M8 Blue Dot
lct
  • Replies 58
  • Created
  • Last Reply
Guest guy_mancuso
My guess the reason folks have seen it as blue is becuase it has a coating on it but what you are really seeing is a reflection from a light source.
I would have preferred the LED at the bottom of the top plate:
Guest guy_mancuso
Fake or not there should be a LCD box on top showing you battery , ISO , Exposure comp, Flash, remaining frames and stuff that is not in the menu selections and also WB. these should be available at a glance and that big dead space on the top deck should have that there. The round circle is really a dumb idea , there is maybe only 1 thing it could do. This is not film anymore and certain viewing stuff needs to be seen all the time without going into the menu. Look at the DMR which frankly the M8 is going to steal a lot of stuff from there are two screens one for menu and image viewing than one for frames remaining, ISO,wb set and so on and these need to be there not buried in a menu and if it is buried this camera is doomed. My personal feeling these are as fake as you can get without a top deck LCD this would never fly
Guest guy_mancuso
Now having said all that there is a way to do it and that is if they make the shutter a half way switch all that data pops up on the main LCD before you fully depress the shutter, than after release you see a image preview . now if you want to change a menu item than a button get's hit and takes you to the menu page an make your changes than hit the release half way than get back the ISO,WB,battery remaining and frames remaining stuff etc etc. There has to be a way to see this stuff on a fulime basis if you only have one screen. i tend to doubt they can get all that data inside the viewfinder and maybe they did and that could be the only other way of doing it but without that data than we have a problem Houston
hmmm...yes. sort of what i thought previously also. a half press of the shutter could poll the status of the settings and briefly display them in the viewfinder. the rear eye piece of the viewfinder seems bigger, there may be more room in the viewfinder for the information.
a half press of the shutter on the M7 locks the shutter speed for the exposure.
i still think something about the bump out on the left side door just seems kind of odd. i wonder why it isn't just a smooth spring loaded door that doesn't interfere with the design?
i think there may be some suprises regarding the way the M8 works that aren't apparent from simply looking at the camera.
I totallly agree, of course, and have said so in several threads...but I've been wondering, what if the "protrubance" on the left "door" is in fact a scrolling selector switch that scrolls that information through the round screen? That screen is bigger than it looks -- the screen alone is as big as the frame counter, plus the little ring around the frame counter, on an M7. You might be able to display two or three pieces of information at the same time.
Still, the rectangular screen on a D2x can be backlit, so you can read it in the dark, and see settings changes, and the backlighting is dim enough not to mess up your night vision. I don't see a backlighting switch, either.
Another thing: if you have to turn on the main screen to see all the changes, in addition to chewing up the battery, it's going to be a large bright rectangle. Not too good if you're shooting at night, on the street, or in a bar, where you might prefer to be less obvious.
I think there might be more going on here than we know, or that the pictures can tell us. I'd like to say that I'm now going to stop looking at Leica forums and not turn them on again until next Friday, but, realistically, there's no way that'll happen.
JC
jrc... yes. i was thinking how cool would it be if we could change the settings while looking through the viewfinder.
say the protruding part of the door had a little dial on top of it which could highlight a parameter(like iso) in the viewfinder, a half press of the shutter could then select that item, the dial could then change the setting and another half press of the shutter could then lock that new setting in place. whoa. i wish!
of course this is all just my brain being funny and waiting for 9/15. haha..
