clx Posted September 15, 2013 Share #1 Posted September 15, 2013 Advertisement (gone after registration) Before I owned the M6, I used to have the Canonet QL 17 GIII. It was working perfectly until I stopped using it for 3 months. The shutter got stuck. When I took it to the repair shop, they asked if I have left the battery inside as the shutter/ self timer is very sticky and dry. So I'm wondering if I should remove my M6's battery when not in use to prevent shutter jam? Link to post Share on other sites More sharing options...
Advertisement Posted September 15, 2013 Posted September 15, 2013 Hi clx, Take a look here M6- Should you remove the battery when not in use? . I'm sure you'll find what you were looking for!
TomB_tx Posted September 15, 2013 Share #2 Posted September 15, 2013 Yes - I left one in my M6 in storage for too long, and the battery leakage affected both the meter circuit and the shutter mechanism. Link to post Share on other sites More sharing options...
philipus Posted September 15, 2013 Share #3 Posted September 15, 2013 I may be wrong but I think power is cut when you put the shutter speed dial on B. I almost never turn off my TTL though and can usually shoot 80-100 rolls before I need to change the battery. Link to post Share on other sites More sharing options...
TomB_tx Posted September 15, 2013 Share #4 Posted September 15, 2013 In my case the M6 was stored for about 5 years! Link to post Share on other sites More sharing options...
philipus Posted September 15, 2013 Share #5 Posted September 15, 2013 sorry to hear that Tom. 5 years is a long time though Link to post Share on other sites More sharing options...
250swb Posted September 15, 2013 Share #6 Posted September 15, 2013 I've an MP that I bought when they where new in 2003, and never used it much. So come 2012 when I decided to give it an exercise the battery was still good, for about a week, so in the scheme of things on its last legs. So leaks and things are not a direct correlation with time. I think temperature of storage and how clean the battery is when inserted into the camera are an indication of passive service life, but that has as yet no correlation with statistical evidence. But keep it clean (the battery), so no sweaty grease can start to cause corrosion, and always switch it off on 'B' as well as any other switch (a trick with Olympus SLR's) and the battery will last as long as it will. Steve Link to post Share on other sites More sharing options...
StS Posted September 16, 2013 Share #7 Posted September 16, 2013 Advertisement (gone after registration) I'm using Lithium batteries, they are relatively more expensive, but still inexpensive, compared to other batteries - or having to take care of leakage damages. Duracell claims they will expire in almost a decade. However, I still would take the battery out for longer storage. A second point to observe would be to use all times, especially 1 s, before putting it in storage and to repeat the exercise in storage - oils start to resinfy, when not moved regularly. I still have an OM4 (pre-Ti), which eats batteries, even when stored shut off (the Ti is said to be improved). Since I seldom use it, it is without batteries by default. Stefan Link to post Share on other sites More sharing options...
sblitz Posted September 16, 2013 Share #8 Posted September 16, 2013 leakage can occur because of any number of factors, including a badly made battery. time in the camera only raises the probability of something bad happening. and yes, fire your last shot, set the shutter to B, camera is off. Link to post Share on other sites More sharing options...
smb Posted September 16, 2013 Share #9 Posted September 16, 2013 If you are putting a camera in storage: Yes, remove the battery. Turning the shutter dial to bulb turns off the meter in the M6 and will not drain the battery. That is wise to do at the end of the day's photographing. But, if you forget it will not make much of a difference. If you have a number of cameras you should check them periodically if there is a battery in them. Remove the battery when it no longer functions. Shutters on cameras should be exercised periodically to prevent them from sticking. Link to post Share on other sites More sharing options...
