Keith (M) Posted December 28, 2011 Share #1 Â Posted December 28, 2011 Advertisement (gone after registration) The postman brought a bayonet adaptor this morning so I just had to try out my recently acquired Elmar 90mm f4 (#1482xxx) which had been primarily bought for use on my IIIg, on my M9. Prior to this, the longest lens I had with bayonet mount was a Summarit 75mm and I was concerned that focussing the 90mm on an M might be a problem, as I have read various threads about difficulties that people have had. Somewhat to my surprise, I do not find any problem with matching the split image, even on relatively low-contrast subjects. One clear advantage of this lens IMHO is the long focus 'throw'. I made a couple of quick tests, one subject at minimum distance, the second at infinity. Ignoring the vignette in image 1 (SilverEfex Pro 2), I note that at infinity and against a blue sky there is a hint of vignetting (which would be easily fixed) but I wonder what the 'best' setting on the M9 would be? At the moment I have selected "90 f4 11633/11634". Â Based on today's results, it just might be a while before the 90mm makes it back to the IIIg... Link to post Share on other sites More sharing options...
Advertisement Posted December 28, 2011 Posted December 28, 2011 Hi Keith (M), Take a look here M9 + Elmar 90mm LTM - Best Code?. I'm sure you'll find what you were looking for!
luigi bertolotti Posted December 28, 2011 Share #2 Â Posted December 28, 2011 Imho, the 2nd picture, at infinity, displays a noticeable LACK of vignetting.... the bottom corners are perfect... and a blue sky - non-uniform while going upward, is someway not a rigorous proof : try a white paper with uniform lighting... I'd bet that real vignetting is very very low (and I, personally, doubt that a different setting can change it). Elmars 90 are pleasant small and nice old lenses... you made a fine buy . Link to post Share on other sites More sharing options...
lct Posted December 28, 2011 Share #3 Â Posted December 28, 2011 No M9 experience sorry. On the M8.2, my uncoded collapsible Elmar 90/4 (11631) vignettes more than my coded Elmar-M 90/4 macro (11633) which is hardly surprising. I would code the former like the latter as well. Link to post Share on other sites More sharing options...
