A Sfeir Posted February 1, 2014 Share #1 Posted February 1, 2014 Advertisement (gone after registration) Does anybody have any experience with this? It does look that the vertical adjustment is different from the M8, 9 using the special tool. Quote Link to post Share on other sites More sharing options...
Advertisement Posted February 1, 2014 Posted February 1, 2014 Hi A Sfeir, Take a look here M 240 rangefinder vertical adjustment. I'm sure you'll find what you were looking for!
A Sfeir Posted February 1, 2014 Author Share #2 Posted February 1, 2014 Having no feedback on my earlier post. I decided to go ahead and do it. My M fell accidentally on a carpeted floor and as a result, I noticed a shift in the vertical alignment of the view finder. No other damage nor scratch. That took place over a month ago, and I decided to live with it until I can send it to Solms at a time where it would not be needed for few weeks. I read most threads on alignment, both horizontal and vertical, and presumed the vertical adjustment would be like the M8 as described by marknorton and others. So I decided to do it myself as I had already adjusted the horizontal shift several times on M cameras. I got the special tool, and managed to remove the Leica logo unscratched by heating it and rotating it with a couple of wooden sticks. Then surprise, the vertical adjustment is nowhere similar to that of the M5..M8..M9 needing the special tool. Seeing this, I posted my earlier question, hoping somebody has been through this so we can compare notes. Instead of having a window showing the mechanism I referred to earlier, I only found a tiny hole showing a hex screw size 2. Examining the inside with a light and loupe, I deduced that the screw is attached to a cam (invisible), turning the screw moves a metal part that causes the patch to move up or down. Very easy to adjust after one puts a tiny drop of acetone to loosen the screw. Referring to previous posts that mention the improvement in the precision of the focusing mechanism, I can confirm, that, at least as far as the vertical alignment is concerned, the new design seems to be an improvement. 10 Quote Link to post Share on other sites More sharing options...
jip Posted February 1, 2014 Share #3 Posted February 1, 2014 Sorry I couldn't help you, but thanks for letting us know!! Very interesting. Quote Link to post Share on other sites More sharing options...
A Sfeir Posted February 1, 2014 Author Share #4 Posted February 1, 2014 Sorry I couldn't help you, but thanks for letting us know!! Very interesting. Will try to post a pic tomorrow. A very small hole, I hope a picture can show some of the inside parts. 1 Quote Link to post Share on other sites More sharing options...
fussgangerfoto Posted February 14, 2015 Share #5 Posted February 14, 2015 (edited) My M fell accidentally on a carpeted floor and as a result, I noticed a shift in the vertical alignment of the view finder. No other damage nor scratch. Today is Friday, the 13th… My four-week-old M240 took a tumble, in a heavily padded bag, about 8 ft. onto a cement floor. After my heart started beating again, I checked it out and it was without a scratch and it seemed to function OK (I turned it on and snapped a couple of live-view pictures to verify the shutter and electronics were OK). So I sighed and went to work and realized I had never checked the viewfinder. Sure enough, after agonizing about it all day, I came home and checked the rangefinder only to find it horribly out of vertical alignment. The horizontal appears to be spot-on, verified with focus peaking, but the vertical is off. Is there any way for a detail-oriented, do-it-yourselfer to make this adjustment? I have disassembled and repaired iPhones and mechanical watches, so I am compelled to ask. I just can't part with the camera for weeks upon weeks. Edited February 14, 2015 by fussgangerfoto Quote Link to post Share on other sites More sharing options...
pico Posted February 14, 2015 Share #6 Posted February 14, 2015 You are a smart person. How hard is it to find this: Leica FAQ — Rangefinder adjustment Quote Link to post Share on other sites More sharing options...
fussgangerfoto Posted February 14, 2015 Share #7 Posted February 14, 2015 Advertisement (gone after registration) You are a smart person. How hard is it to find this:Leica FAQ — Rangefinder adjustment LOL. Yes, found that. Imagine my reluctance to follow the advice from a reference that mentions the M6 as the latest Leica. Perhaps things have changed since then, perhaps not. 2 Quote Link to post Share on other sites More sharing options...
jaapv Posted February 14, 2015 Share #8 Posted February 14, 2015 As this thread specifies, only the screw changed. You can just as well use instructions from a 1954 M3. 3 Quote Link to post Share on other sites More sharing options...
