Naampje Posted January 1, 2017 Share #1 Posted January 1, 2017 Advertisement (gone after registration) Dear all, This is my first post after a lot of reading and learning about the Leica M8. I tested it like members and other fora taught me but now after a few weeks I have gotten a few images with this horizontal stripe. Did I just buy a failing M8? Any advice would be really helpful. Link to post Share on other sites More sharing options...
Advertisement Posted January 1, 2017 Posted January 1, 2017 Hi Naampje, Take a look here Failing sensor?. I'm sure you'll find what you were looking for!
jaapv Posted January 1, 2017 Share #2 Posted January 1, 2017 No -this is standard M8 behaviour when you have a bright highlight precisely on the edge of the frame. You'll soon learn to avoid the situation. See the M camera FAQ at the top of the forum. 1 Link to post Share on other sites More sharing options...
Naampje Posted January 1, 2017 Author Share #3 Posted January 1, 2017 Thank you Jaap for the quick reply. Only I cannot find the FAQ about this issue. I noticed smaller more insignificant lines with the same type of 'firework' (sterretjes in Dutch as you already now) lighting. Could you refer me to the correct discussion or FAQ? Thank you. Link to post Share on other sites More sharing options...
satijntje Posted January 1, 2017 Share #4 Posted January 1, 2017 I'm also looking into this Jaap! Interesting issue as I did not know about this failure.... But I also cannot find the appropriate section where it is described..... Cheers John Link to post Share on other sites More sharing options...
jaapv Posted January 1, 2017 Share #5 Posted January 1, 2017 You're right, it isn't -it should be- Probably because this was such a well-known issue when the camera was new. Anyway, not to worry, just keep highlights away from the edge. Link to post Share on other sites More sharing options...
david strachan Posted January 1, 2017 Share #6 Posted January 1, 2017 I've had thick white lines from the edge into the image, when a bright point source is just off-frame...very occasionally. Don't recall ever having a dark line in the "middle" of the image though. I'm not disagreeing with Jaap...just my experience with two M8's. Naampje..sometimes digital images do unexplained "things". If it continues periodically perhaps try a full charged battery, and a new memory card. All best and welcome to the Forum. Link to post Share on other sites More sharing options...
jaapv Posted January 1, 2017 Share #7 Posted January 1, 2017 Advertisement (gone after registration) I refused to believe it at first too. But it can be replicated. It is normal for M8 sensors, although some cameras are more susceptible than others. Link to post Share on other sites More sharing options...
Naampje Posted January 1, 2017 Author Share #8 Posted January 1, 2017 (edited) Thanks all for the help and the welcome! I'm really happy to have bought this M8, to me as a amateur it really is such an amazing tool to have after all the lesser camera's I have had. I have bought a Summarit-M 35mm 2.5 and a Summicron-M 40mm 2.0 together with a CL, now I use mainly the Summicron. These pictures are crops from the edge and the error comes like Jaap said from the edge of the frame. Here is another example. It flares from the edge horizontally into the frame and has a straight vertical cut off at a the end. It really happened only in about 2 shots from about 600 shots taken. Edited January 1, 2017 by Naampje Link to post Share on other sites More sharing options...
jaapv Posted January 2, 2017 Share #9 Posted January 2, 2017 Same situation. What happens is that light from the highlight on the edge of the sensor gets under the light baffle that covers the reference pixels on the outside of the sensor. This messes up the readout, resulting in a green/black line over the half of the sensor that is affected. The width of the line corresponds to the size of the highlight. M8 sensors are particularly sensitive to this effect although it has been reported once or twice on the M9 sensor as well. There is some sample variation, but all M8-s can be provoked into this behaviour. As I said, absolutely nothing to worry about, there is nothing wrong with your camera. Leica is aware of the quirk and has let know that there is no remedy. Link to post Share on other sites More sharing options...
david strachan Posted January 2, 2017 Share #10 Posted January 2, 2017 (edited) I see, your second pic shows it right to the edge. I'm working on a tablet and thought the first image just showed a bar in the middle of the picture...but evidently right through to the edge. The slightest shift in perspective will stop the problem. . All best.. Edited January 2, 2017 by david strachan Link to post Share on other sites More sharing options...
satijntje Posted January 4, 2017 Share #11 Posted January 4, 2017 It really happened only in about 2 shots from about 600 shots taken. I have made well over 10.000 pics with several M8*s and I have never seen this on a single picture! Strange, but I believe of course Jaap's explanation. John Link to post Share on other sites More sharing options...
