Csacwp Posted October 13, 2018 Share #1 Posted October 13, 2018 Advertisement (gone after registration) Does color space matter at all with the Monochrom? For example, will I notice any difference between SRGB and Adobe RGB when viewing online or printing? Link to post Share on other sites More sharing options...
Advertisement Posted October 13, 2018 Posted October 13, 2018 Hi Csacwp, Take a look here Color Space. I'm sure you'll find what you were looking for!
CharlesL Posted October 13, 2018 Share #2 Posted October 13, 2018 [Never used a Monochrom] Speaking specifically of the ABW (Advanced Black and White) mode in many Epson printers, Eric Chan - who knows his stuff - says, "the ABW driver is expecting to receive image data that is encoded with the sRGB gamma function (approximately a 2.2 gamma-encoding curve)."http://people.csail.mit.edu/ericchan/dp/Epson3800/printworkflow.html#color So generally, you want the gamma curve of your file to be what the printer expects. I believe Adobe RGB also uses a 2.2 gamma curve, but you'd need to verify that. Anecdotally, I have a monitor that can be set to AdobeRGB or sRGB, and I cannot see a difference between their displays of a black and white photo. A sepia or other tone would of course be different. Link to post Share on other sites More sharing options...
AceVentura1986 Posted October 13, 2018 Share #3 Posted October 13, 2018 Sepia, though, is actually a color image. Link to post Share on other sites More sharing options...
pgk Posted October 13, 2018 Share #4 Posted October 13, 2018 If you are shooting RAW files it doesn't matter. If you are not, then JPEGs should probably be shot as sRGB as their information is already compromised so using the larger Adobe RGB colour space seems a bit pointless, and for most uses sRGB is more appropriate for JPEGs than Adobe RGB. Link to post Share on other sites More sharing options...
250swb Posted October 18, 2018 Share #5 Posted October 18, 2018 If you are going to spend time perfecting the image in post processing use Adobe RGB because you can't add back in what you've thrown away in using sRGB later. If you are just going to make an image for instant web use it doesn't really matter. And true B&W images are ironically never the dreaded dead 'Greyscale', they have a tone because photographic emulsion has a tone, so if you want them to compete with a 'wet print' keep the image Adobe RGB to the print stage. You can always dumb the image down as a copy in sRGB for the web. Link to post Share on other sites More sharing options...
jaapv Posted November 9, 2018 Share #6 Posted November 9, 2018 Adob uses Greyscale as the colour space for Monochrom images. You can change that to any other colourspace without quality loss, as the image contains no colour information. Link to post Share on other sites More sharing options...
