35 f/2 sharpness
joeq
Have you checked Leica's tech specs? You can download them complete with MTF curves at:
Leica Camera AG - Photography - Lenses
For a more historical reference, Leica used to offer also Erwin Puts' book "Leica M-Lenses - Their Soul and Secrets." I'm sure it's still available somewhere.
And see his site for further analyses--Home.
notwithstanding the obvious differences in dof, are some apertures inherently sharper than others on this lens?
Which lens do you mean? There are a great many f/2 35s. Not all behave the same way.
Yes, but what lens are your worried about.
If you are critical, i.e. look, or your shots need to be the same in the corners and centre, that is very difficult for a 35mm lens on 24x36.
The 50's summaron f/2.8 sets a standard at /5.6 very difficult to detect an improvement with later (& faster lenses) lenses, - in practice, the asph or the ZM are better than the older lens wider opened.
If you shoot hand held with fast film I'm not worry too much, 1/15 f/2 wont be that sharp.
Most of the time I use a f/2.5 CV, before that I normally used a J12...
Noel
Wow - that looks way too technical for me. Thanks, though.
Hi
That helps.
At /5.6 or smaller only the corners should be detectably softer in definition, if you are shooting brick walls.
Wider apetures you may notice increased softness 'creeping out of the corners'.
But you may need a sturdy tripod and high resolution film to detect these trends.
Leicas are about spontenous, Eugene Smith used antique lenses.
Noel
Hi
That helps.
Noel
got it - thanks.
As a general rule - general doesn't mean that it is always right - you can achieve the utmost sharpness at two stops lower then maximum aperture. That would be f/:4. With the best modern lenses you can achieve the optimum with less stepping down (the 2/90 AA is said to have it's optimum at f/:2.8, on stop down; the 3.4/135 Apo-Telyt at f/.4 - a half stop down; older lenses need to be stopped down more for their optimum: the pre aspherical 1.4/50 is said to have it's optimum only at f/:8 -- which would mean 5 stops down.). Though earlygalleries caveat is right: you won't see much difference in reality between 2 or more steps down.
In the Leica Pocketbook, 7th edit Puts says that the optimum of the 2/35 asph. is between f/:2.8 and f/:4.
Basically, Joe, "sweet spot" or "best performance" doesn't mean that much with Leica lenses.
Generally, they are designed to behave pretty well wide open; they'll improve a bit as you stop down one or two stops. On digital, f/5.6 is probably the point beyond which the lens doesn't improve, and diffraction effects start to seep in. With film, you might go to f/8 without seeing noticeable losses.
Two stops down from wide open is generally a safe bet with any lens. Leica lenses are designed to keep as much of that good performance as possible as you open them up. That's a major reason they cost what they do. They're still surprisingly good at full aperture.
In practical use, you shoot for what you can get. 1/15 sec at f/2 for most people will be more practical than 1/4 sec at f/4.
The main thing is: go shoot. If you're like most of us, you'll find the lens holds its own at any aperture. :)
