Showing results for tags 'hot shoe'.
I recently purchased a 21mm Summilux and a Brightline Finder 12024 to accompany it. When I slide the finder into the hotshoe on my M10 it feels remarkably loose and unstable, so much so that if the camera is tipped it will slide out. This can't be right. Investigating further I tried the same viewfinder on my M9-P and it fits securely, same when I try it on an M4 body. There are raised bars under the edges of the M9 hotshoe (see attached photos) and similarly on the M4 they seem to have springs under bars to use light pressure to hold things in place. Did something fall off my M10 without my noticing? On a stock m10 is the center area with the pin cluster flush with the rest of the hotshoe or is that area in the center raised up a bit from the bare metal? All other hotshoe items that I use have pin locks so nothing else falls out. I had a thumbs-up grip that went in the hot shoe that was too loose as well. I had assumed it was the grip bring too small, not that something was missing from my camera. Can anyone confirm this behavior or help me to understand what I may be missing? I I can use a small bit of gaffer's tape to fill in the loose area when using the viefinder on the the M10 but that hardly seems like the best solution. M9 hotshoe with raised pressure bars: M10, same area: M10 Top Down: M10 Straight in, note slightly raised center pin cluster. Is there a surrounding plate that is missing on my hotshoe?:
Hello everyone ! I just noticed that I have traces of wear on the hot shoe connectors of my leica Q2. I have used it only very rarely and with leica flashes. Has anyone noticed the same thing? Do I have to worry about it? Everything works very well but I still find it weird .. Thanks for your help !
