ryee3 Posted March 17, 2012 Share #1 Â Posted March 17, 2012 Advertisement (gone after registration) Can I use a uv/ir filter made for lenses used on a M8 on a R lens? Or do I need a uv only filter? Link to post Share on other sites More sharing options...
Advertisement Posted March 17, 2012 Posted March 17, 2012 Hi ryee3, Take a look here Leica E60 UV/IR filter. I'm sure you'll find what you were looking for!
Guest Ornello Posted March 17, 2012 Share #2 Â Posted March 17, 2012 Can I use a uv/ir filter made for lenses used on a M8 on a R lens? Or do I need a uv only filter? Â Such a question should probably be directed to Leica technical services. Link to post Share on other sites More sharing options...
giordano Posted March 17, 2012 Share #3 Â Posted March 17, 2012 Can I use a uv/ir filter made for lenses used on a M8 on a R lens? Or do I need a uv only filter? Â If it's the right size for the lens you can use it, but unless you're mounting the R lens on a M8 (via an adapter) you don't need to use it. Â For general photography with other cameras it has no advantages over an ordinary UVa filter (which many people here argue is never needed except perhaps to protect the front surface of the lens), and some disadvantages (typically involving to "ghost" reflections of highlights in night images). Â If you're using the R lens with ordinary professional or consumer film there's no need for an IR-blocking filter; if you're using it with a R8/9+DMR or any standard DSLR body, there's already an IR-blocking filter on the sensor Link to post Share on other sites More sharing options...
lct Posted March 17, 2012 Share #4 Â Posted March 17, 2012 Ghost reflexions can be caused by UV filters as well. If you have UV/IR filters already, you don't have to buy another UV if you need protection vs salt, sand, water and the like. Not sure if UV/IR won't cause some cyan shift with wide lenses though. No harm in giving it a try anyway. Link to post Share on other sites More sharing options...
jaapv Posted March 17, 2012 Share #5 Â Posted March 17, 2012 You cannot use it for slide film, or on lenses shorter than 35 mm. So on the DMR on longer lenses or a third-party DSLR you should be fine, barring the general drawbacks of filters, like flare, ghosting, etc. Â If it's the right size for the lens you can use it, but unless you're mounting the R lens on a M8 (via an adapter) you don't need to use it. Â For general photography with other cameras it has no advantages over an ordinary UVa filter (which many people here argue is never needed except perhaps to protect the front surface of the lens), and some disadvantages (typically involving to "ghost" reflections of highlights in night images). Â If you're using the R lens with ordinary professional or consumer film there's no need for an IR-blocking filter; if you're using it with a R8/9+DMR or any standard DSLR body, there's already an IR-blocking filter on the sensor Sorry, on an adapter on the M8 you WILL need it, and it does give a cool cast on slide film. Link to post Share on other sites More sharing options...
MarkP Posted March 17, 2012 Share #6 Â Posted March 17, 2012 No need to go to Leica technical services. This forum is indeed the fount of all knowledge. Link to post Share on other sites More sharing options...
darylgo Posted March 17, 2012 Share #7 Â Posted March 17, 2012 Advertisement (gone after registration) On an M8 it is necessary, on my M9 I have placed them on lenses 50mm and above. For landscape shooting there is weak ir polution on the M9 that the filter cleans nicely. In my testing of lenses with and without filters I have found zero deterioration of image sharpness when the filter is good quality and clean. Link to post Share on other sites More sharing options...
