M240 SD Cards and Associated Camera Function Speeds
Thought for the day: we seem to be automatically assuming that the Sandisk cards are bona fide.. Are we absolutely certain that this is true because there are an awful lot of counterfeit Sandisk cards in circulation? Just saying.:o
Pete.
Red herring?
  • Replies 259
  • Created
  • Last Reply
Pete.
Ciao Pete,
I thought about that at first, that's why I tried with 3 different sellers, as well as different SD makers (Trascend, Panasonic and Lexar too).
Pete.
Absolutely certain I am not, but the 4.5s Extreme Pro I mentioned in my posts before came from B&H.
Jaap, I wouldn't uphold Leica on this regards.;) Nevertheless, even if you don't care about the speed, you're still confirming that your startup time (which seems to be the best yet recorded), is out of specs too, and it's slower tha the M's predecessors (not counting the competitors).
So it's not a sample's issue imho.
I am reluctant to compare with M9, which had its share of problems with cards as well. My M9 had occasional lockups and I am more comfortable with predictable delay than with unpredictable lockups.
I am not so reluctant to compare with my ages old Canon 5D2 though. I did the same test as with the Leica. There is no delay to measure.
It seems quite obvious to me instead, since the M9 is the closest "relative" to the M 240.
Then again, the M9 trouble with SD cards seems to be another matter to me.
Oh, well you're right. As I wrote earlier, I'm just keeping myself from putting other camera makers into the equation, 'cause it would be even more serious.
Today I bought a new 16 GB Sandisk Extreme (just Extreme) rated 80MB/s at 27 usd at a bestbuy in Chicago.
With this card the camera is lightning fast.
Switch on time is less then half a second and continuous shooting is actually continuous. No slow down (DNG compressed). The camera wakes up istantaneously.
I never had problem with my other Sandik, but this new one is visibly faster than old ones.
I hope this can help
Franco
This seems to be the fastest M240 ever recorded.
May I ask you how you recorded that too?
Few more questions:
-how many red led blinks you can count when turning it on?
-Have you tried the 32GB too? (I did, and it was just a pain)
-Is it really half a second if you switch on the camera, while pressing the shutter button?:confused: ...in other words, it should be half a second from the moment you turn it on, until the moment the shot is taken
In that case, seems like your Leica M, is not only faster than ours when shooting with an SD card, but it's faster than my camera with no sd card at all, which is odd
(and FWIW, it's faster than the one I've used at the Leica event in Milan, as well as the one available at the Leica Store in Rome...)
Or perhaps it is a famous SF card boosted at Maranello.
SF meaning Sandisk Ferrari and not Science Fiction of course.
Just kidding ;)
Not only are there fake SanDisk cards around but duff genuine ones as well. I have now had two bad 16GB 48X cards. In a way it has worked in my favour, as SanDisk has replaced them with 95X ones. My symptoms included getting a file number with no content and failing to erase file numbers although the content was erased. This was on my first M240. I have had no problems with the replacement M240.
Wilson
Not for me (2s). Might i ask how you measured yours?
I agree ...... appearances can be very deceptive....... what seems to be 'lightning quick' compared to a slower card on measuring turns out to be 2 seconds.....:rolleyes:
..... time slows dramatically when you do it looking at a stopwatch .....;)
Sure. Whilst we are at it, some of you folks might wish to try an online stopwatch to reduce the error margin. Switch the camera off, aim it at the monitor, hold down the shutter release, switch the camera on whilst hitting the start button of the stopwatch and look at the pic. I do that thrice and keep the average result personally. FWIW.
ditto. I use exactly the same and shoot at each multiple of 10 seconds with it constantly running. Needs a bit of practice to switch on with the shutter pressed just as the XX0.00 passes though ......
and you have a pictorial record to prove you aren't cheating or have got an over-optimistic memory :rolleyes:
  • 1 month later...
Has the world of SD cards changed while I wasn't paying attention?
When the long-awaited M240 comes -- my first digital camera -- I shall need an SD card. So, consulting lct's invaluable table of SD-card speeds, and other comments on the forum, I decided on Panasonic Gold Pro (RP-SDA16GE1K) as perhaps the least likely to cause any problem.
But it's been discontinued! :mad: ... or at least that's what I've been told by two UK retailers, one of them a Panasonic owned shop.
Instead, pointers on the Web are directed towards Toshiba's new SDHC-II cards, which "will be launched in major markets worldwide, starting with Japan in October."
Toshiba : Press Release 16 Jul, 2013
Does anyone have any idea when these will become available in the UK?
Later,
Dr Owl
