Showing results for tags 'wide-angle'.
I'm thoroughly enjoying my new M10 with the 35mm & 50mm Summiluxes, a 90mm/f2.0 and 135mm Telyt Leica lenses. To cover the wide end for architecture/landscape, I got a Voigtlander Ultron 21mm/f1.8. I'm used to fast lenses from Fuji X. Since I love landscapes, and am curious about Zeiss lenses, I've found there are two interesting options, Biogon 25mm/f2.8 and Biogon 28mm/f2.8. What do you guys think of those as filling the 21-35mm gap? How do you feel about the relative slowness at 2.8? How's the rendering compared to the Luxes? And which one makes more sense, 25 or 28mm? I see that 21mm is quite fish-eye-y and would like a bit straighter lines... A+
- 21 replies
- 1
Hi everyone, I just purchased my first cinema style lens for the SL2-S and have just done a quick review and first impressions about it here I know some users have wondered how non-Leica lenses perform on this body, so I thought this could add to the literature. I have to say that this lens has been a pleasure to use and edit from– the wide angle is insanely fun to use! However, and I guess I don't really touch on this in the video, I don't think this is a normal walk-around lens like most Leica lenses are intended for. Even the bigger SL lenses can seem normal to walk around with. Because of the gears and almost intimidating appearance, I don't believe this fun wide-angle would be all that fun to roam the streets with. This all being said, I can see this being a fun option for small productions and wedding/event use! Sidenote– You may also notice some wobbling/warping on the sides of the video images, and I believe this is because the SL2-S currently does not properly accommodate for a 20mm focal length with IBIS. Throughout this video I used the 21mm option, so the weird warping becomes apparent when moving a lot Cheers
- 1 reply
- 2
- wideangle
- wide-angle
- (and 5 more)
