cirke Posted November 22, 2014 Author Share #41 Posted November 22, 2014 Advertisement (gone after registration) This answer from Metz Thank you very much for your e-mail enquiry of 30 October 2014 and your interest in our products. Unfortunately, flash units of type mecablitz 64 AF-1 digital and mecablitz 26 AF-1 digital are NOT suitable for Leica digital cameras of M-series, e.g. Leica M (type M 240). For the mentioned digital camera "Leica M" (M 240) we may recommend you the flash unit "mecablitz 76 MZ-5 digital" (Metz article number 007625204) of our current product range: Description du produit: Metz For connecting the flash unit mecablitz 76 MZ-5 digital to digital cameras of Leica M series (e.g. Leica M 240) we recommend you to use an adapter "SCA 3502M5" (Metz article number 00033502A). Other suitable dedicated system flash units or SCA flash units are not available in our current product range for running with the digital cameras of Leica M series. Alternatively we may recommend you also so-called "Automatic flash units" (with so-called automatic flash control mode A) for running with digital camera "Leica M": "mecablitz 20 C-2" (Metz article number 002022090): Description du produit: Metz "mecablitz 36 C-2" (Metz article number 003622092): Description du produit: Metz These flash units are equipped with only a centre contact in connecting foot. By this centre contact it's only possible to release the flash unit by the camera. Special flash functions are not available. The flash units are equipped with a built-in light sensor for controlling the light output intensity of flash light. However, the settings for ISO and aperture (f-stop) have to be done manually on flash unit. For more information to the above mentioned flash units the multilingual instruction manuals are ready for download on our web site: mecablitz: Metz However, we may also recommend you the following special Leica flash units for the digital camera "Leica M 240". "Leica SF24D": Flash SF24D // Flash // Équipement // LEICA M // Photographie - Leica Camera AG "Leica SF-26": SF 26 flash // Technical Equipment for Leica T // Leica T // Photography - Leica Camera AG "Leica SF58": FLASH SF58 // Flash // Équipement // LEICA M // Photographie - Leica Camera AG We hope this information has been of help for you and remain With kind regards Wolfgang Becker Technical Support _____________________________________________ Metz-Werke GmbH & Co KG Ohmstraße 55, D-90513 Zirndorf Link to post Share on other sites More sharing options...
Advertisement Posted November 22, 2014 Posted November 22, 2014 Hi cirke, Take a look here flash for M240 {merged}. I'm sure you'll find what you were looking for!
bab Posted November 22, 2014 Share #42 Posted November 22, 2014 Use a Oly fl flash works perfect! I added from cowboy studios a wireless (maybe) 30.00 I can remember but works great off camera. With the oly fl you only need about a quarter or lees power indoors in a darkish room at 8 feet so the recycle time is very fast and you can shoot 400 or so images on one set of dbl aa's. If someone now makes a twin hot shoe that would be nice to use the evf and the transmitter mounted on the body. Link to post Share on other sites More sharing options...
AlanJW Posted November 23, 2014 Share #43 Posted November 23, 2014 The SF26 flash output can be controlled from the M(240). It is not as precise as a SF58, but it does work. Set a shutter speed so you are not operating in "A" mode. Set exposure compensation on the camera's menu. You will see that the shutter speed will not change (of course, it is set manually) and with a constant f/stop the light output of the SF26 can be varied. I know it is not perfect. But the great limitation of the SF24D was no bounce flash unless you attached it via a flash extension cord and handheld it. Not perfect either. In my view direct flash is often quite horrible, especially with people shots, so the SF26 is an improvement. Why Leica has not explained how to use this flash on M digitals is a mystery. They could easily release something on their website instead of making us wonder. Link to post Share on other sites More sharing options...
cirke Posted December 15, 2014 Author Share #44 Posted December 15, 2014 HSS is working with SF 58 and M240 ? Link to post Share on other sites More sharing options...
rramesh Posted January 2, 2015 Share #45 Posted January 2, 2015 Then why does Metz mention Leica support on this page? https://www.metz.de/en/lighting/flash-units/system-flash-units/mecablitz-26-af-1-digital/data-sheet/mecablitz-26-af-1-digital-olympus.html Link to post Share on other sites More sharing options...
jaapv Posted January 2, 2015 Share #46 Posted January 2, 2015 If it supports Olympus it will support certain Leica cameras like the Digilux2. The flash will probably have limited functionality on most Leicas. Link to post Share on other sites More sharing options...
