46mm filters useable on 75mm Summicron ?
Niko
Anyone tried to use 46mm filters on 75mm Summicron with a step-down ring? I´m interested in the lens, but would not like to get yet another sized set of filters. I have 46mm and 58mm, but would like to use 46 so the hood wouldn´t be blocked...
Niko
E46 filters on a 49–>46 mm step-down ring? Bad idea.
Either get a 49–>58 mm step-up ring plus an extra E58 hood, or use the lens with no filters, or sell the Apo-Summicron and get the Summarit-M 75 mm lens instead.
I´m interested in the lens, but would not like to get yet another sized set of filters. Niko
Just how many filters do you use with your lenses? In my case, I have E46 UVa, ND and Pola for all my E46 fitting lenses. Adding an E49 UVa (the Pola has both E46 and E49 rings) is really not a big deal, which simply leaves the ND for which, in your position I'd use an E55 to E49 adapter and use the existing E55 filters. Unless you have numerous other filters that you constantly want to change then I don't see this being a huge problem myself.
