Attached DNG picture was taken by Leica Q with UV filter. Does anyone know know why there is ripple on the blue sky? Thanks in advance!
x
Looks like some kind of moiré effect. If it is not the result of posterizing in the postprocessing I can only think of ice crystals in the upper atmosphere creating a structure.
I suspect post processing rather than atmospherics as it is fairly even in its pattern. It would be interesting to know what pp was done and with what software. Is the banding in the original out of camera DNG? That is the critical question, or just in this much reduced or other processed image? I know I have induced something similar in pp in trying to boost skies. If it is in the out of camera DNG are there other images with the problem and with or without the filter? Is it just a one off?. Very difficult to offer thoughts without the OP ruling out variables and providing more information.
I’m uncertain how to meaningfully contribute to solving this, but I have a few thoughts. Is it for sure in the image? If you zoom in on your computer does it remain in the image or is it some kind of display artifact? What program processed the dng? Try a different program. 8 bit, 16 bit, 32 bit? Could it be an interference with the uv filter? Seems unlikely to me. Original image dng or jpg? If jpg, what are settings in camera for sharpness and contrast? Go shoot a clear blue sky and is it there? What about moire control on LR develop module in the adjustment brush? Does that fix it?
I’m anxious to see what the root of this is. I suspect it’s something obvious that I’m missing. Thanks for posting.
If it is a DNG, please link to a Yousendit  (or similar service) file. We can have a look then.
Or at least show us the histogram (pre and post if anything beens altered). The lack of shadow detail makes me suspect, as have others, that some PP was done and perhaps the original was under exposed. One can induce these sorts of effect bumping the exposure up, by mucking about with the individual colors which can cause clipping or what might be be compression artifacts when converting to jpg.
The banding is from original DNG. I'll try it again with out filter.
I copied the photo from SD card to laptop. And the banding can be seen when opening  it with a picture editor in Windows.
DNG or JPG?
Picture Editor in Windows? Grmpf… lol
This is not a camera / sensor "banding", this is a too small bit depth. A software or software setting problem.
William. Does your picture editor in windows have a profile for correctly processing the Leica Q DNG? I’d strongly suspect this is the problem. Find someone who has Lightroom, Photoshop, Camera Raw or Capture One and import into one of those. I bet you won’t see any weird artifacts.
