Showing results for tags 'zeiss zm'.
Regarding the modern, made in Japan, Zeiss ZM branded lenses for Leica M mount...Some have serial numbers starting with 51 but most appear to have serial numbers starting with 15 - even for the same model lens (eg, 50mm f/2 Planar).I thought I read some explanation for this but I cannot find it any more (and my memory is spotty). I tried asking the mfgr, Cosina but have not received an answer. Does any body know what the different prefixes signify?TiA.
Greetings from lockdown, I just purchased a Zeiss zm 35mm Biogon-C F/2.8. Why? I don't know, I guess I wanted to try a Zeiss zm lens. I do also have a Summilux FLE, and a summicron V1 (Had a summicron ASPH, but never bonded with it). Anyhow, I realized that this lens has 43mm filter threads and was wondering if anyone is using a step-up adapter to 46mm, and if so whether they get vignetting for 1-2 filters? I would normally not hesitate to do this, but I ran into vignetting issues when stepping up from 39mm-46mm on a 50 APO lens (which was disappointing) and wasn't sure how well rangefinder lenses, in general and specific to this Zeiss lens, handle step-up adapters.
- 3 replies
- zeiss zm
- zeiss 35mm
(and 2 more)
Tagged with:
