Joakim Posted November 28, 2016 Share #1 Posted November 28, 2016 Advertisement (gone after registration) Hi I recently managed to damage my Gitzo tripod and while I can fix it with some duck tape short term I need to start looking for a new one. My existing one is from the Gitzo 3-series and I am looking for something similiar, carbon fiber with a good max height (I am 181cm), nothing to monstrous but stabble enough for using for lanscape shooting with my S-006. What are you guys using and what do you recomend? I'm not in a hurry but I would appretiate som input, I've been looking at the RRS tripods but i am not sure about availability here in Eureop or if I must by from the US. Cheers, Joakim Link to post Share on other sites More sharing options...
Advertisement Posted November 28, 2016 Posted November 28, 2016 Hi Joakim, Take a look here Tripod for S . I'm sure you'll find what you were looking for!
LorenzoLandini Posted November 28, 2016 Share #2 Posted November 28, 2016 Joakim, With my S006 (as well as with a Linhof 4x5) I use a Gitzo GT5562LTS with an Arca Swiss Cube. It's on the heavy (and expensive) side and the tripod height is only approx 150cm (+10cm for the cube) and it might not be the right set up for you. My rational was to have a tripod that could fit in a luggage (including cabin luggage if needed), but extremely sturdy to support the S or the view camera in windy conditions and with longer lenses as needed. The 6-leg tripod allows for a "compact" closed tripod while the size of a 5-series off-set the lost in sturdiness of a 6-leg over a 3 or 4-leg tripod. Overall quite happy with it. Probably an overkill. The main downside is the weight of the overall set up, partially because of the cube which is a brick. However, it is very firm and sturdy, compact and with the cube I have extreme control of leveling and framing. Horse for courses. cheers, Lorenzo Link to post Share on other sites More sharing options...
djmay Posted November 28, 2016 Share #3 Posted November 28, 2016 I have used a Berlebach wooden tripod, with leveling ball and extension column, with my view cameras for years. I continue to use it with the S. It is not as compact as a carbon fibre tripod, but the weight and load capacity are about the same. Wood also withstands impact and crush forces a little better, and the cost of replacement when that accident happens, is lower. It is also a conversation piece Jesse Link to post Share on other sites More sharing options...
albertknappmd Posted November 28, 2016 Share #4 Posted November 28, 2016 RRS tripods are fantastic.. You can only buy directly from them.. I have the TVC-34 and the BH-55 ball head.. http://www.reallyrightstuff.com/Heads/Ballheads?_ga=1.46948775.1282328884.1462198895 Albert Link to post Share on other sites More sharing options...
LocalHero1953 Posted November 28, 2016 Share #5 Posted November 28, 2016 RRS tripods are fantastic.. You can only buy directly from them.. I have the TVC-34 and the BH-55 ball head.. http://www.reallyrightstuff.com/Heads/Ballheads?_ga=1.46948775.1282328884.1462198895 Albert Google is your friend. I have just bought a RRS plate from https://www.augenblicke-eingefangen.de/catalog/index.php?manufacturers_id=29. These people also appear to be European agents: http://www.cameranu.nl/c19892/statieven-en-toebehoren/really-right-stuff. Link to post Share on other sites More sharing options...
Jeff S Posted November 28, 2016 Share #6 Posted November 28, 2016 I prefer the RRS TVC 24-L for bigger systems like the S..... extends higher, weighs less and folds almost as small as the TVC-34 ....along with BH-55. Jeff Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted November 28, 2016 Share #7 Posted November 28, 2016 Advertisement (gone after registration) I no longer worry about buying super expensive tripod legs. My Sirui legs get me to eye height without the centre column and are as stable as I could want. Then I just put a top end head on, which I think is much more important as even the Chinese carbon legs are now excellent. I love my D4 geared head which I use with a nodal slider to get better balance. Gordon Link to post Share on other sites More sharing options...
djmay Posted November 29, 2016 Share #8 Posted November 29, 2016 I no longer worry about buying super expensive tripod legs. My Sirui legs get me to eye height without the centre column and are as stable as I could want. Then I just put a top end head on, which I think is much more important as even the Chinese carbon legs are now excellent. I love my D4 geared head which I use with a nodal slider to get better balance. Gordon Good suggestion for me to think about when I want to use something more compact. What model are you using? Jesse Sent from my GT-I9195 using Tapatalk Link to post Share on other sites More sharing options...
