Coldeye Posted May 27, 2018 Share #1 Posted May 27, 2018 Advertisement (gone after registration) Got this lens for a pretty good price online, it has a bit of the white spot problem but everything seems pristine, but I do have a few questions. I currently have a leica m240 and a leitz minolta CL for my film needs. For those who have used this lens on the M, what frameline does it bring out when mounted? I hear reports of it bringing the 35mm frame but I am not sure. Also for the CL, is the whole view of the viewfinder close enough to 28mm? Thank you all. Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2018 Posted May 27, 2018 Hi Coldeye, Take a look here Questions about Rokkor M 28mm. . I'm sure you'll find what you were looking for!
a.noctilux Posted May 27, 2018 Share #2 Posted May 27, 2018 I don't have this 28mm anymore. When I had it years ago with my CLE, if the Rokkor M 28mm was mounted on an Leica M, the framelines was 35mm. Logic things as Rokkor 40mm brings 50mm framelines, and Rokkor 90mm brings 90mm on M. Link to post Share on other sites More sharing options...
luigi bertolotti Posted May 27, 2018 Share #3 Posted May 27, 2018 I can answer only about the Viewfinder : when I used my CL, mounted on it, time to time a 28mm (the Summaron 5,6) : the VF is not large enough,so I preferred to keep with me an external : of course, is not a big difference, so one can make, with experience, a decent guessing. Link to post Share on other sites More sharing options...
Coldeye Posted May 28, 2018 Author Share #4 Posted May 28, 2018 I see. Is it like with the 40mm, shaving a tiny bit of the tab, or is it the opposite? If the CL viewfinder is about 30mm equivalent I can. Live with that. Link to post Share on other sites More sharing options...
lct Posted May 28, 2018 Share #5 Posted May 28, 2018 Yes the M-Rokkor 28/2.8 brings out 35/135 framelines on the M240. I see. Is it like with the 40mm, shaving a tiny bit of the tab, or is it the opposite? The opposite sorry. Only way would be to replace the 28/2.8's flange by that of the M-Rokkor 90/4 which brings out 28/90 framelines. Its screw holes look at the same place but i never tried to do that so far. Link to post Share on other sites More sharing options...
lct Posted October 3, 2022 Share #6 Posted October 3, 2022 On 5/28/2018 at 11:25 AM, lct said: Yes the M-Rokkor 28/2.8 brings out 35/135 framelines on the M240. The opposite sorry. Only way would be to replace the 28/2.8's flange by that of the M-Rokkor 90/4 which brings out 28/90 framelines. Its screw holes look at the same place but i never tried to do that so far. Just tried this: does not work at all. Only way to bring up 28mm framelines is to modify the 28/2.8's flange then. 2 Link to post Share on other sites More sharing options...
sinjun Posted October 4, 2022 Share #7 Posted October 4, 2022 Advertisement (gone after registration) 13 hours ago, lct said: Only way to bring up 28mm framelines is to modify the 28/2.8's flange then. I wedge the frameline selector with a bit of folded paper. Nice lens but sees less use since I got the Summaron. 1 Link to post Share on other sites More sharing options...
lct Posted October 4, 2022 Share #8 Posted October 4, 2022 2 hours ago, sinjun said: I wedge the frameline selector with a bit of folded paper [...] I should have said that the only way to bring up 28mm framelines is to modify the Rokkor 28/2.8's flange on cameras, like the OP's M240, having no frameline selector. My own copy of that lens has such a flange with 6-bit coding and it works fine on both M240 and M11 bodies. JFI. 1 Link to post Share on other sites More sharing options...
Alberti Posted October 5, 2022 Share #9 Posted October 5, 2022 Ict, does the lens still have the 35 frame? Then what is used for the code? I find that the lens needs no code to supress the smearing other 28’s have. Negligable. I heard (Will van Maanen) that a 28mm replacement bayonet is available . . But at €150_200 a bit expensive. For a lens that cost me € 350. But the quality on the M10R and M240-P is outstanding. It should be my favourate lens like the 40mm I like so much. A repair shop in the UK said they could paste a small piece of metal with dentists two-component glue to the existing flange to fill up the space to engage the 28mm frame. That should work. I’ld rather use some silver solder as glue but I’m stupid. 1 Link to post Share on other sites More sharing options...
lct Posted October 5, 2022 Share #10 Posted October 5, 2022 1 hour ago, Alberti said: Ict, does the lens still have the 35 frame? Then what is used for the code? My copy has a modified flange with 28mm frame and Elmarit 28/2.8 pre-asph's code. I don't know whom did the mod though as it is a pre-owned copy. Link to post Share on other sites More sharing options...
Alberti Posted October 12, 2022 Share #11 Posted October 12, 2022 Thanks. I found M-mount and 6-bit flanges on the net, but with 6 screw holes, but the sellers (Aliexpress) have NO IDEA for which lenses/models the flanges are . . The thickness is not universal and the hole spacings are neither. So I wonder. A custom made flange is too expensive (I once asked Skyllaney, they gave a too high quote). Link to post Share on other sites More sharing options...
lct Posted October 12, 2022 Share #12 Posted October 12, 2022 The flange of the Rokkor 40/2 for Minolta CLE is a screwing one having nothing to do with flat ones one can find on e**y or elsewhere. I could not even interchange it with that of the Rokkor 90/4. 1 Link to post Share on other sites More sharing options...
lct Posted October 12, 2022 Share #13 Posted October 12, 2022 (edited) 1 hour ago, lct said: The flange of the Rokkor 40/2 for Minolta CLE is a screwing one [...] I meant Rokkor 28/2.8 sorry. Edited October 12, 2022 by lct Link to post Share on other sites More sharing options...