Naampje Posted January 4, 2017 Author Share #12 Posted January 4, 2017 It all happened with the same lens the Summicron-C 40mm which is prone to flare (they say). Could that add to the equation? Flaring? And John, it only happened during Christmas and new years, just avoid shooting this time of year or near Christmas trees and fireworks Jaap, thanks again for your contribution, I have read many of your answer here on these fora, you know your stuff! With all the people running around screaming about the inevitable failure of anything M8/9 it's nice to read some reassurement Link to post Share on other sites More sharing options...
jdlaing Posted January 5, 2017 Share #13 Posted January 5, 2017 It's from the bright candle light source. Not flaring. The photo is underexposed making it worse. 1 Link to post Share on other sites More sharing options...
Jeff S Posted January 5, 2017 Share #14 Posted January 5, 2017 Same situation. What happens is that light from the highlight on the edge of the sensor gets under the light baffle that covers the reference pixels on the outside of the sensor. This messes up the readout, resulting in a green/black line over the half of the sensor that is affected. The width of the line corresponds to the size of the highlight. M8 sensors are particularly sensitive to this effect although it has been reported once or twice on the M9 sensor as well. There is some sample variation, but all M8-s can be provoked into this behaviour. As I said, absolutely nothing to worry about, there is nothing wrong with your camera. Leica is aware of the quirk and has let know that there is no remedy. Reads like a nice FAQ post! Jeff Link to post Share on other sites More sharing options...
Cris.Huang Posted April 7, 2024 Share #15 Posted April 7, 2024 2017 年 1 月 2 日凌晨 3:33,Naampje 说: 尊敬的各位: 这是我在大量阅读和了解徕卡 M8 后的第一篇文章。 我像会员和其他论坛一样测试了它,但现在几周后,我得到了一些带有这种水平条纹的图像。 我刚刚买了一辆失败的 M8 吗? http://i63.tinypic.com/opvfht.jpg 任何建议都会很有帮助。 我很抱歉再次提起这个话题。由于附件中的图片早已不复存在,因此我最近似乎遇到了同样的问题。我希望我能从你们那里得到一些答案。 Link to post Share on other sites More sharing options...
Ernstk Posted April 7, 2024 Share #16 Posted April 7, 2024 2 hours ago, Cris.Huang said: 我很抱歉再次提起这个话题。由于附件中的图片早已不复存在,因此我最近似乎遇到了同样的问题。我希望我能从你们那里得到一些答案。 Welcome to the forum. Could you post your message in English please? Ernst Link to post Share on other sites More sharing options...
jdlaing Posted April 8, 2024 Share #17 Posted April 8, 2024 15 hours ago, Ernstk said: Welcome to the forum. Could you post your message in English please? Ernst “I apologize for bringing this topic up again. I seem to be having the same problem lately since the attached picture is long gone. I was hoping I could get some answers from you guys.” 1 Link to post Share on other sites More sharing options...
lct Posted April 8, 2024 Share #18 Posted April 8, 2024 22 hours ago, Cris.Huang said: 我很抱歉再次提起这个话题。由于附件中的图片早已不复存在,因此我最近似乎遇到了同样的问题。我希望我能从你们那里得到一些答案。 Show your pictures please. Link to post Share on other sites More sharing options...
Cris.Huang Posted April 8, 2024 Share #19 Posted April 8, 2024 3 hours ago, lct said: Show your pictures please. Firstly, thank you for your reply, as you can see, you've most likely seen it in another one of my threads Link to post Share on other sites More sharing options...
