yesterday i had a severe problem with my q3 28. out shooting I noticed that my images where much to contrasty. At first I thought ofcourse it was te settings of the camera but i couldnt find anything, ( i shoor only L- DNG manual with auto iso)  the images are not only much to contrasty on te display but also on the computer. battery out and in also didn't work.  the only thing that worked was to reset the camera. after that that  the images where ok again .  But a second problem occured during te reset.  The camera didnot keep the presets despite the camera asked for it and i confirmed.  . does Anyone has an idea about the two problems?
Just now, David Wien said:
Show us your too-contrasty images, please.  What did you use to process the raw files?
David
i did not proces the raw files at all
How is your metering set?  You're shooting a dark object against a bright sky.  The camera is probably lowering the exposure of the whole image to protect the highlights in the sky, which is darkening your subject.  Shouldn't be a problem with RAW, just lift the shadows in post.  Your sky isn't blown out so it looks like a perfectly reasonable out of camera RAW file.  You also could have added a bit of exposure compensation to capture the details in the subject, but then your sky would have been overexposed.
The high contrast image is due to a cloudy sky. It seems normal to me. Overcast skies are much bigger issues than blue skies.
Edited by SrMi
