M Monochrom Firmware Update 1.002
Bill W
This came out in June of this year. I still have the email announcing it and was curious if anyone actually did the update and if it is really needed. I did not update and the "improvements" were.
Bugfix to improve stability in “Discreet”-Mode
Linguistic improvements in French, Italian (I do not speak either)
Improved stability when the camera is connected to USB (Never use this feature)
As I recall, the stablity of descreet mode was not fixed. Just curious what other MM owners did.
The discrete mode is still no where near 100% reliable.
It seems like there is a debounce problem with the shutter release.
You have to consciously maintain shutter release pressure until the SD write starts. If you jab at the release it's more likely to lock up until the SD card writing has completed then wind on.
i.e. you must try to carry through with a deliberate fire-hold-wait-release action on every shot ; fire-release is asking for trouble.
Did not upgrade, I never fix something which is not broken (for me).
My thinking exactly, I just was wondering if I was missing out on anything. I never use discreet mode so that was not an issue for me.
Discreet mode is indeed not stable after the firmware update.
I discovered that the camera would still lock up after the 1.002 firmware was installed when using Discreet mode. So I just gave up on the whole discreet mode feature, disabled it, and never thought about it again.
  • 3 weeks later...
Just curious to know if anyone has the previous version of the MM firmware? I use discreet mode a LOT on my M9 so I downgraded to 1.176 so it would function properly. In August I jumped at the opportunity to purchase a demo MM which came with the "updated" and therefore discreet-less firmware.
Looking at Leica's website they of course only have the current firmware available. Please PM me if you have a copy of the older firmware installer/
Thank you!
Jeff G.
Jeff,
The discrete mode never worked properly with any MM firmware version.
The latest version is the best of a bad bunch; as it works most of the time and the camera recovers after a few seconds when it hiccups.
Still it is advisable not to use discrete mode :mad:
Well that sucks! My MM will lock up immediately trying discreet mode… Hopefully Leica will take their thumb out of their … and get this and the M9 firmware fixed. :rolleyes:
Jeff,
As someone about to take the leap of faith and add an MM to my M 240, none of this necessarily fills me with confidence.
Trouble is, I know I'll still buy the MM, probably next week, or even as soon as tomorrow.........I have been around Leicas long enough to know that it is inevitable, and resistance is futile.
