Splashproof ?
dashone
I do worry about water making its way through the lens mount.
I don't. The tollerances are so tight and the grease is good. Als long as you don't throw it into a bucket of water , it will be o.k.
I always dry it with a cloth afterwards, just to clean the lens .( getting no chalk stains )
Don't taking it diving, or swimming, or white water rafting, but I guess using it in the rain shouldn't be a problem.
Actually , I took my M6 traveller with summicon 50 about 2 meter underwater during a survival trip. But it was in a pelicase..:D . Rain was never a problem without a peli. The only trouble I had was with a Elmar collapsable.
Even the non-weatherproofed M8 and M9 could handle an impressive amount of water. There have been a surprising number of M8 and M9 cameras dunked without adverse effects. I have had an M8 sitting in a puddle of water during a sudden wave swamping an open boat, it survived, my M9 got hit by a tropical downpour in the rainforest an only suffered a fogged-up viewfinder for a couple of hours.
Now that the M240 is officially weathersealed I see no problem at all.
A couple of weeks ago, my M240 and 75/2 stood in moderate rain for 10 mins without any adverse effect.
... then it started pouring; I decided that "splash resistant" does not sound much like "cats and dogs resistant" :rolleyes:, and put the camera back in the bag.
The only thing that is probably not as splash proof is the lens to camera mount. You can put a rubber band around there if rain is going to be a constant issue. I always leave the cover for the EVF on my M240.
"Splashproof' is usually defined by an IP rating. If there isn't one (I can't find one for the M240 from Leica) then the design is probably intended to be 'splashproof' but has not been tested nor rated to a known requirement - but if is stated to be splashproof then this should be defined. If anyone can find one for the M240 it will be easy to find out what it means and what tests have been applied - though to be perfectly honest often they are static tests and as such I feel that they have rather doubtful 'real world' relevance. If there isn't one then assume that it shouldn't get too wet;):( whatever that may mean.
I sell underwater housings which are 'waterproof' to 80m (ie 9 bar) - this means that they will not allow any ingress of water at the stated water pressure. Much easier to define, though rather harder to achieve.
The same as with watches: waterresistant 30 meter = shower proof ,100 meter = swimming, 200 meter = diving, 300/ 1000 meter pro diving. I do not know where the 2000m watches can go...
That Splashproof, with 15mm.
Regards,
Edgard
