x
21 hours ago, wda said:
And just hope nothing significant moves 😉
Thank you
You can photograph moving things as long as you understand the constraints,
If you look at my panorama, there are ocean waves, and the ocean waves are in motion.
I wasn't happy with the original pano because the sky was bit blotchy and the entire panorama wasn't that sharp.
I reshot it today, and today's version is a bit better.
ISO 100, 23.2mm f/8, 1/800th sec.
12 shots to 4 HDR shots merge to one HDR panorama.
Edited by TMorita
Yes, indeed. Do you merge HDR shots first, then combine in a panorama; or vice versa?
12 shots merged to 4 HDR shots, then the 4 HDR shots merged to HDR panorama.
So merge to HDR first.
Toshi
Edited by TMorita
Toshi
Toshi, thank you. You have inspired me to try this technique on mundane matter close by; then for real once we can resume travelling again. You certainly produce fantastic results with your X Vario, despite its obsolescence. Truly inspiring.
If you want to try this, here's a few tips:
o Start with a 2-shot or 3-shot panorama for initial attempts.
o Use about a 25% overlap between successive frames
o You need to be in manual mode to ensure the exposure is consistent across frames. If you don't know how to choose manual settings, you can cheat by taking a test shot, then switching to manual and using the settings from the test shot for all the frames.
o My quick easy way to do HDR is to use +-1.7 exposure bracketing. This is what I used for the lighthouse panorama.
o I usually use the default spherical mapping for panoramas in Lightroom. Sometimes cylindrical is also good.
Good luck!
Toshi
Good luck!
Toshi
Toshi, much appreciated. Very helpful. Thank you.
X Vario, ISO 100, 31.4mm f/8, 1/100th sec, HDR +-1.7 EV
X Vario, ISO 100, 32.7mm, f/8, 1/320 sec, HDR +-1.7 EV
On 5/17/2020 at 1:48 AM, jaapv said:
How to upload images:
Prepare the image as follows:
1.   The image should be sRGB and 8-bits
2.   Reduce the size to 2480 pixels on the longest side. (smaller sizes can be set, but are not recommended)
3.   Sharpen properly for screen.
4.   Save as JPG to your desktop, reducing JPG quality to produce 1000 kB (2000 kB for sponsoring members).
5.   In Lightroom these parameters should be set in the Export dialog.
6.   In the Forum posting or editing box, click “choose Files” and select the image.
It is also possible to embed an image through linking, but the  embedded image must still fall within the forum size rules above. There is also the risk of a broken link when the image is moved or deleted on the other site. Not recommended.
When you find an image on the forum you see a preview. Click on it for good quality. When the plus symbol appears click on it for full size.
Jaap, what about Resolution? Any recommendations?
The resolution value is irrelevant for Internet posting. It comes into play when determining print size. For display on a screen the computer will take the number of pixels and put them on your screen which has a fixed resolution.
On a cold and windy day quail like to hang out in my barn.  That's fine with me because they eat any loose grain the horses leave on the ground. The quail are wild but when the weather is bad they put up with me. 🙂
What a lovely story; pictures and words. They work so well together.
California wildfire area after rain
X Vario, HDR pano
Edited by TMorita
A less burnt area after the California wildfires
X Vario, HDR pano
X Vario, ISO 800, 46mm f/8, 1/4 sec.
River Saar
X Vario, ISO 200, 33mm, f/8, 0.3 sec
X Vario, ISO 100, 18mm f/16, 15 sec, yes 15 sec.
Edited by TMorita
