I am wondering whether the top plate can be replaced easily. If yes, then I can use personalized top plate for my usage and replace the original one if planning to sell at later date.
Really great job on engraving btw. Can't believe it is done by hand.
Edited by jmahto
Thank you all :)  It's too risky to do as a side business. There's no way to fix a slip when you're engraving through black paint, and it takes so long it would cost too much. The right person with a pantograph could probably do it.
If that was done freehand without  pantograph, it is truly amazing.  I have a very steady hand but even if I was following a stencil and tape lines I doubt I could get that kind of a machined look, especially where depth is concerned.  Kudos!
Yes, it's done freehand under stereo microscope. I made a special rounded graver of the appropriate size to replicate a machine made cut. I used Adobe Illustrator and traced the lettering from a high resolution photo of an engraved Leica top plate. I printed it on a transparency sheet and transferred it to my camera. From that point it was meticulous hand cutting of each letter, being extremely careful not to damage the surrounding black paint as there's no way to repair it.
  • 3 weeks later...
  • 2 months later...
  • 2 years later...
