DreiPunkte Posted November 4, 2024 Share #1 Posted November 4, 2024 (edited) Advertisement (gone after registration) My '57 M3 DS started producing this stripe on the right side of the negative, as shown. This only happens at 1/1000. Am I correct that the 'closing curtain break' needs to be adjusted? Any idea why this is happening. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited November 4, 2024 by DreiPunkte Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/415775-m3-ds-shutter-error-11000/?do=findComment&comment=5684849'>More sharing options...
Advertisement Posted November 4, 2024 Posted November 4, 2024 Hi DreiPunkte, Take a look here M3 DS shutter error 1/1000. I'm sure you'll find what you were looking for!
TomB_tx Posted November 4, 2024 Share #2 Posted November 4, 2024 I'd guess you are correct! 1 Link to post Share on other sites More sharing options...
jankap Posted November 4, 2024 Share #3 Posted November 4, 2024 It could be, that the second curtain bounces at the end of its path. 1 Link to post Share on other sites More sharing options...
mujk Posted November 4, 2024 Share #4 Posted November 4, 2024 Agree. I have seen exactly the same problem with a similar shutter in a camera of another brand. In that case the reason was "worn break pads". 1 Link to post Share on other sites More sharing options...
a.noctilux Posted November 4, 2024 Share #5 Posted November 4, 2024 For me, I had same kind of trouble, if other speeds are ok, I would not use 1/1000 which is well known for it's inconsistency. When I use Leica M and LTM (same type of cloth blinds), over years the fastest shutters are mostly avoid. Sometimes, CLA can cure this but not always in my case, sometimes temperature (hot/cold) dependant ... I may be wrong just as user. 1 1 Link to post Share on other sites More sharing options...
DreiPunkte Posted November 5, 2024 Author Share #6 Posted November 5, 2024 18 hours ago, a.noctilux said: ... sometimes temperature (hot/cold) dependant ... Temperature was the thing I thought at first because the camera starts this habbit in the north. Link to post Share on other sites More sharing options...
jerzy Posted November 6, 2024 Share #7 Posted November 6, 2024 Advertisement (gone after registration) black stripe is overexposed, it could be that the second curtain is bouncing or it brakes too early. In both cases it may be cured by adjusting brake for the second curtain and/or controlling the brake for opening curtain. You may check break for the opening curtain so: open back door, set speed to B, shut and keep relese down. Observe the metal bar of opening curtain that shall be 2-3mm behind the edge of the frame. Checking the brake for closing curtain is not so trivial, remove lens, set speed to 1/1000, open back door. release and observe if you can notice the white stripe on the left edge of the frame. Another, better method required to hearing and some experince what is the sound when the second curtain is closing. 1 1 Link to post Share on other sites More sharing options...
DreiPunkte Posted November 6, 2024 Author Share #8 Posted November 6, 2024 3 hours ago, jerzy said: black stripe is overexposed, it could be that the second curtain is bouncing or it brakes too early. In both cases it may be cured by adjusting brake for the second curtain and/or controlling the brake for opening curtain. You may check break for the opening curtain so: open back door, set speed to B, shut and keep relese down. Observe the metal bar of opening curtain that shall be 2-3mm behind the edge of the frame. Checking the brake for closing curtain is not so trivial, remove lens, set speed to 1/1000, open back door. release and observe if you can notice the white stripe on the left edge of the frame. Another, better method required to hearing and some experince what is the sound when the second curtain is closing. Thank you very much. I will check that when the camera is emty. Link to post Share on other sites More sharing options...
