Stein K S Posted April 6, 2013 Share #1  Posted April 6, 2013 Advertisement (gone after registration) Hi  I just purchased the Lux 35 asph pre-FLE. And just learned about the hood 12466 as an option. However, when I start to look at the positioning of the "indents" on my lens to make this hood stay "horizontal", the positioning of these indents are not totally " horizontallized". My first thinkink was that this could be fixed in Solms... But when looking closer, it seems that he distance from these indents to the oval white spote to adjust aperture, is uneven to the left vs to the right... about 2,5mm difference... and this puzzles me since it seems so that these indents and the white aperture spot are made/placed on the same piece of metal.  So, would it actually be so that this hood (which I currently do not keep) is uneven as well... or will it just stay un-horizontal on certain examples of this lens?  Anyone having any experience with this issue?  From a guy who is picky... but still not that picky  Regards, Stein Kjetil Link to post Share on other sites More sharing options...
Advertisement Posted April 6, 2013 Posted April 6, 2013 Hi Stein K S, Take a look here Lux 35 pre-FLE & 12466 hood fit. I'm sure you'll find what you were looking for!
lct Posted April 6, 2013 Share #2  Posted April 6, 2013 Not sure if my question is useful as i don't own the lens nor the hood sorry but the 12466 is a clip-on hood which is supposed to clip on the groove you can see below AFAIK. Do you mean that this groove is not parallel to the aperture ring of your lens? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/202141-lux-35-pre-fle-12466-hood-fit/?do=findComment&comment=2292342'>More sharing options...
Stein K S Posted April 6, 2013 Author Share #3 Â Posted April 6, 2013 Not sure if my question is useful as i don't own the lens nor the hood sorry but the 12466 is a clip-on hood which is supposed to clip on the groove you can see below AFAIK. Do you mean that this groove is not parallel to the aperture ring of your lens? Â Hi and thanks for your reply! Â If I read your question right, this is not what I address. Using your picture of the lens, the distance from the white mark (at the 1,4) to left and to right to the respective "indents" to keep the hood in "horizontal" position, differs with appr 2,5mm... which will position the hood slightly wrong... Am I getting this understandable? Â Regards, Stein Link to post Share on other sites More sharing options...
lct Posted April 6, 2013 Share #4 Â Posted April 6, 2013 If i'm not mistaken, the indents you're referring to are two notches made for the regular 12589 plastic hood of the lens. They may be used with the 12588 plastic hood as well. But not with the 12466 metal hood which simply clips onto the groove you can see on my pic above AFAIK. http://www.l-camera-forum.com/leica-wiki.en/index.php/12466 http://www.l-camera-forum.com/leica-wiki.en/index.php/12588 http://www.l-camera-forum.com/leica-wiki.en/index.php/12589 Link to post Share on other sites More sharing options...
UliWer Posted April 6, 2013 Share #5  Posted April 6, 2013 The 12466 covers the f-stop index of the lens, but has the same white spot. So it should be exactly at the position of the f-stop index of the the lens  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  (Sorry for the dust:o)  With the Summilux the hood at first doesn't seem to fit. I had to try several times until I found the right position, but then it enters very snug and without any problems.  Of course the indent above the fixed "ring" which has the index for f-stops should be parallel to all other parts of the lens. Can you post a photo where one can see the uneven part?  If you mean the two little indents which lct marked ob his first photo: the 12466 has two little clamps which must - an do - enter exactly there. Only this way the white spot can be used as f-stop-index Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  (Sorry for the dust:o)  With the Summilux the hood at first doesn't seem to fit. I had to try several times until I found the right position, but then it enters very snug and without any problems.  Of course the indent above the fixed "ring" which has the index for f-stops should be parallel to all other parts of the lens. Can you post a photo where one can see the uneven part?  If you mean the two little indents which lct marked ob his first photo: the 12466 has two little clamps which must - an do - enter exactly there. Only this way the white spot can be used as f-stop-index ' data-webShareUrl='https://www.l-camera-forum.com/topic/202141-lux-35-pre-fle-12466-hood-fit/?do=findComment&comment=2292505'>More sharing options...
