CCD vs CMOS: Can you tell which is which?
dfarkas
After reading a lot of comments debating the merits of CCD vs CMOS (M9 vs M240), I decided to do a comparison of the two cameras. I shot with both at the same time, using the same settings and same lenses. I then used Lightroom to do a rough match of the images using only global slider adjustments. No Photoshop. No adjustment brushes or any other local adjustments.
As a final step, I now welcome everyone to take a look and vote on each set of images (there are 19 sets total) to see if you can tell which was taken with the M9.
The Great Debate: CCD vs. CMOS - Part 1
After amassing enough votes, I will post a follow-up, revealing the answers and how everyone did.
At the very least, I think it will be a good exercise to see if we can really see "The CCD Look".
Thanks for your help in my little experiment!
David
Thanks David. What profiles did you use when importing the raws into LightRoom?
I used my standard import presets for each camera, which use Embedded for M240 and Adobe Standard for M9. Why use different ones?
In my regular course of processing, these were the profiles that worked best for the respective cameras. Embedded for M9 is extremely inaccurate, with Adobe Standard being a vast improvement. There isn't as much difference between Embedded and Adobe Standard for the M240. In most cases, I prefer the look of Embedded, but sometimes portraits benefit from the slightly different color rendition of Adobe Standard. For these test images I didn't mess with different profiles for different images.
Hope that clears things up a bit.
BTW, my own experience was that I could make M240 files look exactly like M9's. I kept both of them for a month before selling M9. However I did find a difference in pixel level sharpness. M9 needed almost no sharpness and M240 needed a "little" to match unprocessed M9's. But on web size this difference will not be visible.
what an unusual post...
you may have considered including a nikon d40 for example as on the web no person can judge better, worse, best.
Print is the ultimate test isn't it?
Not wanting to be negative but what is the purpose of this?
andy
There's a big thread here debating that CCD is superior to CMOS although I don't think this is a direct response to the thread. I personally think there is a difference between how the M9 and M file behaves but if you process them to look similar its really hard to tell the difference.
andy
When evaluating images, if all we have are monitor presentations then it is a waste. Monitor presentations on a web page are already compromised, unless perhaps they contain a color profile and the browser (Safari, for example) considers it.
Well, most of my guesses were in the majority. Even at small size some difference may be apparent. This is quite interesting. A deeper blue, more vivid red, higher contrast -- possibly -- despite finagling the sliders in PP. I'll look forward to see the answers.
Good idea but your pics are too small David. Would it be possible to get at least 10MB files?
You can click on the images for a larger view, but I assume you mean you want to see full-size files. The test isn't to see which is more detailed, or which is sharper. Also, given the resolution difference of the two cameras, the answers would be much more obvious.
My real goal was to see if there was some immediately identifiable and recognizable look inherent to CCD files. This has been the assertion from those favoring CCD over CMOS, that it is impossible to produce the same color and tonality. I feel the images are large enough to judge color and tone and not be so big as to bog down the Internet.
Sending prints to everyone didn't seem a very practical option. :)
Most of us using digital cameras and processing our own files are used to correcting and judging images on screen. I'd guess that most have pretty decent monitors.
Yes, the files do have a color profile, sRGB, which matches most LCD color gamuts fairly closely. And yes, Safari, Firefox and Chrome are color profile aware.
Thanks, interesting test.
However:
- sRGB conversion castrates the color gamut. This is a real bummer, as color is what most people cite as the biggest plus of CCD sensors.
- The difference in dynamic range makes it easier to spot the M9 where color differences are otherwise subtle.
- The web resolution hides the differences in shadow noise.
In any case, if not the evanescent "CCD look", I am confident I have spotted the "M9 look" in most photos. Especially those with the lovely blue San Francisco sky :rolleyes:
Another question is do people prefer the CCD look (assuming they can recognize it)? I preferred most of those I selected as CCDs, even if only marginally. Of course I may be completely wrong. ;)
Hi David thank you for this test.
The ideal is that there is no correction :)
With a film like Kodak Portra and M7, I almost do not correct or I do not correct
Erwin Puts had mentioned that the M9 gives a "vivid" color and the M240 a "neutral" color
and I agree with him.
Best
Henry
