Feudal1 Posted December 22, 2015 Share #1 Posted December 22, 2015 Advertisement (gone after registration) It's a pretty modest set of improvements, but the "improvement of image quality in lower ISO settings" is interesting. I haven't installed it to my Q just yet, but will do so shortly. It's available here: https://us.leica-camera.com/Service-Support/Support/Downloads?category=124335&subcategory=&type=&language=93871 Version 1.1 Performance Improvements: - Improvement of the image quality in lower ISO settings Bug Fixes: - Exposure has been corrected in digiscoping mode after switching off and on again. - Improvement of the Live View in monochrome mode in combination with AF tracking. After installation of the new firmware the Live View now shows a monochrome image. For proper focusing the camera switches to color when pressing the shutter button half way. Link to post Share on other sites More sharing options...
Advertisement Posted December 22, 2015 Posted December 22, 2015 Hi Feudal1, Take a look here Leica Q Firmware 1.1 has been released . I'm sure you'll find what you were looking for!
alexander Posted December 22, 2015 Share #2 Posted December 22, 2015 hello, will wifi work after update? with the T there were problems.... Link to post Share on other sites More sharing options...
biglouis Posted December 22, 2015 Share #3 Posted December 22, 2015 Not exactly a breathtaking set of improvements, is it? LouisB Link to post Share on other sites More sharing options...
katsanes Posted December 22, 2015 Share #4 Posted December 22, 2015 Not exactly a breathtaking set of improvements, is it? LouisB Right!? I'd rather get a much more exciting FW in January if only we had to wait a little longer... Link to post Share on other sites More sharing options...
biglouis Posted December 22, 2015 Share #5 Posted December 22, 2015 Leica are always notoriously slow about any kind of firmware improvements. LouisB PS It's now installed so at least that doesn't appear to create any problems. Link to post Share on other sites More sharing options...
katsanes Posted December 22, 2015 Share #6 Posted December 22, 2015 Well - I just actually did the upgrade and had a minor but briefly frightening experience. After the camera said "Firmware has been updated, turn the camera off" I did, but then it wouldn't turn back on. After a very minor heart attack I picked myself off the floor and pulled out the battery. That did the trick! The camera powered back on just fine, but I am assuming this isn't normal, I lost all my settings and had to reprogram. All seems well now though. Link to post Share on other sites More sharing options...
Fotomaschine Posted December 22, 2015 Share #7 Posted December 22, 2015 Advertisement (gone after registration) Did they adress the banding issue in the low ISO-range (enhance lattitude in deep shadows)? Not sure what to make out of "Improvement of the image quality in lower ISO settings". Thanks a lot! Link to post Share on other sites More sharing options...
kmak817 Posted December 22, 2015 Share #8 Posted December 22, 2015 Ok for a technology luddite such as me, these installation instructions are troublesome; Firmware Update Procedure 1. Download an updated version of the firmware. 2. Copy the firmware file onto a SD Memory Card in its top level folder. 3. Make sure to turn off the power switch on the camera. 4. Insert the fully charged battery to the body. If the battery is not fully charged, the update process screen will not appear. 5. Insert the SD Memory Card into the camera. 6. Turn the camera – while simultaneously pressing the video release button – on. 7. The firmware update screen will appear. Press OK. 8. The LEICA Q will start the update process. The firmware update will take about 90 seconds. How do I copy the file onto an SD memory card in its top level folder? Thanks for any help. Link to post Share on other sites More sharing options...
katsanes Posted December 22, 2015 Share #9 Posted December 22, 2015 You have to mount the SD card in your computer, then drop the FW file at the root of the drive, not in a folder basically. Link to post Share on other sites More sharing options...
pop Posted December 22, 2015 Share #10 Posted December 22, 2015 Ok for a technology luddite such as me, these installation instructions are troublesome; (...) How do I copy the file onto an SD memory card in its top level folder? What kind of computer do you use and do you happen to know what kind of operating system it runs? Link to post Share on other sites More sharing options...
kmak817 Posted December 22, 2015 Share #11 Posted December 22, 2015 You have to mount the SD card in your computer, then drop the FW file at the root of the drive, not in a folder basically. And how do I mount the SD card in my computer? Link to post Share on other sites More sharing options...
katsanes Posted December 22, 2015 Share #12 Posted December 22, 2015 You will need an SD card reader attached by USB (usually). If you happen to have a Mac, often times they have an SD card reader built-in, many laptop PCs do as well. For the record, and SD card reader is the best way to get the photos from your camera to your computer, it's much faster and less prone to issues. Link to post Share on other sites More sharing options...
stantius Posted December 22, 2015 Share #13 Posted December 22, 2015 I have installed the new version and taken some test shots. I think I can see some improvement (it could just be wishful thinking). There still is some banding, but the lines look more straight and it's almost gone with noise reduction level set to about 70 in LR. Images can be found here, manipulated to show potential banding (mainly by setting shadows +100) You can find the RAW files here: https://drive.google.com/folderview?id=0Bw1KEWYgvbB2WUY3N3JLZjJIWjg&usp=sharing Link to post Share on other sites More sharing options...
Fotomaschine Posted December 22, 2015 Share #14 Posted December 22, 2015 Could you post some severely underexposed ISO100 shots? Thank you! Link to post Share on other sites More sharing options...
stantius Posted December 22, 2015 Share #15 Posted December 22, 2015 hello, will wifi work after update? with the T there were problems.... WiFi still works with my Android phone Link to post Share on other sites More sharing options...
Fotomaschine Posted December 22, 2015 Share #16 Posted December 22, 2015 Sorry for the double post: As far as I can say, there is no improvement in the high ISO-range which is supported by the firmware read-me file. I'm very curious about the low ISO-range and the deep-shadow banding. Link to post Share on other sites More sharing options...
stantius Posted December 22, 2015 Share #17 Posted December 22, 2015 One severely underexposed ISO100 image added to both albums. JPG: Exposure +5, shadows +100 Link to post Share on other sites More sharing options...
Fotomaschine Posted December 22, 2015 Share #18 Posted December 22, 2015 Obviously, the banding is still there. Too bad. I'm wondering what Leica did improve in the low ISO-range then? Link to post Share on other sites More sharing options...
barjohn Posted December 22, 2015 Share #19 Posted December 22, 2015 Seems strange they fixed something (?) no one was complaining about and didn't address any of the issues in the firmware upgrade wish list. Link to post Share on other sites More sharing options...
alexander Posted December 22, 2015 Share #20 Posted December 22, 2015 Wifi works with iOS as well! Link to post Share on other sites More sharing options...
