M6 Recalibrating Lightmeter?
Comparing my M6 to 2 independent light meters it looks lik the M6 is under exposing by about 1 1/2 stops (against a Sekonic 18% target). When exposing film I use the handheld meter, but it would be good to have the M6 calibrated.
My question: Can the M6 Light meter be calibrated/adjusted as part of a CLA?
Hi,
I don't wish to ask the obvious, but was the ISO setting on the camera the same as on the meter?  My M6, which I bought new, is still good after 22 years.  It is the early design without the TTL facility.
Susie
Hi,
Susie
Hi,
Yes it is.
I'm interested to know if it can be calibrated during a CLA, ie is there a means of adjustment, a potentiometer for example. But what's absolute, all light meters seem to differ, if only slightly.
Steve , sorry a little late my reply
As I bought new M7 and MP I cannot answer you for the lightmeter of M but recently
Leica Wetzlar has refurbished my Leicaflex SL, they have reviewed the lighmeter
It's now fine and color (or b&w) is exactly well exposed.
You can send a message to Leica CS to have advice.
Best
Henry
Obviously the TTL light measurement circuitry is more complicated than the non-TTL.
My non-TTL M6 was serviced and adjusted by Will van Maanen just one year ago.
My advice is to ask a local (and not a Leica) repair service about the specifics for your camera.
Thank you, there's a spark of hope after all !
My 1985 M6 was serviced earlier this decade by an independent tech, who got a new replacement meter circuit board from Leica, as the old had been damaged by battery leakage. So indeed the M6 may be easier than the TTL model for parts.
I think that anyone considering an electronic M, even a relatively 'simple' one with a light meter, should be encouraged to watch the video, then the person should be pointed in the direction of an MA, or an earlier model sans electronique!
As discussed in the second link, repair costs could easily exceed the original purchase price!
Right Steve . I work during several years with my SL witout battery
battery in mercury not available . Rule f16
