DAVIDMC100 Posted January 24, 2019 Share #1  Posted January 24, 2019 Advertisement (gone after registration) Hello all. I just ordered a CL ! I'm going to use my M lenses on it. I have  35, 50, and 90 mm Summicrons. Will the APS-C sensor size effect make them work like 47, 75 and 135 mm ? Link to post Share on other sites More sharing options...
Advertisement Posted January 24, 2019 Posted January 24, 2019 Hi DAVIDMC100, Take a look here Multiplication factor for M Lenses. I'm sure you'll find what you were looking for!
M11 for me Posted January 24, 2019 Share #2  Posted January 24, 2019 (edited) 1.5 is the multiplier. So you are right with your focal lengths. Actually you are right too with saying "make them work like". Of course the focal length of an existing lens stay unchanged. By the way 35 x 1.5 equals 53mm not 47. And note that the lenses you have are not exactly the focal length that is written on the body. It is aprox. that focal length. Edited January 24, 2019 by Alex U. 3 Link to post Share on other sites More sharing options...
ramarren Posted January 25, 2019 Share #3  Posted January 25, 2019 Yes. In effect if you want the same wide FoV as you have for an M, you'll need an additional 24mm lens. Link to post Share on other sites More sharing options...
Trivette Posted January 25, 2019 Share #4 Â Posted January 25, 2019 The crop factor (1.5 in this case) does not change the focal length, but it changes the field of view. Therefore, for example, a 35mm lens will have approximately the same field of view as a 53mm lens on a so-called "full frame" camera. 1 Link to post Share on other sites More sharing options...
jaapv Posted January 25, 2019 Share #5 Â Posted January 25, 2019 Actually it does not really change the field of view, as that depends on the subject distance. Move backwards with a cropped sensor and you'll have the same field of view, albeit with a different perspective. Sensor crop changes the angle of view. 2 Link to post Share on other sites More sharing options...
nicci78 Posted January 25, 2019 Share #6  Posted January 25, 2019 Multiple focal length and aperture x1.5 to get an idea of the lens will look like on APS-C. Field of view and depth of field wise. It is just that simple. No need to know read the scientific fine prints. Summilux-TL 1.4/35mm mounted on a CL will look like a 2,.1/53mm wide open. Close enough to a Summicron-M 2/50mm mounted on a M10. Actually almost all 50mm are 52mm, just rounded to 50mm, for marketing sake. Link to post Share on other sites More sharing options...
johntobias Posted January 25, 2019 Share #7  Posted January 25, 2019 Advertisement (gone after registration) I guess the answer is better get a w-i-d-e angle.....?21mm perhaps  Link to post Share on other sites More sharing options...
ramarren Posted January 26, 2019 Share #8  Posted January 26, 2019 15 hours ago, johntobias said: I guess the answer is better get a w-i-d-e angle.....?21mm perhaps  If you like to shoot with very wide angle lenses, 21mm isn't a particularly wide focal length on APS-C. That's why Leica makes the TL11-23mm lens for the APS-C line... 1 Link to post Share on other sites More sharing options...
lct Posted January 26, 2019 Share #9  Posted January 26, 2019 On 1/25/2019 at 4:45 PM, johntobias said: I guess the answer is better get a w-i-d-e angle.....?21mm perhaps 15mm x 1.5 = 22mm on the CL. CV 15/4.5 v2 here (Summilux 35/1.4 v2 in the background)  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/293622-multiplication-factor-for-m-lenses/?do=findComment&comment=3672141'>More sharing options...
