SrMi Posted February 2 Share #61 Posted February 2 Advertisement (gone after registration) 10 minutes ago, FlashGordonPhotography said: On an SL body, all this does is switch the IS system from the lens to the body, so IS would still be active, just in another way. You’d also need to turn the IS off in the body (while the lens IS is off or the option is greyed out). The system would still use some power to keep the sensor floating. I am not sure how much more power the lens IS uses compared to IBIS. Gordon In my experience with Nikon long lenses, OIS on lenses with heavy glass drains battery a lot. IBIS drains much less battery than EVF or LCD. 1 1 Link to post Share on other sites More sharing options...
Advertisement Posted February 2 Posted February 2 Hi SrMi, Take a look here IBIS and OIS . I'm sure you'll find what you were looking for!
hdmesa Posted February 2 Share #62 Posted February 2 54 minutes ago, SrMi said: In my experience with Nikon long lenses, OIS on lenses with heavy glass drains battery a lot. IBIS drains much less battery than EVF or LCD. @FlashGordonPhotography, my experience aligns with this above. I'm ok with IBIS reactivating when I turn off OIS, I just don't want OIS running constantly sometimes, especially with lenses with large elements that draw a lot of power to stabilize. If that 105mm filter on the end of the 60-600 is any clue to the size of the elements in the stabilization group, then it's probably drawing a lot of power with OIS on 😵💫 That said, I wonder if the IBIS of the SL2/3 actually reactivates when the Sigma OIS switch is turned off. I don't have a stabilized Sigma lens at the moment to test it with (still need to re-buy some L lenses after bouncing back and forth between M and SL systems a few times). 1 Link to post Share on other sites More sharing options...
jaapv Posted February 2 Share #63 Posted February 2 With lenses of the focal lengths we are discussing, it should not make much of a difference whether IBIS is switched on . Link to post Share on other sites More sharing options...
SrMi Posted February 2 Share #64 Posted February 2 50 minutes ago, hdmesa said: @FlashGordonPhotography, my experience aligns with this above. I'm ok with IBIS reactivating when I turn off OIS, I just don't want OIS running constantly sometimes, especially with lenses with large elements that draw a lot of power to stabilize. If that 105mm filter on the end of the 60-600 is any clue to the size of the elements in the stabilization group, then it's probably drawing a lot of power with OIS on 😵💫 That said, I wonder if the IBIS of the SL2/3 actually reactivates when the Sigma OIS switch is turned off. I don't have a stabilized Sigma lens at the moment to test it with (still need to re-buy some L lenses after bouncing back and forth between M and SL systems a few times). I prefer the way I can set up my Nikon: the shutter half-press enables stabilization. Link to post Share on other sites More sharing options...
jaapv Posted February 3 Share #65 Posted February 3 1 hour ago, hdmesa said: @FlashGordonPhotography, my experience aligns with this above. I'm ok with IBIS reactivating when I turn off OIS, I just don't want OIS running constantly sometimes, especially with lenses with large elements that draw a lot of power to stabilize. If that 105mm filter on the end of the 60-600 is any clue to the size of the elements in the stabilization group, then it's probably drawing a lot of power with OIS on 😵💫 That said, I wonder if the IBIS of the SL2/3 actually reactivates when the Sigma OIS switch is turned off. I don't have a stabilized Sigma lens at the moment to test it with (still need to re-buy some L lenses after bouncing back and forth between M and SL systems a few times). The problem being however, that when you are in a situation that requires quick reactions, this will lose you opportunities. I find a battery grip a better solution. Link to post Share on other sites More sharing options...
FlashGordonPhotography Posted February 3 Share #66 Posted February 3 4 hours ago, hdmesa said: @FlashGordonPhotography, my experience aligns with this above. I'm ok with IBIS reactivating when I turn off OIS, I just don't want OIS running constantly sometimes, especially with lenses with large elements that draw a lot of power to stabilize. If that 105mm filter on the end of the 60-600 is any clue to the size of the elements in the stabilization group, then it's probably drawing a lot of power with OIS on 😵💫 That said, I wonder if the IBIS of the SL2/3 actually reactivates when the Sigma OIS switch is turned off. I don't have a stabilized Sigma lens at the moment to test it with (still need to re-buy some L lenses after bouncing back and forth between M and SL systems a few times). Yes it does, up to about 400mm which I think is the limit of the SL2/3 IBIS. I have a flock of Sigma lenses in L mount. When I did my shutter shock testing on the SL3 I had to test with both IS systems on/off as well as mechanical vs ES. I’m more than happy to go with you and SrMi on this. I have the lenses but have never bothered to test for extra battery drain. I do trust your experiences will both be accurate. Gordon 1 Link to post Share on other sites More sharing options...
hdmesa Posted February 3 Share #67 Posted February 3 Advertisement (gone after registration) 4 hours ago, SrMi said: I prefer the way I can set up my Nikon: the shutter half-press enables stabilization. Agree. 4 hours ago, jaapv said: The problem being however, that when you are in a situation that requires quick reactions, this will lose you opportunities. I find a battery grip a better solution. Sigma lens switch is a workaround. Definitely not ideal. That's why I originally said I wish we could have the option for stabilization only to be active half shutter press like the S5IIX (and others) 😁 57 minutes ago, FlashGordonPhotography said: ...I have the lenses but have never bothered to test for extra battery drain. I do trust your experiences will both be accurate. Could be interesting to test generally (an hour shooting with just IBIS versus an hour shooting with just OIS – but it would be hard to keep it equal). Perhaps OIS is more efficient than one would think. 1 Link to post Share on other sites More sharing options...
jaapv Posted February 3 Share #68 Posted February 3 More like a matter of preference . I prefer lens switches in general. Much faster and ergonomic in use. No delving into menus or wasting Fn buttons for occasional functions. And I like the USB programmable function switch of some Sigma lenses. Link to post Share on other sites More sharing options...
SrMi Posted February 3 Share #69 Posted February 3 9 hours ago, jaapv said: More like a matter of preference . I prefer lens switches in general. Much faster and ergonomic in use. No delving into menus or wasting Fn buttons for occasional functions. And I like the USB programmable function switch of some Sigma lenses. I like one way of doing it. I find it confusing when sometimes you have to do it on the lens and sometimes in the camera. Link to post Share on other sites More sharing options...
jaapv Posted February 3 Share #70 Posted February 3 I like to avoid doing things on the LCD other than setting up the camera. Link to post Share on other sites More sharing options...
SrMi Posted February 3 Share #71 Posted February 3 58 minutes ago, jaapv said: I like to avoid doing things on the LCD other than setting up the camera. That would mean avoiding all Leica L-mount lenses. Link to post Share on other sites More sharing options...
jaapv Posted February 3 Share #72 Posted February 3 If truth be told - it is one reason that I prefer the Sigmas over the parallel Leica versions 1 Link to post Share on other sites More sharing options...
SrMi Posted February 3 Share #73 Posted February 3 1 hour ago, jaapv said: If truth be told - it is one reason that I prefer the Sigmas over the parallel Leica versions And similarly, truth be told, that is why I prefer the Leica versions to the corresponding Sigma lenses. We are lucky that we have a choice. 1 Link to post Share on other sites More sharing options...
