anonymoose Posted December 18, 2024 Share #101 Posted December 18, 2024 Advertisement (gone after registration) 15 minutes ago, SrMi said: The sensor readout is independent of processor used, though processor affects the time to process the image. 61MP sensor has slower readout than the 47MP. My assumption is other cameras with the same sensor/readout (e.g. M11, A7RV) that don't have the Q3's long blackout have something that allows them to be quick, but even that doesn't make sense now because the M11 has the Maestro III 🤷🏽♂️ Link to post Share on other sites More sharing options...
Advertisement Posted December 18, 2024 Posted December 18, 2024 Hi anonymoose, Take a look here Q3/Q3 43: Firmware update v.3.0.0 improves black out times and much more. I'm sure you'll find what you were looking for!
Cogito Posted December 18, 2024 Share #102 Posted December 18, 2024 1 hour ago, Steve19958 said: Completed the upgrade. Uploaded my saved user profiles. I noticed that the button customizations I had is not saved with the profiles. Am I corrected about this? Ended up redoing the button customizations again saving them with each profile. Whish there was a global save for this. don’t know why, but my customized buttons were restored after FW update 1 Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 19, 2024 Share #103 Posted December 19, 2024 Same here. Link to post Share on other sites More sharing options...
wlaidlaw Posted December 19, 2024 Share #104 Posted December 19, 2024 My numbering was retained but oddly the prefix, which I had changed from L to Q wasn't and I had to re-enter it again. Different cameras seem to be reacting differently to this FW update. Wilson Link to post Share on other sites More sharing options...
CharlieC Posted December 19, 2024 Share #105 Posted December 19, 2024 12 hours ago, Steve19958 said: Completed the upgrade. Uploaded my saved user profiles. I noticed that the button customizations I had is not saved with the profiles. Am I corrected about this? Ended up redoing the button customizations again saving them with each profile. Whish there was a global save for this. I found the same thing, today’s task is to re-program the buttons! Link to post Share on other sites More sharing options...
StyxTravel Posted December 19, 2024 Share #106 Posted December 19, 2024 Just updated, I think its my first FW update as only owned it for about 10 weeks. Anyway, it all went Ok thankfully. All six profiles properly saved, all the Function buttons correctly assigned and the photo count didn't reset and has carried on sequentially. The worst thing was setting the time as I had it to sync with iPhone but this wasn't remembered and I couldn't remember where the setting was... Link to post Share on other sites More sharing options...
Ivan M Posted December 19, 2024 Share #107 Posted December 19, 2024 Advertisement (gone after registration) If i RESET to factory settings will it erase my 3.0 FIRMWARE? I want to reset but i do NOT want to lose my 3.0. Thanks in advance. Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 19, 2024 Share #108 Posted December 19, 2024 1 minute ago, Ivan M said: If i RESET to factory settings will it erase my 3.0 FIRMWARE? I want to reset but i do NOT want to lose my 3.0. Thanks in advance. I don't know, but you can always download and install it again, can't you? Link to post Share on other sites More sharing options...
Ivan M Posted December 19, 2024 Share #109 Posted December 19, 2024 7 minutes ago, LocalHero1953 said: I don't know, but you can always download and install it again, can't you? I am afraid things could go SIDEWAYS, LOLOLOL. 1 Link to post Share on other sites More sharing options...
Ivan M Posted December 19, 2024 Share #110 Posted December 19, 2024 Ok just did a FACTORY reset and it did NOT delete my latest FIRMWARE 3.0, in case anyone wants to know. 4 Link to post Share on other sites More sharing options...
nussbusch Posted December 20, 2024 Share #111 Posted December 20, 2024 vor 21 Stunden schrieb Ivan M: If i RESET to factory settings will it erase my 3.0 FIRMWARE? I want to reset but i do NOT want to lose my 3.0. Thanks in advance. A reset does NOT erase firmware. The last is always kept. 2 Link to post Share on other sites More sharing options...
