RobertW Posted May 11, 2008 Share #1 Â Posted May 11, 2008 Advertisement (gone after registration) I picked up a 2nd hand flash and can't seem to locate the manual on the Leica site for down load.... Can anyone direct me to a link to a soft copy please? Â Cheers Robert Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2008 Posted May 11, 2008 Hi RobertW, Take a look here Leica SF 24D Manual? pdf?. I'm sure you'll find what you were looking for!
archi4 Posted May 11, 2008 Share #2 Â Posted May 11, 2008 only one I could find is not free. Instruction Manuals L Link to post Share on other sites More sharing options...
grduprey Posted May 12, 2008 Share #3 Â Posted May 12, 2008 Call Leica NJ, they will probably send you one for free. Â Gene Link to post Share on other sites More sharing options...
grduprey Posted May 12, 2008 Share #4 Â Posted May 12, 2008 OOPs Sorry I did not see that you were in HK, maybe your local distributor can get you one. Â Gene Link to post Share on other sites More sharing options...
MichelB Posted May 12, 2008 Share #5 Â Posted May 12, 2008 You can have some information in the M8 Instruction Manual. MichelB Link to post Share on other sites More sharing options...
wiedemann Posted May 12, 2008 Share #6 Â Posted May 12, 2008 I can send a copy of the manual to you, please check your email, wolfgang Link to post Share on other sites More sharing options...
RobertW Posted May 12, 2008 Author Share #7 Â Posted May 12, 2008 Advertisement (gone after registration) I'll continue to "experiment". That said, I'd like some opinions whether I'm on the right track or way out to lunch. If you could provide some advice on how wrong or correct I am that would be greatly appreciated. I think the following assertions are correct:confused: ? It appears the + EV adjustments works in concert with the A or M mode only? You can set the camera body to "auto slow sync off which automatically sets the shutter speed to 1/250 all the shutter speed on the camera body? Or "down to either 1/30 or 1/8 or 32 seconds" I think these settings can be used for TTL & A mode? TTL flash mode works best with shutter speed set to 1/250, 1/30 or 1/8? When using TTL adjust the lighting intensity by stopping down on the camera's aperture ring since the EV + or - doesn't work well here? For "fill flash" its best to use M mode on camera and flash? Oh I forgot, when using A mode on the flash, you need to adjust the aperture setting to match the distance to the subject and then adjust the aperture on the camera lens to match. Also, always mount the flash and then turn on before turning on the camera so the ISO setting on the camera is communicated to the flash:eek: . Â Cheers Rob Link to post Share on other sites More sharing options...
RobertW Posted May 12, 2008 Author Share #8  Posted May 12, 2008 I can send a copy of the manual to you, please check your email, wolfgang  Oh thanks so much for sending a copy of the manual by e-mail. It must take a bit of time to arrive, as I've just checked and it hasn't arrived yet. As you can see from my recent post, I've been stumbling around trying to understand how to get the flash working well in A or TTL or M modes.  Thank you again  Best Rob Link to post Share on other sites More sharing options...
wiedemann Posted May 12, 2008 Share #9  Posted May 12, 2008 Dear Robert  the email is on the way to you. I hope, the instructions answer all your questions. If not, please don't hesitate to ask for further informations.  Best regards Wolfgang Link to post Share on other sites More sharing options...
RobertW Posted May 12, 2008 Author Share #10  Posted May 12, 2008 Dear Robert the email is on the way to you. I hope, the instructions answer all your questions. If not, please don't hesitate to ask for further informations.  Best regards Wolfgang  Thank you Wolfgang. I got the pdf and I'm sure its going to solve a great many mysteries and give me some additional confidence in knowing what the functionalities are in the flash.  Best, Rob Link to post Share on other sites More sharing options...
chris_livsey Posted May 12, 2008 Share #11 Â Posted May 12, 2008 I have found the 24D I bought with manual S/H, it was made before the M8 and the info in the M8 manual, one of the few times I have opened it, was much more help than the flash manual. A hint from Strobist ( a must visit for flash) is to use a cheap (now discontinued so e-bay) Nikon SC17 cord to use the flash TTL off camera (the new replacement cords are slightly longer and MUCH more expensive). Link to post Share on other sites More sharing options...
bsmithy Posted August 29, 2008 Share #12 Â Posted August 29, 2008 Dear Wolfgang, Â I know this must get annoying, but if you'd be willing to forward the sf 24d manual to me as well, I'd greatly appreciate it. I've emailed Leica but never received a response. Â Regards, Brad Link to post Share on other sites More sharing options...
RobertW Posted August 30, 2008 Author Share #13  Posted August 30, 2008 Dear Wolfgang, I know this must get annoying, but if you'd be willing to forward the sf 24d manual to me as well, I'd greatly appreciate it. I've emailed Leica but never received a response.  Regards, Brad  Hi Brad,  If you want a pdf of the manual, you'll need to provide your e-mail address as one of the options in this forum or you can just post it here and I'll e-mail you the file. Otherwise, no one will be able to e-mail you with the pdf.  The file size is just under 10 meg:eek: , so hope your server allows you to receive e-mails of that size.  Best, Rob Link to post Share on other sites More sharing options...
gautier Posted August 30, 2008 Share #14 Â Posted August 30, 2008 In french : SF 24D Link to post Share on other sites More sharing options...
jaapv Posted September 1, 2008 Share #15  Posted September 1, 2008  The file size is just under 10 meg:eek: , so hope your server allows you to receive e-mails of that size.  Best, Rob  Solution to that one: YouSendIt - Send large files - transfer delivery - FTP Replacement Link to post Share on other sites More sharing options...
SJP Posted September 1, 2008 Share #16 Â Posted September 1, 2008 or get a Google account (free) with 100Mb (free) space to dump files etc. (+ your homepage if you want to have one) Link to post Share on other sites More sharing options...
bsmithy Posted September 3, 2008 Share #17  Posted September 3, 2008 Hi Brad, If you want a pdf of the manual, you'll need to provide your e-mail address as one of the options in this forum or you can just post it here and I'll e-mail you the file. Otherwise, no one will be able to e-mail you with the pdf.  The file size is just under 10 meg:eek: , so hope your server allows you to receive e-mails of that size.  Best, Rob  Hi Rob,  Thanks. Please send it to bksmith12@cableone.net AND bsmith@hp.com. One of them is bound not to choke on it :-)  Regards, Brad Link to post Share on other sites More sharing options...
ger1g0 Posted March 21, 2009 Share #18 Â Posted March 21, 2009 Could I also bother you guys to send the PDF to me at jerome8@mindspring.com. Â Thanks! Link to post Share on other sites More sharing options...
ho_co Posted March 21, 2009 Share #19 Â Posted March 21, 2009 Rob-- I've just PM'd you with my email for one more of same. Â You know, Jaap's solution might be simpler: You just send a single copy of the PDF to YouSendIt, then post the password they give you here. The file remains available for two weeks, I think, and anyone with the password can download it. It's a single upload for you, and avoids email file-size restrictions. Â Many thanks for your courtesy. Link to post Share on other sites More sharing options...
zeitz Posted March 21, 2009 Share #20 Â Posted March 21, 2009 If you plan to use the flash on the M8, the manual I got with my flash last year and the french .pdf manual above won't help at all. The word "M8" does not even appear in the manual. Does anyone know if there a newer manual that addresses the M8? I haven't checked the M8.2 instructions, but the instruction in the M8 manual are nearly unless. Link to post Share on other sites More sharing options...
