EltonPL Posted July 30 Share #1 Posted July 30 (edited) Advertisement (gone after registration) I've just found a lovely used lens in box(s) with papers, etc. However, a thread protection ring for use without the thread-on shade is not included. Is one normally included with a new lens (as there was with my 28/2.8 Elmarit ASPH)? If they exist, I'd like to find one, as I often shoot without the hood because of the size. Edited July 30 by EltonPL Link to post Share on other sites More sharing options...
Advertisement Posted July 30 Posted July 30 Hi EltonPL, Take a look here Summicron-M 35 ASPH V2 (11673) question. I'm sure you'll find what you were looking for!
don daniel Posted July 30 Share #2 Posted July 30 vor 14 Minuten schrieb EltonPL: I've just found a lovely used lens in box(s) with papers, etc. However, a thread protection ring for use without the thread-on shade is not included. Is one normally included with a new lens (as there was with my 21 SEM)? If they exist, I'd like to find one, as I often shoot without the hood because of the size. Yes, that slim ring should be included. But did you really dig deep enough into the lens pouch? It might be underneath a piece that’s covering it. Link to post Share on other sites More sharing options...
M11 for me Posted July 30 Share #3 Posted July 30 Otherwise you could order is a a spare part. Link to post Share on other sites More sharing options...
EltonPL Posted July 30 Author Share #4 Posted July 30 Yes, Looked in the pouch bottom thoroughly. Will order as a spare. Thx! Link to post Share on other sites More sharing options...
don daniel Posted July 30 Share #5 Posted July 30 I would still recommend using the lens hood, because the Summicron 35mm ASPH is prone to lens flare. That’s also the reason why the lens hood was designed so large on version 2. Link to post Share on other sites More sharing options...
M11 for me Posted July 30 Share #6 Posted July 30 vor einer Stunde schrieb don daniel: I would still recommend using the lens hood, because the Summicron 35mm ASPH is prone to lens flare. That’s also the reason why the lens hood was designed so large on version 2. And that is why it could be that that lens is delivered without that ring. Indeed not all lenses have it in the box. Link to post Share on other sites More sharing options...
lct Posted July 30 Share #7 Posted July 30 Advertisement (gone after registration) I use the little hood of the Elmar-M 50/2.8 and did not notice significant flare with the Summicron 35/2 asph v2 so far. Works with the ring BTW. Link to post Share on other sites More sharing options...
don daniel Posted July 30 Share #8 Posted July 30 vor 4 Stunden schrieb M11 for me: And that is why it could be that that lens is delivered without that ring. Indeed not all lenses have it in the box. I remember quite well: This one has it, too. If you don't use the lens hood there is not only the screw on the front element of the lens. Link to post Share on other sites More sharing options...
M11 for me Posted July 31 Share #9 Posted July 31 vor 10 Stunden schrieb don daniel: I remember quite well: This one has it, too. If you don't use the lens hood there is not only the screw on the front element of the lens. Ok. I did not know it for sure. I just remember that a while ago I took all the lens hoods off the lenses and put on that ring. That is when I found out that not all lenses had it in the box 😇 By the way I have no lens hoods on my lenses any more (unless it is built in). I like it much more like that and the whole setting is smaller again. And I had no issues so far. Neither with flaits nor finger prints . . . And without the hood you need new lids (covers) as well of course. These are not in the box either (nit all the time anyway). And here I found out that not all the lenses have that vover as a spare part. In that case take the diameter of your lens a look which other lens has the cover with the same size. The Leica store new all of this of course . . . Link to post Share on other sites More sharing options...