Bill W Posted November 30, 2016 Share #9 Posted November 30, 2016 I use a Gitzo 1228 Mk2 as my compact tripod. They are no longer made but can be bought off ebay. I am 6'3" and find it is adequate for my needs. I use a RRS BH40 head. There are those that will say this setup is too light for the S007 but I disagree. My longest S lens is the 100. I am sure it might not be as stable with a 180 attached but I do not own one. Link to post Share on other sites More sharing options...
mgrayson3 Posted November 30, 2016 Share #10 Posted November 30, 2016 I have a tall tripod - a four section Gitzo 3-series. It's not as tall as the Giant, but it goes way over my head. What's the point? Uneven terrain. It's Great to be able to stick a leg downhill or to the ground from a wall, or brace against a tree too far away. I use that fourth section more than I expected. Well, with the S, I carry a monopod on most walks, but if I need slow shutter speeds, I'm taking the tall tripod. --Matt Link to post Share on other sites More sharing options...
RVB Posted November 30, 2016 Share #11 Posted November 30, 2016 Hi I recently managed to damage my Gitzo tripod and while I can fix it with some duck tape short term I need to start looking for a new one. My existing one is from the Gitzo 3-series and I am looking for something similiar, carbon fiber with a good max height (I am 181cm), nothing to monstrous but stabble enough for using for lanscape shooting with my S-006. What are you guys using and what do you recomend? I'm not in a hurry but I would appretiate som input, I've been looking at the RRS tripods but i am not sure about availability here in Eureop or if I must by from the US. Cheers, Joakim RRS ship everywhere, they're really good quality, the TVC 24 version is light and stiff enough for the S system, I use one with a cube, I also have a TVC-34 which is heavier but I use its less. If you want top buy in Europe Nivo Schweitzer in Amsterdam sell RRS!! Here is the link http://www.nivo-schweitzer.nl Link to post Share on other sites More sharing options...
Joakim Posted November 30, 2016 Author Share #12 Posted November 30, 2016 Thanks for all replies and suggestions, I think I will look closer at the RRS TVC 24 but also check what Sirui has to offer. Link to post Share on other sites More sharing options...
Jeff S Posted November 30, 2016 Share #13 Posted November 30, 2016 Thanks for all replies and suggestions, I think I will look closer at the RRS TVC 24 but also check what Sirui has to offer. I prefer the taller TVC 24-L (16+" potential, yet only 4" add'l collapsed height). Jeff Link to post Share on other sites More sharing options...
RVB Posted November 30, 2016 Share #14 Posted November 30, 2016 I prefer the taller TVC 24-L (16+" potential, yet only 4" add'l collapsed height). Jeff TVC 23 is also worth looking at, less sections make it lighter and stiffer, I also have TQC 14 and its surprisingly good for its low weight and small size. Link to post Share on other sites More sharing options...
Jeff S Posted November 30, 2016 Share #15 Posted November 30, 2016 TVC 23 is also worth looking at, less sections make it lighter and stiffer, I also have TQC 14 and its surprisingly good for its low weight and small size. I also have the TQC-14, which I use for smaller systems (e.g., M) and for travel....great small tripod. The TVC-24L serves when significantly more height is desired, which the TVC 23 doesn't provide (hence less sections). And I have the tiny Leica tabletop pod....from many decades ago. I don't use tripods as much as in my film days, but in retirement these 3 are all I'll ever need....and probably more. Whatever works. Jeff Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 1, 2016 Share #16 Posted December 1, 2016 Gitzo Mountianier long with a Manikin Head....................fantastic fantastic fantastic.....................I was luck I had the chance to try 3 Gitzo tripods and the mountaineer was bar far the sturdier of the three abd it just feeks solid. @Jeff recommended the RRS ones before but living in Malaysia you cant get them on the street you have to buy online so you don't get to try first. I had the B55 head and sold it as its just too frigging heavy............fantastic head but heavy Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 1, 2016 Share #17 Posted December 1, 2016 I use a Gitzo 1228 Mk2 as my compact tripod. They are no longer made but can be bought off ebay. I am 6'3" and find it is adequate for my needs. I use a RRS BH40 head. There are those that will say this setup is too light for the S007 but I disagree. My longest S lens is the 100. I am sure it might not be as stable with a 180 attached but I do not own one. Too light, and flilmsy legs Link to post Share on other sites More sharing options...
Guest NEIL-D-WILLIAMS Posted December 1, 2016 Share #18 Posted December 1, 2016 And I have the tiny Leica tabletop pod....from many decades ago. Jeff Jeff Jeff...I bought one of those a year ago...............I love it, it goes with me everywhere...fits in the Harley Pro bag at the back Link to post Share on other sites More sharing options...
xiaubauu2009 Posted December 1, 2016 Share #19 Posted December 1, 2016 RRS TVC-24L with Linhof 3D Micro levelling head.... I do mainly landscape/cityscape/architecture, so levelling is important... Link to post Share on other sites More sharing options...
Jeff S Posted December 1, 2016 Share #20 Posted December 1, 2016 RRS also makes a nice leveling plate for their heads. Jeff Link to post Share on other sites More sharing options...
