Having just now entered into the world of the little CL, I’m thinking about purchasing the APO-Macro-Elmarit-TL 60mm f/2.8 ASPH. Do any of you have experiences to share when using that lens with the CL? I live a long way from any Leica dealers, so I can’t go check out the lens myself before I purchase. As of now I only own the 18mm.
Please post a few shots.
(Until now the M has been my only serious Leica camera.)
Edited by Jeffry Abt
I like it a lot.  It's competitive with the R 100 macro and S 120 Macro, has no bad habits when used wide open, focuses fast and accurately.  It's quite a bit lighter than the TL 35/1.4, although it is about the same size.  Awesomely sharp when you are careful.  Here's an example:
24733915697_0669c0021c_o.jpgC1000596 by scott kirkpatrick, on Flickr CL 80@f/2.8 ISO 800 1/60 sec
I posted a number of images with the lens at the start of the CL image thread (around post #22), when it was my only native lens.
I use it with AF in the normal range, and manual focus for macro. It can take a lot of turning of the focus ring to shift from the normal range to macro (turning it fast is the trick, because it is non-linear focus-by-wire). This is not too much of a hardship, compared to the R and M equivalents, which all require separate adapters.
I still have just the 18 and the 60, and don't feel the need for anything else.
Edited by LocalHero1953
I bought it recently to replace the 55-135mm as a portrait lens. The 60mm is incredibly sharp, colors are gorgeous. However, it is not very fast to focus, very far cry from the 35mm. A couple days ago, I tried to use it to take pictures of a two year old in the evening, indoor, with crappy light. The lens was way too slow to focus and could not keep up with the toddler. I switched back to the 35mm and the 18mm, and things were fine. When the light is better, I have no problem focusing.
Alain
Did someone suggest that the 60 2.8 TL was sharp?
(Taken w TL2)
Edited by ropo54
Echoing the sentiments here, it is a terrific lens. Very sharp, autofocus is accurate and renders very nicely for mid-telephoto (eg portrait) work.
I have actually listed my S 120 Macro for sale as I don't see myself using it much now that I have the TL 60 Macro.
Here are some more recent sunny day outdoor shots with the CL and 60-Elmarit-TL
28294046669_719b2b081f_o.jpgC1010426 by scott kirkpatrick, on Flickr
28294039509_717b3f35a2_o.jpgC1010400 by scott kirkpatrick, on Flickr
26200482898_a8341a5380_o.jpgC1010384 by scott kirkpatrick, on Flickr
I was using f/8 and 1/250 generally, so shooting into the shade the ISOs were 1000 or 1250.
I don't see many people sharing my opinion here, but how me 60/2.8 was incredibly bad at focusing. The focus might miss and than hunt for 3 seconds (!!!) or so, without getting the job done anyway. Maybe it's the case with all macro lenses (I don't do marco and have no idea, but 8 years ago or so my cheap Sigma with macro option didn't hunt at all), or maybe it was a flawed 60/2.8, I have no idea. Here are two pictures I was able to accomplish with it though. You probably won't see the quality because I'm restricted to 500KB for both pictures, but believe me they are super sharp ;)
 I am not having any problems focusing this lens on the CL.  I use spot focus and find something with an edge or contour.  I've also used single field at times.  Of course, sometimes it takes a few tries to grab a very near object when other stuff is visible in the background, but that's true of any autofocus system.  If the AF goes off in an obviously wrong direction, I'm used to backing off the shutter and pressing again.  That seems to send it back in the other direction.  Portraits of people in a studio may demand more rapid response than I usually need, but the CL has been doing fine for me.  Its AF is great with the 23 and the 11-23,  just fine with the 60 and the 55-135.
OK so I definitely got something not working right there. When it tried to focus and missed it was super slowly moving the focus in and out for about 3 seconds without a way to stop it. So, please ignore my comment about AF and appreciate my comment on great IQ ;)
Wondering which would be the better combination for landscape + street + macro: 23mm + 60mm or 18-56mm + 60mm?
for my taste: 11-23+60   ;)
except for low light and shallow DOF in shallow places: 23/2.0
The 18-56 comes into play if you want to bring just one lens.
AF on my T and TL2 did hunt in certain conditions. First impressions with the Cl are much better.
That was my experience with the lens on the TL2. On the CL, the focus speed is an order of magnitude faster and far less/no hunting.
