Eduardo Backhoff Posted February 9 Share #1 Posted February 9 Advertisement (gone after registration) It Is harmful to use Olympus Flashes on m11 Link to post Share on other sites More sharing options...
Advertisement Posted February 9 Posted February 9 Hi Eduardo Backhoff, Take a look here Non Leica Flash. I'm sure you'll find what you were looking for!
jdlaing Posted February 9 Share #2 Posted February 9 40 minutes ago, Eduardo Backhoff said: It Is harmful to use Olympus Flashes on m11 No Link to post Share on other sites More sharing options...
dante Posted February 23 Share #3 Posted February 23 In general, the best non-Leica flashes to use are Nikon speed lights that support A mode because the "ready" pin is the same as the Leica and will trigger the correct synch speed. But non-Leica flashes lose TTL operation, auto-zoom for focal length, and high-speed synch with M cameras. Dante 2 Link to post Share on other sites More sharing options...
jto555 Posted March 3 Share #4 Posted March 3 Most non Leica flashes will default to the centre pin to fine the flash. One upside is that they can "beat" the flash sync speed. In other words the camera can fire at a faster speed than the sync speed. Yes, only part of the frame will be illuminated by the flash but with careful subject placement you can get a shot at 1/500th sec with the subject against the bright sky, for example. I use it all the time. Link to post Share on other sites More sharing options...
dugby Posted March 4 Share #5 Posted March 4 Not sure how extensively you have researched within these Leica forum pages. There are references to a third party website “botzilla” that does collate the trigger voltages of many electronic flashes, which can guide your decision making for flash choice on any Leica M Many here have reported their experience with various manufacturers flashes. 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted March 13 Share #6 Posted March 13 Godox has dedicated Leica trigger and the Panasonic speedlight work with Leica too. 1 Link to post Share on other sites More sharing options...
Pelu2010 Posted March 13 Share #7 Posted March 13 Advertisement (gone after registration) The Godox For > Panasonic Speedlight I was referring to. Link to post Share on other sites More sharing options...
250swb Posted March 13 Share #8 Posted March 13 On 2/9/2025 at 4:47 PM, Eduardo Backhoff said: It Is harmful to use Olympus Flashes on m11 As I understand it you can use the Olympus flash guns in Auto mode, I have on my M10 anyhow. Something like the FL36 is both small and with a swing tilt head, features you don't often get on a flash gun that balances nicely on an M body. Link to post Share on other sites More sharing options...
jaapv Posted March 13 Share #9 Posted March 13 As far as I am aware, trigger voltage is a non-issue. The M series is safe to 600 V ( Mr. Daniel on the M8 (!) ).I think that the last high-voltage flash dates back to the 1960-ies. https://www.lucan.org.uk/Vintage/Hotshoes/volt_table.html Link to post Share on other sites More sharing options...
PhotoCruiser Posted March 13 Share #10 Posted March 13 (edited) vor 51 Minuten schrieb Pelu2010: Godox has dedicated Leica trigger and the Panasonic speedlight work with Leica too. Yep, i use successfully the Godox X3 trigger and two Godox V1 flashes for Nikon on my SL2 and i am not sure if the X3 works on the M11. The M11 is not on the compatibility list, but Godox is a bit fuzzy with what works and what not and you may contact them first. Also, all small Godox strobes do not work in TTL with the X3 trigger, but do in manual so you should test trigger and flash for working TTL I used successfully a older Metz flash on my Q2 in manual mode. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited March 13 by PhotoCruiser Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/419159-non-leica-flash/?do=findComment&comment=5771281'>More sharing options...
Jamie Roberts Posted March 13 Share #11 Posted March 13 FWIW my Profoto Canon flashes (A10s, I think) work just fine on the M11P in manual, and now there's a full Profoto remote for Leica that really does dial them in properly from the camera. Very pleased with them for wireless flash! Link to post Share on other sites More sharing options...
DadDadDaddyo Posted March 13 Share #12 Posted March 13 Flash?? Was ist Flash?? Keine Ahnung.... Link to post Share on other sites More sharing options...
Photoworks Posted March 14 Share #13 Posted March 14 9 hours ago, DadDadDaddyo said: Flash?? Was ist Flash?? Keine Ahnung.... yep, Leica totally forgot about creating light for images. they convinced many Leica photographers to use natural light, so they don't have to keep up with new flashes. 1 Link to post Share on other sites More sharing options...
levine889 Posted March 19 Share #14 Posted March 19 On 3/13/2025 at 3:47 AM, PhotoCruiser said: Yep, i use successfully the Godox X3 trigger and two Godox V1 flashes for Nikon on my SL2 and i am not sure if the X3 works on the M11. The M11 is not on the compatibility list, but Godox is a bit fuzzy with what works and what not and you may contact them first. Also, all small Godox strobes do not work in TTL with the X3 trigger, but do in manual so you should test trigger and flash for working TTL I used successfully a older Metz flash on my Q2 in manual mode. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! The Godox X3 does not work with the M11 https://www.dpreview.com/forums/post/67989812 Link to post Share on other sites More sharing options...
PhotoCruiser Posted March 19 Share #15 Posted March 19 (edited) Thanks for your important reply! Yes the X3 is not on the list of the compatible cameras and after Godox it will never work. Godox states in a email from the post on DPReview: Unfortunately, our technician responded that the compatibility issue is due to a mismatch in the hotshoe, which cannot be resolved through a firmware update. So it seems that the M11 has a different hots hoe what surprises me as it makes no sense to me. Chris Edited March 19 by PhotoCruiser Link to post Share on other sites More sharing options...
tpf1952 Posted March 25 Share #16 Posted March 25 On 3/13/2025 at 5:58 AM, Pelu2010 said: Godox has dedicated Leica trigger and the Panasonic speedlight work with Leica too. Pelu: Does the Panasonic speedlight work with the Leica X3 trigger in TTL also? Link to post Share on other sites More sharing options...
Photoworks Posted March 25 Share #17 Posted March 25 58 minutes ago, tpf1952 said: Pelu: Does the Panasonic speedlight work with the Leica X3 trigger in TTL also? the Godox V1pro with Olympus / Panasonic mount with talk the X3 for leica. a Panasonic brand flash will never work with the godox trigger, or profoto. that said the Godox trigger for leica does not work in TTL with M11 1 Link to post Share on other sites More sharing options...
