Neutral Density Filter
bab
I haven't used this particular filter but any ND filter can be used on a rangefinder lens without restriction. In fact, it is more practical than an ND on a SLR, as it will not darken the viewfinder.
You can also stack more than 1 ND filter for a cumulative effect. They typically come is sets of 3: 2, 4 & 8 stops. So you can say, put a 2 & an 8 together for 10 stops total.
Get larger sizes and a step down ring to avoid vignetting
I can't speak about this particular model, but I have two standard height B+W 58mm ND filters -- one 3-stop and one 6-stop. I use them with step-down rings, separately and stacked, so there's no vignetting. I've tried cheaper ones but they shift color. NDs work great on an RF. On an SLR you could not see through them to compose or focus.
John
I haven't used this particular filter but any ND filter can be used on a rangefinder lens without restriction. ...
Excluding ND Grad filters. Yes, I know they can be used but it's 'hit and miss' with a rangefinder camera, which I consider to be a restriction.:o
Pete.
John
This is uncharterded terrain for me. What is a "step down ring" and what is its purpose?
Regards
Åmund :confused:
Regards
Åmund :confused:
Åmund,
It's a circular piece of metal with two threads each of different sizes and is used, for example, to attach a 46mm diameter filter to a lens with a 39mm filter thread.
There is a wide variety of step-up rings available and can be purchased as a set of consecutive sizes like Steps from Leicagoodies.
Pete.
What is a "step-down ring" and what is its purpose?
It's a simple (and cheap) adapter ring to screw a wide-diameter filter onto a small-diameter lens. With a set of step-down rings matching your lenses, you can use one single set of filters on a variety of lenses—particularly useful when you're using many filters (uncommon today but used to be common for B/W film users).
Thank you!
So I can buy a set of filters that fit my lens with the largest diameter and step down rings for my other (smaller) lenses?
Regards
Åmund
Be careful when you order "step-up" and "step-down" rings - the nomenclature is not standardized. Some use "step-down" to refer to a ring which allows the use of a smaller filter on a larger lens filter thread, while others use it to refer to this as a "step-up ring", and vice-versa. Depends on whether you start at the lens side or start at the filter side...
Regards, Jim