Stein K S Posted April 7, 2013 Author Share #6  Posted April 7, 2013 Of course the indent above the fixed "ring" which has the index for f-stops should be parallel to all other parts of the lens. Can you post a photo where one can see the uneven part?  If you mean the two little indents which lct marked ob his first photo: the 12466 has two little clamps which must - an do - enter exactly there. Only this way the white spot can be used as f-stop-index  Hi again and thanks a lot... Great to see the hood actually mounted!  My "dilemma" is still on though... Cause when I measure the distance from the white spot on the lens to each of the indents (to left and right on your photo), these two distances differ with 2-2,5 mm... not that much... I guess the hood stil mounts kind of straight (even if defenitely totally straight), but still weird on a Leica lens or...? Guess I need to get one to find out!  Stein Link to post Share on other sites More sharing options...
Stein K S Posted April 7, 2013 Author Share #7  Posted April 7, 2013 Advertisement (gone after registration) Of course the indent above the fixed "ring" which has the index for f-stops should be parallel to all other parts of the lens. Can you post a photo where one can see the uneven part? If you mean the two little indents which lct marked ob his first photo: the 12466 has two little clamps which must - an do - enter exactly there. Only this way the white spot can be used as f-stop-index  Hi again and thanks a lot... Great to see the hood actually mounted!  My "dilemma" is still on though... Cause when I measure the distance from the white spot on the lens to each of the indents (to left and right on your photo), these two distances differ with 2-2,5 mm... not that much... I guess the hood stil mounts kind of straight (even if defenitely totally straight), but still weird on a Leica lens or...? Guess I need to get one to find out!  Sorry... should be a "NOT" within the last parentesis...  Stein Link to post Share on other sites More sharing options...
Erik Gunst Lund Posted April 7, 2013 Share #8 Â Posted April 7, 2013 Why don't you take a picture of it so we can see. Link to post Share on other sites More sharing options...
UliWer Posted April 7, 2013 Share #9 Â Posted April 7, 2013 ...My "dilemma" is still on though... Cause when I measure the distance from the white spot on the lens to each of the indents (to left and right on your photo), these two distances differ with 2-2,5 mm... Â Now I got it! Â It is exactly as you say: from the white point I measure 3.8 cm to the left and say 4.05 to the right. This is as it should be and the clamps for the hood will enter exactly there with the white spot at its proper place. Link to post Share on other sites More sharing options...
Stein K S Posted April 7, 2013 Author Share #10  Posted April 7, 2013 Now I got it! It is exactly as you say: from the white point I measure 3.8 cm to the left and say 4.05 to the right. This is as it should be and the clamps for the hood will enter exactly there with the white spot at its proper place.   Thanks! You made my day!  And we are "dead on"... I measured appr 3,85 cm to left and 4,05 to the right! Now I just need to come up with the euro 350,- + for the piece!  The very best from Stein in Norway Link to post Share on other sites More sharing options...
UliWer Posted April 7, 2013 Share #11 Â Posted April 7, 2013 As you already have the 35mm Summilux the most economic way for the 12466-hood is to buy a 28mm Elmarit asph or a 28mm Summicron. Then the costs for the hood can be divided on two lenses and won't hurt so much Link to post Share on other sites More sharing options...
lct Posted April 7, 2013 Share #12 Â Posted April 7, 2013 You mean the last 28/2.8 pre-asph i guess. Link to post Share on other sites More sharing options...
UliWer Posted April 7, 2013 Share #13 Â Posted April 7, 2013 You are right! I thought, the hood fitted the current 28mm Elmarit, which it doesn't. Link to post Share on other sites More sharing options...
Stein K S Posted April 7, 2013 Author Share #14  Posted April 7, 2013 You are right! I thought, the hood fitted the current 28mm Elmarit, which it doesn't.  Hi guys  Already got the very nice 12504 for my 28 Elmarit asph... I guess I am not much of a hood guy, but if hood... they should be nice...  Stein Link to post Share on other sites More sharing options...
