andybarton Posted April 25, 2015 Share #1  Posted April 25, 2015 Advertisement (gone after registration) I have searched the forum but can't find anything, so please forgive this request for ancient news.  I have three M lenses. One is 6-bit coded and my 24mm Elmarit-M takes a standard 6 screw replacement. I have found one from HK on ebay.  However, my 50mm has a different screw pattern and I can't find a replacement codeable mount anywhere. Any ideas?  Thanks  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/244231-6-bit-replacement-mount-for-1973-50mm-summicron/?do=findComment&comment=2804857'>More sharing options...
Advertisement Posted April 25, 2015 Posted April 25, 2015 Hi andybarton, Take a look here 6-bit replacement mount for 1973 50mm Summicron. I'm sure you'll find what you were looking for!
jdlaing Posted April 25, 2015 Share #2 Â Posted April 25, 2015 You may try to send jinfinance an email and see if they can get or make one. Link to post Share on other sites More sharing options...
andybarton Posted April 25, 2015 Author Share #3 Â Posted April 25, 2015 Thanks. That's where the other mount is coming from. Â This is an unusual mount. I don't know how many other lenses use it. Link to post Share on other sites More sharing options...
jaapv Posted April 25, 2015 Share #4  Posted April 25, 2015 Why don’t you have the original mount coded by for instance Will van Manen? Link to post Share on other sites More sharing options...
lct Posted April 25, 2015 Share #5  Posted April 25, 2015 Hi Andy, If your 50 is a Summicron 11817, it can be updated by Leica AFAIK. Otherwise, 5-holes flanges ar not easy to find out i've been told. Amazon invites clients to contact them in advance here: http://tinyurl.com/k2bbqy7. Beware that the M240 does not like much replacement mounts though and the latters don't have recessed parts for focussing generally. I would check if your original mount has such a recessed part to be sure. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/244231-6-bit-replacement-mount-for-1973-50mm-summicron/?do=findComment&comment=2804965'>More sharing options...
bocaburger Posted April 26, 2015 Share #6  Posted April 26, 2015 I don't bother with coding on lenses longer than 35mm, but my pre-ASPH 21mm has that type of flange. I hand-cut dimples for the black coding and filled the screw head with flat white enamel. Works like a charm. Link to post Share on other sites More sharing options...
andybarton Posted April 26, 2015 Author Share #7 Â Posted April 26, 2015 Advertisement (gone after registration) Beware that the M240 does not like much replacement mounts though and the latters don't have recessed parts for focussing generally. I would check if your original mount has such a recessed part to be sure. Thanks LCT. The mount that will come from HK only cost <$20, so it's not the end of the world if it doesn't work. Â The one on the 1973 50mm doesn't have the groove that your example on the left shows. Â I only want to code the 50 for EXIF purposes, as I know that the vignette adjustments in-camera are only really needed for wider than 35s. Link to post Share on other sites More sharing options...
andybarton Posted April 26, 2015 Author Share #8  Posted April 26, 2015 Perhaps it's an excuse to save up for a new lens  Or code the 1963 version that I have that does have six screws... Link to post Share on other sites More sharing options...
gvaliquette Posted April 28, 2015 Share #9  Posted April 28, 2015 My problem with non-coded lenses is that I identify them manually in the menu, and then change the lens for a coded lens and forget to reset the menu to "auto". My Tele-Elmarit 90mm is not coded, but my Elmar-M 24mm is. So I shoot with the Elmar-M and the camera thinks that I still have the Tele-Elmarit. Drives me crazy!  Guy Link to post Share on other sites More sharing options...
TomB_tx Posted April 28, 2015 Share #10 Â Posted April 28, 2015 I've never found a replacement flange that actually fits my '69 11817, but the coding I put on with the M-coder still works fine, even though one screw is in the codign area. I coded it a few years ago and it hasn't worn off. Link to post Share on other sites More sharing options...