Ivan M Posted December 20, 2024 Share #112 Posted December 20, 2024 3 hours ago, nussbusch said: A reset does NOT erase firmware. The last is always kept. Thank you sooo much, i always worry about updating NEW FIRMWARE. Even while doing it i get CRAZY nervous, i wont even answer my phone. I don't want to BRICK this GORGEOUS camera. Link to post Share on other sites More sharing options...
Michal76 Posted December 21, 2024 Share #113 Posted December 21, 2024 Hi, after fw 3.0 update, my Leica Q3 has frozen three times , and I had to take out the battery in the middle of taking photos. After putting it back in, everything worked fine again. No issues with the previouse fw 2.5... Is there any workaround??? Thanks, Michal Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 21, 2024 Share #114 Posted December 21, 2024 27 minutes ago, Michal76 said: Hi, after fw 3.0 update, my Leica Q3 has frozen three times , and I had to take out the battery in the middle of taking photos. After putting it back in, everything worked fine again. No issues with the previouse fw 2.5... Is there any workaround??? Thanks, Michal Do you mean that since taking the battery out it has not frozen again? In which case there is no need for a workaround. Or do you mean that you have had to remove the battery three times? In which case you have found a workaround, but not a solution. You could try the usual checks: reset to factory settings, and try a different SD card, freshly formatted. Link to post Share on other sites More sharing options...
Michal76 Posted December 22, 2024 Share #115 Posted December 22, 2024 Hi, It happens like this... I take a photo and suddenly the camera freezes. It won't turn off, won't take pictures, it doesn't respond. The only thing that works is pulling out the battery, and then everything works fine. After a while, the same scenario happens again. This has repeated 3 times after the update to fw 3.0. Thanks, Michal Link to post Share on other sites More sharing options...
Le Chef Posted December 22, 2024 Share #116 Posted December 22, 2024 The old solution is to change the SD card and format the new one in camera. Other than that which is common, any other cause is likely down to your particular settings rather than being a generic problem. You could also switch off Bluetooth and disconnect from Fotos if you use them, and see if that solves the problem. 1 Link to post Share on other sites More sharing options...
volatileagent Posted December 22, 2024 Share #117 Posted December 22, 2024 On 12/18/2024 at 4:32 PM, anonymoose said: My assumption is other cameras with the same sensor/readout (e.g. M11, A7RV) that don't have the Q3's long blackout have something that allows them to be quick, but even that doesn't make sense now because the M11 has the Maestro III 🤷🏽♂️ I’ve used the M11 some and it has the same long blackout time when shooting in live view. Curious what the SL3 is like—from what I can tell, it is the same too. Link to post Share on other sites More sharing options...
volatileagent Posted December 22, 2024 Share #118 Posted December 22, 2024 Regarding the improvement in blackout time, I am only seeing it when shooting in the camera’s default profile. Whenever I switch to a custom profile, the longer blackout time is back. It is very different when switching between default and User 1. Anyone else notice this? Link to post Share on other sites More sharing options...
LocalHero1953 Posted December 22, 2024 Share #119 Posted December 22, 2024 (edited) 36 minutes ago, volatileagent said: Regarding the improvement in blackout time, I am only seeing it when shooting in the camera’s default profile. Whenever I switch to a custom profile, the longer blackout time is back. It is very different when switching between default and User 1. Anyone else notice this? I find it difficult to judge, though I think you're right. I hadn't noticed because I always use a custom profile. It never disturbed me particularly, so I can't remember what it was like before the update. Edited December 22, 2024 by LocalHero1953 Link to post Share on other sites More sharing options...
jplaurel Posted December 22, 2024 Share #120 Posted December 22, 2024 Thanks to the Q firmware team for implementing the AF-L feature. I just got back from shooting a wedding, and this feature improves the usability of the Q dramatically! Well done, Leica. 1 Link to post Share on other sites More sharing options...
