Small padded case for M8 w/ no extra lenses?
piblondin
H everyone,
I'm looking for a small case that will snugly fit my M8 with the very small Summicron 40mm lens attached to it. I don't need the case to fit anything else except, perhaps, a Ziploc bag to protect in the rain. I'm going to be traveling and would like to be able to put the camera inside my larger backpack with my other stuff. However, I want it to be protected from the other contents and from when I put the backpack on the ground. If the case also has an attachment for a shoulder strap, that's a plus too. Any suggestions? Thanks!
x
Have you considered the Leica Neoprene case? The short-nose version should meet your need for reasonable protection of the camera. It is the least expensive case for Leica.
I'm looking for something more like a small Lowepro case, but it's hard to tell which one would fit properly when I can only see them online. However, I'm also considering the neoprene case, but it doesn't seem like it would offer much protection.
Actually, it does offer quite good protection for bumps etc. but it is worse than useless in the rain. It acts like a sponge, soaking the camera. Reason I use the everready case in the wet, but it needs an extra baseplate to get the camera in and out easily and is quite a handful when shooting.
H everyone,
A piece of Roadwired wrap 16" x 16" would be a great alternative to small padded case. Search Amazon.
I googled and found Calumet site which lists several variants. Quite a good alternative.
OP don't discount the neoprene case entirely. It is not an equivalent to a fitted leather case, nor is it so expensive. I use mine mainly when bundled in a non-photo bag for non-photo outings. It does stop scuffing and scratching but, like most bags, they are not designed to withstand too many 'drop' tests!
Mine's pretty similar to this one (maybe an older model): Case Logic Ultra Compact Camera Case > Photo and Video > Case Logic
it was perfect with the collapsed Heliar 50/3.5, fits also the Planar 50/2 with no shade.
If your 'cron is shorter than the Planar chances are that you can fit it with the shade on.
Cheers,
Bruno
Bummer - thanks for the heads-up on the Leica neoprene case in the wet. I bought one just to keep in my pocket for situations when I want to be out with just the camera and no bag assuming it would provide wet protection, but haven't actually been in the wet with it.
