Problem with 50mm lens?
jeffnesh
Hi All,
I just picked up a used 50mm Summicron-M for my M240. I suspect a problem with the lens, but only have the one, so can't try another on the M240.
Anything shot in mixed light (outside or even inside as seen in one example) shows a 'wash out' in the center of the frame, upper half or so. These outdoors examples are in thick cloud cover, so no direct sun...could it be a bad flare anyway (shot with hood pulled out)? Sometimes it's subtle, sometimes very pronounced. The indoor example is in a warehouse room with light coming in a window.
Thoughts on the cause of this?
Thanks for your time,
Jeff
Have you checked that all the surfaces of the glass are clean? Could be caused by a smudge or similar causing some flare?
Is it your only lens for the M, or your only 50? Have you confirmed that the problem is not caused by the sensor itself?
Thanks for the response. It is the only lens I currently have for the M, so can't try another. I've cleaned the lens and it looks okay. It doesn't seem to be completely consistent (thus suspecting the lens), but I'll try some controlled shots indoors and see if anything leads me suspect the sensor.
Just wondering if anyone else has seen such a thing...
Thanks,
Jeff
Do the torch test: take a torchlight and shine it through the lens, you will get a pretty decent idea of the status of the innards. Fog, dust, fungus et al
That means take a small pen light or keychain light and shine thru one side while looking inside the other, then reverse.
If you see fog, grime, scratches, spider fungus, the lens is defective. The lens needs to be clear.
This test should be done on all lenses before purchase.
That's my main lens - no way would a bit of overcast weather effect shot #1 so dramatically with or without a hood
Find a good lens tech and have it serviced, should be about $100 USD, not bad - cuz when that lens is clean, you'll love it!
To me, the best 50 M mount ever. (Lux's are too heavy for all day and its very tough to take advantage of the razor thin DOF @ 1.4)
Congratulations—you just found out why many Leica M users don't like the Summicron-M 50 mm.
It's small, it's sharp, it has virtually no distortion at all, it's a great little lens ... except for this tendency to wash out in back-light situations (on film it used to be less pronounced). There is nothing you, or Leica Customer Care, can do about it. If you don't like it then sell the lens and replace it with a Summarit-M 50 mm 1:2.5 or a Summilux-M 50 mm 1:1.4 Asph ... or anything but a Summicron.
Early 50/2s do have that tendency but not no that point in my experience and the current version is more resistant to flare fortunately. Your lens needs a good check-up most probably.
Strange. I've used mine on digital as well as film and have never seen this. I would have noticed straight away! I agree with others that it needs to be checked; it's certainly not normal behaviour in my experience (on digital I've used it on the M9 and M Typ 240).
