Giampi58 Posted December 27, 2024 Share #1 Â Posted December 27, 2024 Advertisement (gone after registration) Hi. I'm looking for a small, inexpensive TTL flash for Leica M11. Occasional use, not too expensive, what do you recommend? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted December 27, 2024 Posted December 27, 2024 Hi Giampi58, Take a look here TTL Flash. I'm sure you'll find what you were looking for!
dugby Posted December 28, 2024 Share #2 Â Posted December 28, 2024 Leica SF26 Link to post Share on other sites More sharing options...
jaapv Posted December 29, 2024 Share #3 Â Posted December 29, 2024 The SF 40 costs approximately the same - and is more powerful and better built. Link to post Share on other sites More sharing options...
lct Posted December 29, 2024 Share #4  Posted December 29, 2024 19 hours ago, dugby said: Leica SF26 +1. Small yes but inexpensve i have no idea. Here on digital CL. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/418167-ttl-flash/?do=findComment&comment=5730841'>More sharing options...
DadDadDaddyo Posted December 29, 2024 Share #5  Posted December 29, 2024 Flash??? Was ist?? Link to post Share on other sites More sharing options...
Photoworks Posted December 29, 2024 Share #6  Posted December 29, 2024 you should do your research on what is compatible. I would go with SF-40 is small is necessary and has to have TTL  many of the flat older flashes have the issue of not coming back up when the camera goes to sleep and wakes-up  Link to post Share on other sites More sharing options...
kiwidad Posted December 30, 2024 Share #7  Posted December 30, 2024 Advertisement (gone after registration) Sf26 is 124 grams and takes 2 AAA (30grams a pair) batteries and the SF40 weights in at 203 grams and take 4 AA (120 grams for four).  So on the camera the sf26 is 154 grams and the SF40 is 323 grams SF40 does HSS and Sf26 does not. The SF40 is a lot to put on top of an M11. Those weak pressure rails on the iso shoe will loosen up very quickly and it will flop around.  The SF26 is very compact and functions just as well unless you need HSS in which case . The Sf26 slips in a bag pocket nicely and barely takes more space than a camera battery does. The SF40 shape does not. I currently have an Sf26 which I use on the M11 and an Sf60 and SFC1 for times I need off camera flash. The Sf26 nicely slips into a bag pocket on my Billingham M bag. 1 Link to post Share on other sites More sharing options...
PhotoCruiser Posted February 2 Share #8  Posted February 2 What about the tiny Godox X3 wireless trigger and a Godox flash on a grip? Not really small, but it works at least on my SL2 but should also on a M. Chris EDIT: A short search found a tread in another forum with email between owner and Godox stating this. Zitat Unfortunately, our technician responded that the compatibility issue is due to a mismatch in the hotshoe, which cannot be resolved through a firmware update. So it seems no Godox with working TTL on the M11 😞 Link to post Share on other sites More sharing options...
Photoworks Posted February 2 Share #9  Posted February 2 6 hours ago, PhotoCruiser said: What about the tiny Godox X3 wireless trigger and a Godox flash on a grip? Not really small, but it works at least on my SL2 but should also on a M. Chris EDIT: A short search found a tread in another forum with email between owner and Godox stating this. So it seems no Godox with working TTL on the M11 😞 It works with M10, not M11 Link to post Share on other sites More sharing options...