fussgangerfoto Posted February 14, 2015 Share #9 Posted February 14, 2015 As this thread specifies, only the screw changed. You can just as well use instructions from a 1954 M3. Yep. I warmed the red dot logo and turned it a few times clockwise then anti-clockwise until it came loose, revealing the 2mm hex adjustment screw beneath it. Turning the screw clockwise raised the ghost image and anti-clockwise lowered it. A few trial and error adjustments and it was perfect again. The glue pad on the back of the red dot was still intact so I didn't have to reglue it.I think I dodged a bullet this time. Interestingly my M7 was in the same case and survived the jolt just fine. Thanks for everyone's help. 3 Quote Link to post Share on other sites More sharing options...
pico Posted February 14, 2015 Share #10 Posted February 14, 2015 Yep. I warmed the red dot logo and turned it a few times clockwise then anti-clockwise until it came loose, revealing the 2mm hex adjustment screw beneath it. Turning the screw clockwise raised the ghost image and anti-clockwise lowered it. A few trial and error adjustments and it was perfect again. Thank you for posting your good experience. It lends confidence to others who wish to do the same. . Quote Link to post Share on other sites More sharing options...
Hannes Lummes Posted February 14, 2015 Share #11 Posted February 14, 2015 I did it today. Easy! Quote Link to post Share on other sites More sharing options...
epand56 Posted February 17, 2015 Share #12 Posted February 17, 2015 At the time i had this problem with my M8, i did a try on aligning it by myself, but the results didn't match my expectations. I had then to send the camera to Solms and when back, two weeks later, anything was spot on. Unless you're very skilled in this kind of tricks, I suggest you to send the camera for adjustment. Quote Link to post Share on other sites More sharing options...
A Sfeir Posted February 17, 2015 Author Share #13 Posted February 17, 2015 At the time i had this problem with my M8, i did a try on aligning it by myself, but the results didn't match my expectations. I had then to send the camera to Solms and when back, two weeks later, anything was spot on. Unless you're very skilled in this kind of tricks, I suggest you to send the camera for adjustment. I believe the new mechanism where the cam is attached to the hex screw is easier to adjust than in previous Ms 2 Quote Link to post Share on other sites More sharing options...
aaronganz Posted January 11, 2016 Share #14 Posted January 11, 2016 Hi there am new with my m240 the focus is good but the vertical alignment is a little bit off, i will puchase the key to make it on ebay .....i just wanted to make shure after you remove the red dot and aligned it how do you properly paste it back on Any sugestions i dont want to by a new dot if i can safely get it off and on properly Thank you guys Quote Link to post Share on other sites More sharing options...
rafael_macia Posted January 11, 2016 Share #15 Posted January 11, 2016 How about this adjustment on an M-P 240, where there is a screw, rather than a dot? Quote Link to post Share on other sites More sharing options...
jdlaing Posted January 12, 2016 Share #16 Posted January 12, 2016 How about this adjustment on an M-P 240, where there is a screw, rather than a dot? The screw covers the same hole the dot does. 1 Quote Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted January 12, 2016 Share #17 Posted January 12, 2016 Hi there am new with my m240 the focus is good but the vertical alignment is a little bit off, i will puchase the key to make it on ebay .....i just wanted to make shure after you remove the red dot and aligned it how do you properly paste it back on Any sugestions i dont want to by a new dot if i can safely get it off and on properly Thank you guys It's a 2mm Allen key. A dollar or two at any hardware store. The dot is held on with sticky gum. I just stored mine carefully and stuck it back on when finished. It's still there six months later. If it lost it's stick some thin double sided tape would do the same job. Gordon 1 Quote Link to post Share on other sites More sharing options...
steadivision Posted December 28, 2016 Share #18 Posted December 28, 2016 (edited) Thanks so much for this thread. I was anticipating a 6-week turnaround. Even for a klutz like me. It's five minutes work with a hairdryer, two wooden toothpicks, and a 2mm Allen key. Chris Edited December 28, 2016 by steadivision 1 Quote Link to post Share on other sites More sharing options...
jaapv Posted December 28, 2016 Share #19 Posted December 28, 2016 Hi there am new with my m240 the focus is good but the vertical alignment is a little bit off, i will puchase the key to make it on ebay .....i just wanted to make shure after you remove the red dot and aligned it how do you properly paste it back on Any sugestions i dont want to by a new dot if i can safely get it off and on properly Thank you guys The key on eBay is for older models. Quote Link to post Share on other sites More sharing options...
ndf9 Posted December 31, 2016 Share #20 Posted December 31, 2016 Is the Horizontal alinement more difficult to resolve? My M-P has it and needed to be send to Wetzlar, after been checked in the Leica Store. Is now away since nearly 2 month Quote Link to post Share on other sites More sharing options...
