asalazar Posted December 12, 2013 Share #1 Posted December 12, 2013 Advertisement (gone after registration) Any suggestion for a flash with a swivel head? I need some input. thanks Armando armandosalazar.weebly.com Link to post Share on other sites More sharing options...
Advertisement Posted December 12, 2013 Posted December 12, 2013 Hi asalazar, Take a look here Flash for leica m6 ttl. I'm sure you'll find what you were looking for!
MAX Posted December 12, 2013 Share #2 Posted December 12, 2013 METZ SCA Adapter 3502 ( M5 ) + METZ Flash 40 ~ 58 for TTL ! ...without TTL - every Flash over central contact. Link to post Share on other sites More sharing options...
asalazar Posted December 13, 2013 Author Share #3 Posted December 13, 2013 Thanks. I usually shoot with the flash in manual mode. I use a handheld exposure meter, fire the flash, measure it and then i decide exposure trying to match the strobe with the natural light. That is the way i learned to work with flash so i don´t need the TTL system. What unit do you recommend for this manual approach?, something small and not so expensive Armando Link to post Share on other sites More sharing options...
MAX Posted December 13, 2013 Share #4 Posted December 13, 2013 What unit do you recommend for this manual approach?, something small and not so expensive ...without TTL - every Flash over central contact. For METZ Flash(es) the SCA Standard Adapter 3001 is sufficient. All other Flash ( z.Bsp. LEICA 24 D etc. ) have this "option" inside. Link to post Share on other sites More sharing options...
stuny Posted December 13, 2013 Share #5 Posted December 13, 2013 Armando - This section is for technology photos not Q&A. I'm moving it to where it belongs, and leaving a redirect here. Link to post Share on other sites More sharing options...
250swb Posted December 13, 2013 Share #6 Posted December 13, 2013 Swivel and tilt head an Olympus FL36 or FL50. Both are small and powerful and although made to match the m43 format they do have a conversion setting for use with the 35mm format. Steve Link to post Share on other sites More sharing options...
sc_rufctr Posted December 14, 2013 Share #7 Posted December 14, 2013 Advertisement (gone after registration) Nikon SB 15... Swivel head, Cheap, reliable and best of all... SMALL. Link to post Share on other sites More sharing options...
