28mm for Leica M8?
jsrockit
Really? Tell me where you focus to take this pic for instance. http://tinyurl.com/yg6ozaf
Well, I'm not professing to be a depth of field master, but the photo you linked to is on a sunny day which would allow for a very closed down f/stop... allowing for a huge depth of field. MY point was that the other pictures you posted are not very active and generally zone focusing is more pressing for active subjects. I just meant that AF could work in these situations.
I have the 28 Rokkor on my M8 and I like it better than my 35 Summicron M.
The white spots are a "flaking" of the rear coating. Mine has been like that for the 3 1/2 years I've owned it and used it first on the RD1 and now the M8. No problems with the images.
If you use it on the M8 you should send it to DAG to have the mount modified to bring up the 28mm framelines. A small thing.
Jay
In that case it would be worth considering removing the coating altogether. Polishing with vinegar does that. I understand there are even not too expensive possibilities to recoat a lens, but I do not think the coating on the rear element would be missed.
And i just doubt it hence my question about the X1. Getting sharp results from say 2 meters to 50 meters can be achieved easily with the DoF markings of an Elmarit or a Rokkor 28 for instance. Less so with AF if DoF cannot be checked with a good VF or distance markings displayed somewhere on the camera.
I have the 28 Rokkor on my M8 and I like it better than my 35 Summicron M. The white spots are a "flaking" of the rear coating. Mine has been like that for the 3 1/2 years I've owned it and used it first on the RD1 and now the M8. No problems with the images...
The Rokkor's white spots come from moisture in the paint AFAIK, which explains why the spots don't alter the image quality, reportedly, as far as moisture doesn't reach the glass though.
See 28mm M-Rokkor White Spots - Photo.net Leica and Rangefinders Forum
  • 4 weeks later...