MikeyK Posted January 2, 2015 Share #47 Posted January 2, 2015 Advertisement (gone after registration) I have just received the little Metz 26 AF (olympus/panasonic/leica - according to BHPhoto) , but TTL doesn't seem to work at all. Does anyone know if I can get this flash to work with the M240? The pin configuration seems different and I'm guessing the TTL is therefore not possible. Is there an adapter hotshoe, that could convert from the Leica hotshoe dots to the flash foot pins? That could be a great little gadget as you could then presumably use any combo of flash with that metz pin configuration? Perhaps I'll have to ebay the Metz 26 and stomach three times higher price for the Leica SF26 (the same flash made by Metz but with the Leica badge which I'll have to tape over). Link to post Share on other sites More sharing options...
jaapv Posted January 2, 2015 Share #48 Posted January 2, 2015 Not on TTL. You need to use "A". The only flashes that can fully handle M-TTL are the Leica flashes SF 24 and SF 58. It is by no means certain that the SF 26 flash will work fully on an M camera, as it is configured for the Leica T. Link to post Share on other sites More sharing options...
masjah Posted January 2, 2015 Share #49 Posted January 2, 2015 I think I'm right in saying that the appropriate SCA system version for Panasonic clone Leicas is different from the Leica M version (which latter is SCA 3502). It looks as if this flash comes in different models with the relevant SCA adapter integral to each, rather than being, as with the older Metz units, a generic flash unit with a separate (and therefore exchangeable) SCA adapter added on. So I fear you may be stuck! Link to post Share on other sites More sharing options...
jaapv Posted January 2, 2015 Share #50 Posted January 2, 2015 Even the SCA adapter will not support M-TTL. Link to post Share on other sites More sharing options...
freitz Posted January 2, 2015 Share #51 Posted January 2, 2015 To the OP. I tried the SF26 and SF24D and ended up with the SF 24D. I found the controls on the 26 to be very limiting as if it was designed for the Leica T rather than the M. Link to post Share on other sites More sharing options...
fore Posted January 9, 2015 Share #52 Posted January 9, 2015 So from reading this, it seems it's best just to use the Leica branded flash for a full functioning flash..a-priority to manual for instance? Can I use a trigger with these so I can use my Canon flashes for a multi-flash setup? Link to post Share on other sites More sharing options...
jip Posted January 9, 2015 Share #53 Posted January 9, 2015 HSS is working with SF 58 and M240 ? Yes HSS with the SF58 is supported with the M240. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted January 9, 2015 Share #54 Posted January 9, 2015 So from reading this, it seems it's best just to use the Leica branded flash for a full functioning flash..a-priority to manual for instance? Can I use a trigger with these so I can use my Canon flashes for a multi-flash setup? Difficult with Canon as they don't have a manual receiver built in. The appropriate Canon adaptor, like the STE3, con fire them as manual guns but you'll need to change power at each gun. You could also use a system like the pocket wizards or Cactus trigers where each flash sits on a receiver to trigger. It can work but it's a cludge. Personally I just use an Elinchrom ranger system for off camera flash, with a skyport, and a Leica 58 for TTL. Gordon Link to post Share on other sites More sharing options...
jrp Posted January 25, 2015 Share #55 Posted January 25, 2015 What else can one connect to the SCA port of the multifunction grip on the m240, if one wants full functionality? Paying £900 for the SF58+bar with chord seems excessive, even for Leica, particularly when Metz seems to be bust, so it seems unwise to count on longer-term support / compatibility. Link to post Share on other sites More sharing options...
flyalf Posted February 14, 2017 Share #56 Posted February 14, 2017 Not on TTL. You need to use "A". The only flashes that can fully handle M-TTL are the Leica flashes SF 24 and SF 58. It is by no means certain that the SF 26 flash will work fully on an M camera, as it is configured for the Leica T. Thanks! Do you, or any other know if (the new?) SF-40 can "fully handle" M-TTL on M-240? According to this site it should: http://leicastoremiami.com/products/leica-sf-40-flash Btw; its a bit annoying that the Leica site cannot provide this information, http://us.leica-camera.com/Photography/Leica-S/Technical-Equipment/SF-40-flash. Link to post Share on other sites More sharing options...
