F456 Posted October 6, 2024 Share #1  Posted October 6, 2024 Advertisement (gone after registration) Not the most exciting topic but I could do with some clarification regarding certain combinations of lens versions and appropriate hoods. I have a 12504 metal 2-part unscrewable clip-on hood that came with my Summilux 35mm 11870 lens bought new in 1992. You unscrew it to insert Series VII filters.  So far so good... It also has inscribed on the hood however that it is suitable for 1:2/35 (as well as the 1:1.4 that I have described just above). Question 1: which version Summicron 35mm was it supplied with? I imagine but don't know for sure that the 'dinky but effective' (courtesy Brian Bower) rectangular plastic hood 12524 was introduced at the same time as Summicron v4 11310. Does that mean that the 12504 hood was supplied only up to the end of v3 as far as Summicrons are concerned? I know it stayed as the supplied hood for the Summilux till the 46mm diameter aspherics took over. I also have a 12538 plastic clip-on hood that came with my Summicron 50mm v4 11819. However, I also have from separate accessory purchases several 12585 metal lens hoods for 1:2/50 Question 2: which version(s) of Summicron 50mm was the 12585 hood supplied with? And one of those 12585 hoods is designated actually as 12585 H and has the front shade  part in a dark grey metallic colour next to the black of the mounting / clip-on ring — any ideas why or for which camera? Finally, these 12585 hoods also have marked that they are suitable for 1:2/35 as well as various slower lenses, so: Question 3: which 35mm lenses and  versions are the 12585 hoods matched up with? Thank you if you got this far! Link to post Share on other sites More sharing options...
Advertisement Posted October 6, 2024 Posted October 6, 2024 Hi F456, Take a look here 35 & 50mm lens hoods. I'm sure you'll find what you were looking for!
TomB_tx Posted October 6, 2024 Share #2 Â Posted October 6, 2024 When I bought my 35 (v2) & 50 (v3) Summicrons in 1969 they were supplied without hoods - you had to order hoods separately as accessories. I did get 12585 and 12504 hoods for them at that time. 1 Link to post Share on other sites More sharing options...
a.noctilux Posted October 7, 2024 Share #3  Posted October 7, 2024 1- hood 12504 was for 2/35 version II/III these don't have "2 grooves" to prevent from turning square hood 12524/12526 2- 12585/12538 can be used on a- 2/35 version II/III b- vignetting at corners (depending on the distance/aperture) with version IV (11310). 3 - see 2a  1 Link to post Share on other sites More sharing options...
lct Posted October 7, 2024 Share #4  Posted October 7, 2024 6 hours ago, a.noctilux said: 2- 12585/12538 can be used on a- 2/35 version II/III Version I of the Summicron 35 too (8 elements). 1 Link to post Share on other sites More sharing options...
lct Posted October 7, 2024 Share #5 Â Posted October 7, 2024 On 10/6/2024 at 7:28 PM, F456 said: I have a 12504 metal 2-part unscrewable clip-on hood that came with my Summilux 35mm 11870 [...] which version Summicron 35mm was it supplied with? None AFAIK. If memory serves it was sold apart as accessory. 1 Link to post Share on other sites More sharing options...
lct Posted October 7, 2024 Share #6 Â Posted October 7, 2024 On 10/6/2024 at 7:28 PM, F456 said: which version(s) of Summicron 50mm was the 12585 hood supplied with? None AFAIK. If memory serves 12585 and 12585H hoods were sold as accessory. 1 Link to post Share on other sites More sharing options...
lct Posted October 7, 2024 Share #7  Posted October 7, 2024 Advertisement (gone after registration) On 10/6/2024 at 7:28 PM, F456 said: one of those 12585 hoods is designated actually as 12585 H and has the front shade  part in a dark grey metallic colour next to the black of the mounting / clip-on ring — any ideas why or for which camera? No special camera. See: 1 Link to post Share on other sites More sharing options...
F456 Posted October 12, 2024 Author Share #8 Â Posted October 12, 2024 On 10/7/2024 at 7:29 PM, lct said: No special camera. See: Thanks for all your help over these hoods, lct. 1 Link to post Share on other sites More sharing options...
F456 Posted October 12, 2024 Author Share #9 Â Posted October 12, 2024 Thank you all for your help. Great forum this! No further questions on this topic from me. Link to post Share on other sites More sharing options...
