vor 32 Minuten schrieb M11 for me:
Did you "delete" the camera in the BT settings of your iPhone/iPad?
I do not have the Q3 43 but the Q3 and with this one it works fine. So in your case there is something else.
Hope it works.
In the Camera AND on the Smartphone the Bluetooths connections should be removed. Then Restart the connection process
I restart the process with cable first or directly bluetooth ?
Edited by cirke
1 hour ago, egrossman said:
I had difficulties setting up the Q3 43 with bluetooth so in the end opted to connect the camera via USB-C to complete the configuation.
Configuring using USB-C is much smoother. I did it the first time with Q3 43.
