Tenor1 Posted September 23, 2009 Share #1 Posted September 23, 2009 Advertisement (gone after registration) What is the technique needed to keep structures straight when using a wider-angle lens? I was using a DLux-4 in Florence and the bell tower next to the church leans too much. I made the leaning tower of Florence, but I don't think the people of Piza would appreciate it. Link to post Share on other sites More sharing options...
Advertisement Posted September 23, 2009 Posted September 23, 2009 Hi Tenor1, Take a look here Need Help With A Wide-Angle Picture . I'm sure you'll find what you were looking for!
luigi bertolotti Posted September 23, 2009 Share #2 Posted September 23, 2009 Absolutely UNAVOIDABLE using wideangles (and normal lenses, too), expecially when you point the camera upwards. On reflex cameras special lenses with tilt & shift of optics are available, to have a certain degree of correction; large format cameras, with big bellows, allow large movements of lenses for this purpose. But digital post processing can be of help (and, indeed, also traditional film enlargers, with tilting base for paper). This is a quick adjusting of your picture made with Photoshop ... posing attention in the framing, when taking the picture, one can achieve good corrections in this way. [ATTACH]163829[/ATTACH] Link to post Share on other sites More sharing options...
Tenor1 Posted September 23, 2009 Author Share #3 Posted September 23, 2009 Thanks Luigi for helping me keep the leaning tower IN Piza. I hoped there was a camera technique while taking the picture, but I'm glad there is a post production tool. How appropriate that an Italian helped with this picture. Thank you, Link to post Share on other sites More sharing options...
dave_d Posted September 23, 2009 Share #4 Posted September 23, 2009 Keep the camera back parrallel to the face of the building. A shift lens comes in handy otherwise correct in post production. The tilting of the camera causes the the lines to converge. Link to post Share on other sites More sharing options...
farnz Posted September 23, 2009 Share #5 Posted September 23, 2009 Thanks Luigi for helping me keep the leaning tower IN Piza. I hoped there was a camera technique while taking the picture, but I'm glad there is a post production tool. How appropriate that an Italian helped with this picture. Thank you, Unfortunately, as you can see, Carlos, with extreme examples that are corrected in pp perspective can remain distorted: the rectangular tower has become triangular and the dome has gained a few pounds. In this instance it may be better to take a number of vertical shots around the subject with the camera level with the ground and stitch in pp. Pete. Link to post Share on other sites More sharing options...
Tenor1 Posted September 24, 2009 Author Share #6 Posted September 24, 2009 Thanks for the tips Dave and Pete. Pete I didn't catch the distortion issue until you pointed it out. I just thought the buildings looked some what different. Thanks again! Link to post Share on other sites More sharing options...
jankap Posted September 24, 2009 Share #7 Posted September 24, 2009 Advertisement (gone after registration) You should take a look at the stitch-software Autopano too. Very interesting! Jan Link to post Share on other sites More sharing options...
Overgaard Posted September 24, 2009 Share #8 Posted September 24, 2009 It's actually a good habit to keep the camera plane upright for as many photographs as possible as it will straighten the lines and create less disturbance in the background as well (even doing potraits) - unless of course the dramatic effect is wanted. Often it will result in a lot of concrete or floor in the buttom or ceiling in the top - which can be cropped away, and then you have a nice architecture shot with straight lines. I guess it's part of composition of the frame doing so, whereas the tempting thing is to "point the camera" at what you want to shoot and crop it tight. But resolution is so good and lenses so sharp you can easily get away with taking much more than you need and crop it away later to have the perfect photo say in the 1/3 upper left corner of the frame. Link to post Share on other sites More sharing options...
joppepop Posted September 24, 2009 Share #9 Posted September 24, 2009 As already said in this thread, shooting with the camera vertically (still pointing at the horizon, if you're standing on the ground) and later stitching them in Photoshop is a very good way to solve this problem. If you don't maintain a straight plane, the stitched result can get really awful. Tilt-shift lenses could do, but even with those you might need more FOV, and end up in stitching. Link to post Share on other sites More sharing options...
Mauribix Posted September 24, 2009 Share #10 Posted September 24, 2009 You should take a look at the stitch-software Autopano too. Very interesting!Jan Or take a look at here and use a telephoto lens as well... :D Esplora il Parco>Introduzione Link to post Share on other sites More sharing options...
Riley Posted September 24, 2009 Share #11 Posted September 24, 2009 always shoot as long a FL as you can in the firstplace as for correction, i do this stuff all the time, first remove distortion if you have any the it can be straightened in PS using transform, or like this in Paint Shop Pro (which is better at this stuff anyway) after you have dragged the corners out, what you must remember to do, is to reduce the height by 3/4 (on a 4x3 frame) of what was lost at the centre of the frame to restore the proportions. And just to make it clear that would be 2/3 on a 3x2 frame sorry the text on the images isnt very clear....I shall reproduce the notes from top to bottom top image turn grid on select 200 pixel select raster deform tool compare grid to desired verticals drag handles out to set verticals bottom image 2/ then drag top up to equalise frame proportions 1/ drag handles out to set verticals Link to post Share on other sites More sharing options...
Tenor1 Posted September 24, 2009 Author Share #12 Posted September 24, 2009 THANK YOU Riley! I appreciate the lesson. Maurizio, although I went to Italy, I didn't learn how to speak Italian in 2 weeks. I'll go and look at an English site for that program. Thanks for sharing it with me. Link to post Share on other sites More sharing options...
