing the failures with the lighter thread after I posted here. I have wet and lubricated the thread and have tried various tools to feed it and there is no way. So frustrating because that damn camera makes me obsess on keeping her out of harms way. so meanwhile, I installed the arca plate included with the PD travel tripod and attached two of the QR disc to that and sling the Q2 crossbody style. I haven’t tested it across my ecosystem (tripod, fluid head, slider) yet but will evaluate over the next couple of days. Fishing line is your friend to feed it through. Easy solution if you have some. 1 Link to post Share on other sites More sharing options...
prio Posted September 1, 2021 Share #59 Posted September 1, 2021 32 minutes ago, Marc B-C said: Fishing line is your friend to feed it through. Easy solution if you have some. Hmmm… makes perfect sense! I will give that try. cheers! p 2 hours ago, docmoore said: PD changed the thickness of the cord on the little disks ... earlier ones lighter and will barely fit ... no way on the new ones ... seems they got caught out with failures on the originals ... Link to post Share on other sites More sharing options...
prio Posted September 2, 2021 Share #60 Posted September 2, 2021 4 hours ago, Marc B-C said: Fishing line is your friend to feed it through. Easy solution if you have some. Hey Marc, circling back to thank you for the fishing line tip. Worked 100%!!! cheers, prio 1 Link to post Share on other sites More sharing options...
